Question about Sharp R-820B Convection/Microwave Oven
Heat's water great , won't pop corn
Sharp R820BC convection/microwave oven 900watts
  • 1 more comment
  • souldawg Jun 06, 2008
    Even off center, the microwave still won't properly pop popcorn. Everything else is fantastic. However, I really like popcorn...
  • Anonymous Jun 26, 2008
    I place the popcorn in the convection oven press popcorn regular and 2-3 minutes later.. nothing. Help!
  • Anonymous Mar 30, 2014
    not heating
  • Sharp Master
  • 9,173 Answers
It may be a food placement issue or possibly a bad humidity sensor.
I always recommend that folks put food off-center on the turntable (not in the center) to assure more even heating.
It's a stirring action, so imagine how inefficient it would be to stir just by twirling a spoon in the center of your coffee!
Also, when you put your food off-center, you're not putting it in the same spot every time. That will help prevent repeated heating of the the same spot on the glass, which can lead to weakness and cracking. Microwave popcorn gets hot enough to do that.
We have the entire service manual at our site if your or a friend want to look that over: http://www.microwavedisplay.com/r820bc_bk_bw_sm.pdf
If you need a new sensor, you can order Sharp parts from Tritronics at http://www.wehaveparts.com
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 04, 2007
    New Friend:
It was suggessted to me to use the wire rack to place the popcorn bag on... Seems to work better!
Posted on Jul 13, 2013
The manual says to put popcorn bag on overturned glass pie plate because the microwave emisions are higher than in a conventional microwave.
However, I do not want to use any more Pyrex because of all the reports of it exploding unexpectedly and injuring many people. I am wondering if this new silicone bakeware could be used to hold the bag instead.
Anyone else use something besides a glass pie plate for their popcorn?
Posted on Dec 10, 2007
  • thebigdog284
    thebigdog284 Nov 30, 2012
    I had a custome rjust put in a standard Dinner plate and this solved the probem
SOURCE:
I have a few questions, we have a convection microwave in our motor home. Is there special cookware I should use? How do you figure out cook times when baking in it?
if only using on convection it is like any other oven so either metal or corning ware, if using with microwave it must be a microwave safe material like corning ware, which is also good for heat.
Mar 19, 2018 | In Microwave Ovens
Sharp R-405H microwave turntable doesn't rotate and makes strange noise
Replace the turntable motor, it is defective and will only get worse.
Mar 17, 2012 | Sharp R-405H 1100 Watts Microwave Oven
Sharp R-1406 made a loud pop and now sounds like its draging and not heating up 2002 model
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Nov 03, 2010 | Sharp R-930AK Convection/Microwave Oven
Where is the internal thermal fuse located at on the R820bc
check underneath or on back for removable panel,or go to- sharp r820b on web for customer care assistance
Oct 08, 2010 | Sharp R-820B Convection/Microwave Oven
Sharp R-1870 Convection works, microwave doesnt heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ytwyys
Oct 07, 2009 | Sharp R-1870 Convection/Microwave Oven
Turntable stop working along with microwave and convection oven
would be a door micro-swtch sharp part # Sharp Part Number: QSW-MA085WRE0
Jan 07, 2009 | Sharp R-1405 / R-140 Microwave Oven
Microwave turntable won't turn
Most likely the turntable motor itself is bad - not an uncommon problem for that model.
Check with www.martinmicrowave.com (toll free 1-877-894-0035)
unfortunately, the particular motor used in your model is rather expensive - + - $50
Dec 23, 2008 | Sharp R-930AK Convection/Microwave Oven
PROBLEM WITH SHARP R-1874TF CONVECTION OVEN
sometimes an over heat will shut down the oven for a little bit but lets look at other things
i dont believe the board to be bad but i do believe the heating element inside is fried or a wire got fried by heat
if you know how to use ohm tester i would check heating element and wireing first
then try to see if the timer gave out
Dec 06, 2008 | Sharp R-1874 Convection/Microwave Oven
Sharp r1500 microwaive
Indeed, sounds like the magnetron is shot. Not a big deal, I've replaced them before. But unless you know what your doing, don't! If under warranty, get a service tech out. Check on the service call charge ($) first....it may be cheaper to buy a new micro!
May 12, 2007 | Sharp R-1500 Microwave Oven
Sharp R-820B Convection/Microwave Oven Logo
1,293 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
