Not too sure which guide you are refering too, the only keeper at the clutch is the anti rotation bracket for the clutch itself, it bolts to the side of the chassis and the other end sits into a cut a way in the side of the clutch assembly.
With the pto switch pulled out check with a multi meter that you have a 12 volt supply the the clutch, pull the connector apart at the clutch end to do this, if there is no supply it is a switch or wireing issue, if there is a supply, you shouls have an audible click when the pto switch is pulled out, this is the elecro magnetic clutch engaging, if the click is present, check the belt from the clutch to the deck.
i had a 2148. you remove the mower deck as the first step. feed the belt over the pulley on top the transmission, then put it over the engine pulley. then have someone push the clutch pedal in so the tensioner pulley moves, put the belt in the guide pulley and on the tensioner. release the clutch put the deck back on and you are good to go. notice there are little keepers welded to the frame for the front, engine, pulley and it is easy to mistakenly put the belt over them instead of under them.
a general rule is that a pulley shaped like a Vee takes the V of the belt whilst a pulley which is flat takes the flat back of the belt. if you bear that in mind you will not have a problem putting belts back on. also there is a little decal on top the deck showing how the deck belt and deck drive belt go.
Make sure you have the belt routed correctly. ALSO make sure that you do not have it flipped 180 deg over the idler.
I recommend that you unhook the belt from the mower deck pulleys and try rotating the blades. A bad blade bearing can cause a belt to heat up. Of any of the blades are hard to turn by hand that blade bearing will need to be replaced. Check the idler pulley also.
If after checking the above you continue to experience a problem just respond here and I will help you.
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
