Question about Dell E171FPb 17" TFT LCD Flat Panel Monitor
No picture my dell model # e171fpb 17 inch flat screen when turned shows bars you can tap the back and it just changes from like a grayscale to different colors and then different bars but no picture
    Problem Solver:
  • 5 Answers
Pull the back off of the monitor. Check for loose connectors that connect the scaler, power supply, and logic board. I doubt its a loose cable but you may get lucky. Most likely it is a bad solder joint in the logic board.
Posted on Feb 17, 2008
  • 3 Answers
Try to reverse the cable....use the end connected to the computer at the monitor and the monitor end to the computer. If tapping the monitor doesn't do anything and tapping the cable at the computer does the same faults then I would have it checked or just replace that cable.. Good luck.
Posted on Jan 06, 2008
SOURCE:
Black screen when the power is on.
Common failure in the Dell are shorted transistors or bad caps in the inverter ccircuits, bad solder joints, bad caps in power supply. I would try it on another PC first, if it still does not work, you will have to open it up. Please look through my pictures of failed Dell moniotrs to get some ideas.
http://s807.photobucket.com/home/budm/allalbums
Replacement board: http://www.lcdrepair.us/e171fpb-power.html
Please post back what you find.
Apr 22, 2010 | Dell E171FPb 17" Flat Panel LCD Monitor
PICTURE ON MONITOR SCREEN IS SIDEWAYS
Your screen is set to sideways. These the common features for all video cards. You can set it back to default, just go to video control panel of your video card and find Display Rotation.
Nov 03, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell E171FPb 17" TFT LCD Flat Panel Monitor Problem
The LCD and or the LCD inverted has failed. it is an unfortunate fact of life that nowdays it is cheaper to replace that monitor that to aquire parts for repair
Here is one on Ebay:
http://cgi.ebay.com/Dell-E171FPb-LCD-17-Flat-Panel-Color-Monitor_W0QQitemZ290290215133QQcmdZViewItem
You can buy a new 19 for about the same price
http://www.newegg.com/Product/Product.aspx?Item=N82E16824254009
Jan 21, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
E171Fpb driver on dimension 2400
installing windows again then the monitor driver should resolve the problem
Jun 25, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell e171fpb lcd monitor
The driver tabs between the LCD panel and it's controller board have failed.
These are very fragile and not repairable for anything in the cost effective range.
Best option is to either find a new panel to replace it, or get a new monitor.
Sep 10, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell E171FPb 17" TFT LCD Flat Panel Monitor Logo
116 people viewed this question
Ekse
Clive
Clive
