Question about Rainbow E series Canister Wet/Dry Vacuum
The water swirts ou put the vacuum does not pick up the water
The water skwirts out on the carpet but does not pick up the water. the clear tubes seem to be connected right. there is nothing to put in the hole that sucks in.
  • 3 Answers
Re: the water swirts ou put the vacuum does not pick up...
Make sure that you are using the wet hose and that it's not clog and hooked up tight to the hole in the front of the vacuum.The same place that you would hook it up to vacuum.
Posted on Feb 13, 2008
0 characters
3 Points
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
Rapide XL. Why isn't it sucking up the dirty water?
you need to set it lower for water
Aug 10, 2015 | Vax Vacuums
My Hoover vacuum cleaner is not picking up from the carpet like it used to. Like it's having difficulty picking up strings, fuzz, etc. from the carpet. Suction power seems to be fine. The belt and the...
Jan 16, 2011 | Hoover Vacuums
Vacuum not picking up much but the hose attachment has no problem
I assume you've checked for blockages and that there's a useful length of bristles on the brush roll. Turn the machine over, and just behind the brush you will see a short length of clear plastic tubing with spiral reinforcing. That tube often splits, so there's an air leak and consequent loss of suction at the brush. A split may not be immediately obvious - to get the tube off, pull it off from the motor end and then unscrew it at the brush end. As a temporary measure you can cover a split with tape, but the tube undergoes so much flexing that tape is rarely effective for very long. A new hose (it's called the internal hose) is not expensive and is the only permanent solution.
If the internal hose is not split, post a reply here and we'll see what else we can think of. Good luck!
Jun 05, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My steamvac will not **** in it just blows air out and does not pick up the water solution once it has been sprayed on the carpet.
I finally remedied this "no suction" problem with mine. At front of recovery tank is a plastic panel that can slide up and down. Make sure that front panel is pushed COMPLETELY down when cleaning floors.
Dec 31, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Water is not dispensing to clean carpet. Water
the problem is the heater is cloged you can drill it out to clean it
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
How do you attach the upholstry attachment to your hoover steamvac
The hose hooks into the dirt bucket on the front where a clear plastic block sets. Put the hose in that slot and then hook the tube for the water at the top of the hood.
Nov 27, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
My hoover steam cleaner will not pick up the water the machine pu
Two checks:
(1) Is the lid aligned and sealed to the recovery tank
(2) Is the round rubber gasket installed on the tubular post under the hood, where the tank seals to the base? The tube extending down from the tank must sit on the rubber seal to get vacuum from the motor.
Sep 29, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Cleaner was working fine. Emptied the recovery
yes please help0. my carpet is soaked and the machine will not **** up the water
Jul 03, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Doesn't pick up water
Is the vacuum motor running? Are the pathways from the floor tool to the recovery tank clean and clear?
Jun 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Rainbow E series Canister Wet/Dry Vacuum Logo
240 people viewed this question
Top Rainbow Vacuums Experts
Roger Potts
Jim Parker
Jim Parker
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
