Question about Palm Treo 700w Smartphone
Treo 700 It is like my phone is stuck. It keeps flashing on and off. I took the battery out hoping it will quit but it does not. I can not receive calls or call out? Please help? Nancy
Mine did the same thing also would not charge. I called Verizon data center and they did not even go through a re-set, just sent me a new phone. It is a common problem with hardware.
Posted on Feb 10, 2008
Cant find cd to set up computer and hotsync phone to
Here you can find all information related to your Palm Treo 700 W:
http://kb.palm.com/wps/portal/kb/na/treo/700w/verizon/home/page_en.html
If you want to hotsync your phone you need to download the Microsoft Active Sync software from this site:
ActiveSync Software
for Windows XP icon_activesync.png Download Updater 1.22 (Windows Installer) for Treo 700w/wx for Verizon downloads-item-update.png Update your phone Update Windows Mobile
Device Center for Vista icon_activesync.png Learn more
Hope it helped.
Nov 19, 2009 | Palm Treo 700w Smartphone
The screen is blank white and the back light keeps flashing
Sounds like your charger isn't working. Meter it. Also possible, it may nt be working IN the phone.
Aug 08, 2009 | Palm Treo 680 Smartphone
Treo 700 P red, white, blue, green checkered screen
Finally found this solution! It is a connection issue at the bottom of the phone where you would plug in the cable to hotsync your phone.
Put in your hotsync cable and wiggle it around really good and it will fix the issue. Do this with the battery out and then pop it in until you have fixed the issue. Took me a few tries as I was worried about how hard to do it, but no problem!
Jul 28, 2009 | Palm Treo 700p Smartphone
Hello, have a Palm 755p Treo screen just keeps flashing
There are multiple reasons for the phone to go into an endless loop.
Fix #1 - Soft Reset - Take out the battery. On the back of your phone, pop the cover off, remove battery, place battery back in and it will show each screen once and power on normally.
Fix #2 - Hard Reset - To do a hard reset, hold the power button while you replace the battery and then release it when the Palm logo appears.
Fix #3 - Hammer
Apr 09, 2009 | Palm Treo 755p Smartphone
My palm 755 wont hot sync
Restart your Palm Treo 744p. Take out the battery from the phone for more than 3 min and put it back in. Switch on the phone and then try to Hot sync Again. Hopefully it will work. I am assuming that you installed the Palm Desktop software came with the phone on your computer
I have same problem once in a while when i try to hotsync with new comp and this trick always worked for me.
Nov 17, 2008 | Palm Treo 755p Smartphone
How to unlock my palm treo 700 from verizon
I WOULD LIKE TO KNOW HOW TO UNLOCK MY PALM TREO 700 FROM VERIZON TO ATT
Aug 18, 2008 | Palm Treo 700w Smartphone
Treo 755
Did you ever figure this out? Mine is doing the exact same thing now.
Aug 01, 2008 | Palm Treo 755p Smartphone
Treo 680 charging light flashes red when disconnected from charger
Have you activated phone yet? When phone is activated and in service it flashes green. It's hard to believe it would flash green without a SIM card, as there is no service...unless AT&T is providing emergency service only and you're getting a flashing green which means you're in range of their towers.
Jun 14, 2008 | Palm Treo 650 Handheld
Help please
hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
Mar 17, 2008 | Palm Treo 650 Handheld
Resetting to Power Off
hi dear
Good luck
cropp
Mar 07, 2008 | Palm Treo 650 Handheld
Palm Treo 700w Smartphone Logo
85 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
