Question about Hoover H2800 Stick Wet/Dry Vacuum
Hoover will not release water/solution
I took the unit a part and cleaned everything. I also ran pressure water through the hosing. No clogs, everything snapped in correctly. No what?
    President:
  • 1,673 Answers
Maybe the reservior asm(#24). isn't working, when you push the trigger, it pushes a rod inside the handle to hit the reservior asm. so the water will release. Could be the rod isn't hitting the reservior asm. Maybe these pictures will help.
Hoover will not release water/solution - 7979241.jpg
Posted on Feb 22, 2008
Hoover vacuum shuts off minutes
Check your bag or collection area and see if it is full or clogged.
low air flow may cause extra heat and temp override.
see if hose is clogged you can place hose over exhaust and feel air pressure.
a visual for hose if clogged would be that hose will bunch up.
Sep 30, 2016 | Hoover Vacuums
Beater brush stuck on (keeps turning) in upright position and no hose suction with Hoover U5753-900 WindTunnel Bagless Upright Vacuum. I have tried adjusting the brush level up and down and moving the...
HI, it's Jim from Crucial Vacuum!
Your Hoover may be losing suction in the hose and having an issue with the brush roll due to a clog within the vacuum, or possible debris stuck on the brush roll itself. Here's some tips that will help.
First off, if your brush roll just keeps turning be sure to turn off your vacuum before examining it. In regards to the lack of suction in the hose there may be a clog in the vacuum itself.
After every use, make sure to empty your unit's dust cup. Allowing for fine dust and debris to rest in your unit's dust cup for a long period may cause your unit to become clogged, which leads to poor or even no suction, for the hose as well.
It is recommended to wash and clean your unit's filter weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours. Be sure to allow it to FULLY dry.
Lets look at the hose itself. Stretch the hose out entirely to see if there are any clogs within. A handy way to unclog your hose is to use a broom handle or coat hanger. Make sure the coat hanger is a plastic one. You don't want to tear the walls of your hose.
As for the brush roll itself. Is the belt intact? After usage the belt will stretch out and lessen the tension on the brush roll. This could be causing the brush roll to have a lack of resistance against it. You want to be sure the belt is on there nice and tight. Also, manually spin the brush roll to see if there are any clogs or debris stuck within.
You can purchase replacement parts for your Hoover direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover+windtunnel&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Dec 14, 2014 | Vacuums
My Hoover upright U5472-900 runs but there is no suction at all. I have taken it apart and thoroughly cleaned it.
Turn it on. Detatch the cleaning tools handle from it's mount. If it still has no suction, you have a plugged hose. Everything your vacuum does goes through that long hose. Take the 2 screws off where it attacvhes to the unit, then gently push a broom handle through it to release/loosen the clog. You should be able to see through the hose from end to end. Toys, tissue and pine needles are big culprets of clogged hoses.
Aug 31, 2011 | Hoover U5472-900 Upright Vacuum
Vaccum seems to cut off after short use like its hot,,once it cools off i can use again
Check filter. Clean if needed. The filter should be cleaned when it appears dirty. Simply remove filter, rinse thoroughly under warm running water until clear, then allow to thoroughly air dry. The drying is very important. Additional filter cleaning instructions are on page 13 of the manual.
Check the pleated exhaust (HEPA) filter. If dirty, cleaning is necessary. Instructions for removal and cleaning are on page 14 of the manual.
Check hose, wands, and power nozzle for blockages.
Hose: detach at both ends. The ends of the hose are the most common areas for a blockage. Check visually and clear as much as possible if present. If not visible, hold one end up and drop a coin in. Lift the end until the coin falls through. If it doesn't, there's a clog.
The easiest way to unclog a hose is to use an air pressure hose, or a canister vacuum that has an exhaust blower that the hose can be held too. If enough pressure, it will blow the dirt out. Make sure to put a plastic bag around the loose end to hold the dirt.
Visually check wands and power nozzle. The bend in the power nozzle connection is another common place for clogs. A wooden spoon handle, or similar blunt object, can be used to push the debris back toward the brush to clear a blockage here.
If none of these are the problem, contact a vacuum service center, preferably Hoover, for assistance.
Manual:
http://www.hoover.com/pdfs/manuals/S3865.pdf
Thank you for providing the brand and model info. It helps a lot.
Mar 05, 2011 | Hoover Platinum Cyclonic Bagless Canister...
The hoover steam vac 5 brush agitator dispenses water and soap but does not show any return water to dirty water reservoir. The carpet seems damp but not soaked, still a bit troubling no waste water...what...
You do not have the needed vacuum on the dirty water intake. Possible causes are:
1. No adapter sleeve in the back of the dirty water tank (the one that you remove to put the fabric hose adapter in)
2. The dirty water top is not sealed (cracked, not on correctly)
3. The intake shoot at the front of the unit is clogged with dirt/hair.
REMEMBER: This is NOT a vacuum cleaner - it is not designed to remove hair and dust.... ONLY wet dirt. If you fail to vacuum floors just before steam cleaning, the unit will clog up in minutes!!
Nov 24, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hose that releases the water and cleaner on my Hoover is clogged
Your right the hose is clogged.. Use a portable vacuum to blow the dirt inside the hose.
Jul 24, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover F6212-900
Press the handle release kick-button with your foot, extend the handle all of the way back, and take a look at the gap between the base of the unit and the handle/reseviour assembly. You should see several black hoses attached to the base and running up into the handle assembly. One of them (the dirty water return hose) might be cracked. Turns out that might be a common problem with this model. We had the same problem.
Judging by the interference between the vacuum hose and the "dirty water return" hose, there is NO WAY those two hoses can exist together in that housing without causing the dirty water return hose to stress. It certainly cannot last for many full bends of the handle.
We opted to not repair our unit, but you might be able to do it yourself for the cost of the part and several hours of your time. Otherwise, seek out your certified Hoover repair center for more info.
UPDATE: I McGuyverized it myself with a dremel cutoff tool, some vinyl tubing, some 2-part epoxy, and a lot of faith. It sure isn't pretty, but it sucks again. :)
May 30, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Constantly sprays water
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=515776&thid=544922
Posted by elstretcho on Apr 25, 2008
Hoover F7452-900 SteamVac Upright Vacuum
I noticed recently that our Hoover F7452 All Terrain constantly sprays water. As soon as I turn it on, whether or not it's set to Rinse or Auto-Rinse, its leaking water at the brushes. I probably wouldn't have noticed but I attached the hand-held adapter to clean our stairs and when I was done there was a HUGE pile of water under the vac. I took everything off and cleaned really good and looked again this morning and its still doing it. Any ideas?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You probably have a bad trigger release valve or a loose connection @ the bottom of the SteamVac or the gasket under the solution tank in not sitting on there right and is leaking or you may have a small cut in the hose, but it so may guess that it is a bad trigger release valve or a bad gasket. Check with your local vac dealer to see if they have a new or a good used one to see if there is the problem or back track the problem from the bottom to the solution tank. So If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 25, 2008 | Hoover F7452-900 SteamVac Upright Vacuum
Hoover eite rewind vacuum has blocked airflow, how do i fix?
Is there suction at the end of the hose, if not then the blockage is in the hose, unhook the hose and dig out the debris, if hose isn't blocked, then clean out the filters, if they get clogged, then air can;t flow thru them and you won't have suction. If you have suction at the end of the hose, then it is clogged down in the nozzle asm. there is an inlet by the brush roll and it comes up to where the hose plugs into. Clean the clog out.
Jan 03, 2008 | Hoover U5507900 Elite Rewind Bagless...
Hoover H2800 Stick Wet/Dry Vacuum Logo
74 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
