Question about Kenmore 22422 Top Load Washer
Kenmore model 11049182992 serial # ull4509224
All of a sudden it will not turn on? wall outlet is working what do i need to do
  • 32 Answers
Make sure you have a new fuse in your panel and you have the lid down on the washer also check the lid switch it may be broken
Posted on Dec 18, 2007
What can I do my dishwasher Kenmore model 665-13834K601 the Cancel and Normal wash lights are blinking and won't work
Try this, unplug it from wall outlet for one minuet to reset its processor. Then plug it back in to see if that worked.
Dec 03, 2014 | Kenmore Dishwashers
Why will it not come on?
The rust shouldn't make any difference.
When you plug it in, does the interior light turn on? If not, suspect the wall outlet - test it for power by plugging in something else. If the interior light turns on, listen very closely to the freezer. It should hum. If it doesn't, toy with the freezer control inside - it may just be turned off. Turn it to about midpoint and listen very closely to it again. If still no hum, wait a short while, then feel carefully on the outside of the cabinet - it may be running through a defrost cycle. The outside of the cabinet may get warm while that's happening, especially around the door gaskets. Wait a while (half an hour, an hour, for the defrost cycle to finish - the freezer should run then.
If it never hums, then the compressor isn't running, so adding freon won't make any difference. Instead, suspect the defrost timer - that's a little electronic circuit board inside.
If it HUMS but never gets COLD, then you potentially have a freon leakage problem. It's difficult at best, though, to refill a refrigerator or freezer - they don't usually have refill taps.
Oh, yes. If the internal light never comes on but you've proven that the wall outlet has power, it's entirely possible that the plug is bad and needs to be redone.
Jul 29, 2014 | Kenmore 12.1 cu. ft. Upright Freezer 2826
Laptop suddenly turn off
check ac adapter is working, try another wall outlet
try laptop with battery removed
Dec 26, 2013 | MSI Computers & Internet
My old Kenmore window unit has all of a sudden stopped working. Was working fine then just stopped coming on. The wall outlet checks out fine. Is there a re-set on the unit? What else can I check?
Hello, if the unit is receiving power check the capacitor, this is a round or oval can located inside the control panel of the Ac, it controls the fan and compressor operation.
May 23, 2012 | Kenmore Heating & Cooling
Ve a kenmore ac heat combo model # 58075184500 that the cord was pulled away from the outlet and melted both just slightly. I replaced the wall outlet but the unit seems to have low voltage to it. the fan...
Before doing anything elese I would replace that cord also... it may have damaged to cord too...
Make sure to get a heavy enough replacement cord so it does not burn up again...
heatman101
Dec 13, 2010 | Kenmore Room Air Conditioner
Microwave oven suddenly stopped working, no display,not outlet
Hi, you must check the inside fuse. If is burned out, please consider that something happened, you must check further beyond to find the causes.
Nov 13, 2017 | Kenmore Microwave Ovens
Wont work at all
Need to know the model number and serial number before I can assist you
Jan 09, 2008 | Maytag Atlantis MAV8000
Laptop won't turn on.
does it work when you plug it into the wall outlet. i need more info.
Dec 08, 2007 | Dell 2600 Notebook
Broken air conditioner?
Try another wall outlet. You may need an extenion cord.
Jun 25, 2007 | GE AGP07LH Air Conditioner
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
