i have a cs-800x that i used to DJ and i run 2 jbl tr225. i run 1 on the left channel and the other on the right. sometimes the left channel just goes out and i run both just fine on the left channel. the other day both channels went out ? no sound but powered on ? can you please help....
The CS800 designs have not changed mucch in the last 20+ years. There is a resistor inside that can fail that can cause this symptom. If you have not worked on these before, I'd suggest that you have this serviced. As it stands the parts cost should be in the $20 range. If the outputs have finally failed, the parts cost will go up significantly. WIthout taking measurements inside the unit, I can't say specifically what is wrong.
Why does my Peavey bandit 65 cut out when I increase the volume on the guitar and the reverb is...
(More)
Why does my Peavey bandit 65 cut out when I increase the volume on the guitar and the reverb is turned up
I have a technics amplifier model SU-G75, it will power on but it will not play any of the...
(More)
I have a technics amplifier model SU-G75, it will power on but it will not play any of the equipments that is attached to it
do you return the product that is under the replacement protection plan to walmart or manufacturer...
(More)
do you return the product that is under the replacement protection plan to walmart or manufacturer to be replaced?
