Hi, you shouldn't need to change the tension on your machine. But it's always a good idea to make sure it is set correctly. Look in your manual for the recommended tension setting, and make sure that is where your tension is set. If you don't have a manual, the default tension setting for most machines is between 4 and 6.
If you are suddenly getting loops when you sew your seams, it is usually caused by one of three simple problems. The most common is that your machine is not threaded properly.
But, when your sewing machine suddenly goes "wonky" - try these step
- Raise your presser foot and rethread your machine. Always remember to raise the presser foot when you thread your machine! When you raise your presser foot, the tension dials are released; when you lower the presser foot, the tension dials close around your thread. If you happened to leave your presser foot up when you finished sewing yesterday, the thread could have slipped out of the tension dials, so when you started sewing today, you got loops. And, sometimes, your sewing thread can shift out of position along the thread path and you can't see it. Trust me on this - I often need to rethread while I'm sewing, and I have an expensive machine! If your machine is new to you, it is always a good idea to refer to your manual the first few times you thread up - it is really easy to miss little things, even for advanced sewers.
- If you are still getting loops after rethreading your machine, remove your bobbin and reinsert it. Make sure you know which way your bobbin need to be inserted. After you re-insert your bobbin, sew another sample seam. If you are still getting loops...rewind your bobbin (you can put your bobbin where you normally put your sewing thread and wind the bobbin thread onto a new bobbin). Never wind more than one color on a single bobbin. When you look at the thread in the bobbin, it should be straight a tight. Yesterday, I wound a bobbin, and the thread was kind of wavy and loose. Don't know why, but it happens.
- Change your needle.
- Check your manual - most manuals have troubleshooting tips in the last chapter. If you don't have a manual for your machine, search on google. You might be able to find one online.
- If your machine is new, try calling the manufacturer or check their web site. They might have troubleshooting techniques specific to your machine.
If this doesn't help, please write again and describe your problem in more detail. Did you buy a used machine? Do you have your manual? Did you start a new project or continue working on the project you started when the machine was working correctly? Hope this helps! Ginny
brand and model
What is the model number?
BERNINA ARTISTA 180
