Question about RCA RTD258 System
Reads all as BAD DISC
We recently acquired 2 of these systems (RCA RTD-258) and both have the same problem. Neither will read any discs. They spin and say loading, but then come up and say BAD DISC, no matter what we put in them.
Any suggestions. We have already cleaned the lenses on both systems.
  • 2 more comments
  • zincboy Apr 23, 2008
    I have the same problem - all discs read as BAD DISC.
    I have also attempted to clean the lenses, as suggested by on-line support FAQ.
  • moose207 Sep 06, 2008
    My RTD 258 also will not read discs. Thr disc drive also makes an unusual low grinding noise before the " bad disc" error message appears
    Tried using an air can to clean it but do results.
  • richardwm222 Sep 27, 2008
    same problem as others, bad dics appears. last rca product I'll ever puchase!!
  • Anonymous Sep 29, 2008
    I Have the same issue and some how all DVDs I have tried read BAD DISC
  • 31 Answers
My friend do you try to adjust the 2 potentiometer behind the dvd lens.?
there is 2 potentiometer and they can maybe be the problem.
but you have to be very delicated. and move only by milimeters. becouse if you move a lot maybe the unit no read more.
if you need help and you fell ready to do that ask to me.
Posted on Sep 19, 2009
    New Friend:
I have the same problem, but all the data DVD's recorded with mi PC works ok! (p.e. MP3 DVD disks). The lens are not the problem, i think.
Posted on Oct 25, 2009
SOURCE:
Why wont my rca rtd 205 fail to read any disc then power down?
If it is not reading then either the motor that spins the disk is bad or the laser is burned out.
Aug 20, 2015 | RCA Audio Players & Recorders
My RCA RTD 206 5 disc changer wont play DVD's. It stays on Disc 3 or just says close. I called the # in the manual foe help, but its no longer in service.
If it plays the same disc without issues, you have a mechanical(or the electronics powering the motors and such) problem. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 20, 2013 | Audio Players & Recorders
Drc99391
Usually if "no disc" the optical unit in the player is either dirty or bad.
If bad cheaper to buy a new unit as individual parts are not usually sold for this type of equipment.
Dec 08, 2012 | RCA Televison & Video
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Disc changer won't open, won't play DVDs. RCA RTD
Check the belt inside underneed the tray if this is still in place.
if not put belt back on
Feb 15, 2010 | Bose Lifestyle 12 System
Whenwe try to use dvd it reads bad disc used dvd
Hi did you try cleaning the washer that spins the cd they often get glazed and slip causing the cd to spin at a low rpm causing the bad disc error.
Feb 01, 2010 | Daewoo DV-6T955B DVD Player/VCR
Reads Bad Disc also. Just bought a memorex DVD lens cleaner disc. And that also reads bad disc.
What is the format of the data on your CD?
It is not all players that plays all CD's, so maybe the CD you inserted is among those that your player cannot play.
Or maybe you need to change the lens totally, but before you do this, try some other CD's on the player and see how it responds.
Nov 05, 2009 | RCA RTD258 System
Bose 321 system reads bad disc on all dvds
if will not read a laser lens cleaning disc , then it will need to be opened up and the laser lens will need to be cleaned manually with the cleaning solution and a cotton tip , but do it easy and dry the lens with the cotton tip
if that don't do it then the laser mechanism will need replacing
electech
Nov 27, 2008 | Bose 3 2 1 GSX System
Rca rtd 160 home theater
Power regulator burnt beyond recognition
Mar 09, 2008 | RCA RTD160 System
Sony mini hi fi shelf system reads no disk
you may have a defective lense . but check your disc to see if they are dirty..
Jan 06, 2008 | RCA RS2505 CD Shelf System
RCA RTD258 System Logo
482 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
