Question about Cuisinart DGB-500 Coffee Maker
Cuisinart DGB-500 Filter basket opens during brewing process
We have had the Cuisinart DGB-500 for less than one year and have been experiencing the same problem. On numerous occasions (i have lost track), the filter basket opens during the brewing process. Normally, we have the coffee maker programmed the night before. In the morning, not only do we not have fresh brewed coffee, we have a mess to clean up. Coffee spilled EVERYWHERE. We have changed the carafe, the basket, and the filter, but continue to experience the same problem
  • aymee Jan 05, 2008
    thought that may have been the problem; replaced the basket and filter mechanism. Problem continues.
Broken basket.
Posted on Jan 04, 2008
SOURCE:
How to fix the leak from the bottom of my cuisinart dgb-900bc
Re: Cuisinart grind and brew model DGB900BC leaking from the bottom. Finally fixed it before buying a new one. Remove the 4 torq screws (#10 bit check auto stores) from the bottom and remove the bottom. You will see a horse shoe shaped metal coil that heats the water from the resevoir. I found that the coil had a small hole in it. Cleaned it well and applied a coat of epoxy paste to the leaking area ( I used a product called PC11 from Ace) So far, no leaks, and the coffee maker is working like new.
Aug 10, 2012 | Cuisinart Dgb-900BC Grind & Brew Thermal...
Cuisinart DGB-900BC filter basket brew pause spring came out. How do I fix it?
You can push the soft rubber stop or valve back on the plunger stem with the flat side down. It can pull out if you are rough with it or if the plunger gets stuck in your dishes drip rack. But if it is torn you need to order a new basket because I don't think the parts are sold separately.
Jan 12, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Coffee Machine Brewing Water
Try an experiment - brew a test cup, but use only a small amount of grounds in the brew basket (use a paper filter) [or else, put the grounds in the gold tone filter basket]. See if the machine makes coffee (albeit weak coffee). If it does not make coffee, see if the water is draining properly from the brew basket, or if it is leaking over the sides of the brew basket. Also, make sure the lid to the brew basket is completely open and in the correct position.
If you still get water only in the caraffe, replace the brew basket. The part costs about $11.95 with shipping - or even call Cuisinart to see if your 3-year warranty will cover the issue.
-Tha Mp3 Doctor
Mar 03, 2009 | Cuisinart Thermal DGB-600 Grinder
Cuisinart DGB-300 coffee maker brew pause valve
No one has just the individual part, but you can get the whole brew basket with the part included on Cuinart's website, or by calling them.
Feb 03, 2009 | Cuisinart DCC-100 Coffee Maker
Cuisinart dgb-600 brew pause feature doesn't work
Replace the filter basket - they can be had for around $6.00 plus shipping - you can even get them directly from Cuisinart.
Jan 23, 2009 | Cuisinart DGB-600 Coffee Maker
Won't start
DGB-300 - continuously beeping indicates that something is out of place - either the grind basket isn't exactly in place, the filter basket is loose, the water filter holder is out of place, or the lid of the coffee maker is open.
-Tha Mp3 Doctor
Jun 23, 2008 | Cuisinart DGB-500 Coffee Maker
Filter Basket door sticking/ opening during brew
try this site [ nelson appliance dot com] they have parts for just about any kitchen appliance. they may have an exploded diagram for it or can steer you in the right direction for one. try the cuisinart site. cuisinart is in champlain ny.
Sep 04, 2007 | Cuisinart DGB-500 Coffee Maker
I just called Cuisinart and they will send me another brew basket for my DCC-100 (it has a Brew Pause valve also) for $9.14 (part + S&H). Did you try to contact Cuisinart?
Aug 30, 2007 | Cuisinart DGB-300 Coffee Maker
Cuisinart DGB-500 Coffee Maker Logo
363 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Pierre Laplante
Steve Allison
Steve Allison
Norman Worley
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
