Question about LG WM-2277HW Front Load Washer
Leaking from the front of washer and moldy odor.
Washer just started with these two problems front is leaking from door and musty smell left on clothes after wash cycle.
  • 34 Answers
Guru - with all due respect - it's very uncommon for a boot to be torn. If there was a tear in the rubber you'd be able to see the hole. If you call for service the technician may come and simply twist the door to make the bottom make better contact against the gasket because liquid detergent changes the surface tension of water to cause easier leaking. Try using less detergent or switching to HE in powder form to see if you can stop the leaking. OR- intermittent leaking can be caused by a suds-lock forcing a little water out the stand-pipe. It is a good idea to start the washer with no clothing (in the washer) to see if suds form.
Musty smells are almost invariably caused by overuse of detergent or using fabric softener - at all. Go to www.smellywasher.com to read the blog page on what causes washing machine smell and towel mildew odor.
Paul Flynn / smellywasher.com
Posted on Dec 27, 2009
    Sergeant:
    Champion:
  • 262 Answers
You need to replace the front boot what a pain you may need a tech to do this also you need to keep door open and wipe the boot with a towel after each use this is a common problem with front loaders.I do warranty work and run across this problem alot
before you replace boot turn on washer with nothing in it and let it cycle if you see suds in water you are using to much soap and this will cause the machine to over fill check this first
Posted on Dec 02, 2007
My LG front loading washer smells like wet clothes that have been in the washer for months? Musty smell?washer overnight? Strong smell of musty old clothes
This is caused by the biomass built up inside the tub of the machine. This can also be caused by a moldy door boot. You need to scrub your door boot between the tub and the door. Water settles in the bottom of it and molds. Once you clean this, order affresh washer cleaner for your machine. This kills all the biomass built up in the tub and removes the smell. You will put all three tablets in the drum and run on the longest hottest wash available. When this is completed your machine should smell much better. To keep this from getting so bad again... Keep the washer door cracked open between cycles. This keeps the inside from smelling. Hope this helps
Apr 04, 2012 | LG WM-2277HW Front Load Washer
Why does My washer have a moldy musty smell?
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Apr 30, 2011 | Asko W6021 Front Load Washer
How to get rid moldy smell in LG Front loader washmachine?
There are several cleaners for front loading washers on the market, such as affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, and tide washer cleaner. Clean out the filter located behind the access door at the lower left front of the machine, then, if your model has a tub clean setting, use that with one of those cleaners, if not, use one of those cleaners with the longest, hottest cycle. If things were very bad, you may have to clean it twice. Now, after it is cleaned out,.....STOP USING SO MUCH SOAP ! Use only one tablespoon of HE laudry detergent per cycle, and only one teaspoon of fabric softener if you use that. (Note: Bath towels, used only to wipe off clean bodies, then tossed into the laundry are not dirty enough to require soap usage, and should never have softener used on them) The odors in your washer are caused by a build up of soap and fabric softeners on the inside of the washer's drum. Also, you may have a build up of soap or fabric softener on your clothes. Wash them again once with no soap or fab softener to rinse them out.
Mar 17, 2010 | LG WM-2277HW Front Load Washer
I have always had a smell coming from my duet washer. I put bleach in and run it through a rinse cycle, but it always comes back
there may be some dirt or other things collecting in the drain boot attatch to the drain pump there is usually a plastic coin trap located inside the rubber boot his will cause a musty smell in the washer.as well as a moldy door boot seal.if the door boot is moldy it needs to be replaced.
Jan 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The machine smells moldy...
moldy smell, may not be mold at all, in fact most "moldy musty" smells actually come from user not using proper detergents, you NEED to be using an HE detergent and little amounts of that even. cut back on fabric \softneer if using, www.affresh.com new product to help alleviate this issue
Nov 29, 2008 | Frigidaire Affinity ATF7000E Front Load...
Moldy smell in front load kenmore washer
forget the vinegar, theres a product www.affresh.com this will help. you also MUST USE HE( high efficency) DETERGENt. reccomneded amount is 2-3 tablespoons. regular detergent, and too much fabric softener is possibly adding to the moldy/musty smell..
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I had the same problem. Have you cleaned the filter under the front panel? Simply remove the three screws holding the panel below the door and remove the 2" white screwcap. Be sure to have a basin handy to catch the water. (possibly a couple of gallons if the stainer is really clogged) I suspect you'll find several moldy items that are causing the odor. Good luck.
Feb 28, 2008 | GE WSXH208A Front Load Washer
Bad Musty Moldy Odor in Washer
Run a wash on the highest temperature, and add some vinegar into it. May do this more than one time. Be strict to wash on the higest temp some times in the month.
Good Luck
Jan 24, 2008 | Siemens WFXD8400UC Front Load Washer
LG WM-2277HW Front Load Washer Logo
239 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
