Question about Thermador SEC272BPSS Electric Double Oven
Control Panel is cockeyed on right side.
Presumably, the plane of the face to the Control Panel should coincide with the plane of the oven doors. Maybe not. Maybe its face should be parallel to the plane of the doors but inset about 2MM.
From the side, the bottom right edge of my Control Panel jutted out about 2MM, giving a cockeyed appearance from the exposed side.
I removed the two sheet metal screws from underneath the Control Panel, slid the panel upwards, removed it and set it down on the top oven rack in order to evaluate a possible obstruction.
Now I would like to put the Control Panel back, but I can’t seem to catch the two tongues that secure the panel at the top. Do I have to pull out the oven to accomplish this? Or should there be enough room to maneuver the panel and catch those two tongues?
I just finish doing the same thing and you have to be carefull in putting back the panel the same way it was set, otherwise it will not work. Just do it carefully and you should be able to tell when is set in place correctly. Do not use force, since it was designed to be set in one position only before attaching the screws back in place. Good luck!
Posted on Apr 08, 2008
My cleaning lady wiped the control panel and now the controls are locked. How do I release them?
Hello DiAne;
You may try turning the power off to your oven at the circuit breaker for ten minutes and then turn the power back on. Hopefully this will reboot the control panel.
If not you must provide a model number which should be on a label on the face of the oven when you open the oven door or on the side of the oven door.
Mar 24, 2016 | Ovens
Oven all of a sudden stopped working. The clock face on the upper right hand side of control panel is illuminated and I'm not sure what this is for. Is it related? Do I buy a new oven, or try to fix?
Microwave ovens are not to be messed with. Get an approved Sanyo technician to replace the control panel or ASDA; 29 pounds to replace it.
Oct 22, 2014 | Ovens
Instructions to replace Jenn Air oven thermostat
To remove the control panel, open the oven door wide as possible. Remove the screws from the top of the CP and the screws from the bottom of the CP. Grasp the CP bu placing hands on the right and left sides of the panel, pull out and down to disengage. Depending on manufacture run you might need to lift up and out to diengage.
Have a cloth on the oven rack to lay the control on so you won't scratch the pretty facing. Once that is done you have easy access. Wear some rubber gloves doctor, this prevents harm to the electronics. Static discharge is a no no around expensive electronics. You can do this. Take your time. Piece of cake.
You will be able to check high limit cooling fan door latch and motors 9if applicable on your model) cool ain't it?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 07, 2010 | Ovens
My GE double oven JKP26GP broiler burned out (burned a hole right thru). The keypad immediately went blank and the keypad controlled top unit isn't working now (top unit only - bottom is fine). Will...
I'm afraid I don't know how to help you get a new control panel (part #WB36K5065 is no longer available). But we have the same oven and a similar problem. Our control panel works just fine, but the face is melted from a recent mishap (small fire in the upper oven while broiling), so the plastic face of the control panel looks awful and needs replacing. If you decide to replace your oven and would like to sell the front face to your control panel we'd love to purchase from you.
Nov 21, 2009 | GE Ovens
Control panel buttons due not work
It is the whole front face w/ the buttons. My whole neigborhood has these ovens (same builder, same ovens) and this part lasts about 2-4 years. The part is about $165. You can see it on Home Depot's appliance repair site. It looks like there is nothing electronic, but there is, and it's busted. It is really easy to replace:
1. Turn off the breaker at your house's breaker panel.
2. Verify there is no power to the oven.
3. Open the oven door. Look on the right and left side of the oven. There should be 4-6 screws going from vertical trim pieces of the oven into your cabinets. Your builder may have also put screws from the bottom trim of the oven into your cabinets. Mine did not. Remove these screws.
4. After that, your oven should slide forward out of the cabinet. Pull it about 6 inches out.
5. There are two screws (1/4 inch hex headed screws) holding the front panel to the oven. Remove those.
6.Slide the front panel off.
7. Remove the computer ribbon looking wire from the back of the control panel. It's a strange connection - it should come out effortlessly when done right. The little grey connection that surrounds the wire's entry point stays on the panel, but a wedge is jammed between the grey surround and the wire. You pull the wedge out and the wire comes out...easier than my credit card out of my wallet.
8. Remove the four screws (again, 1/4 inch hex headed screws) connecting the thick, double layered circuit board and clock display from the metal face.
9. The metal face is what you need to replace. Pasted onto the front of the metal face is a super thin button panel, and that's the part that died, and will die again, and again, and again...
email me for pics schmidtkeith1@yahoo.com
Aug 31, 2009 | Maytag 30" Built-In Single Electric Wall...
Built-In Oven Buttons Stop Working
Email me for some pictures:
Aug 02, 2009 | Maytag 30" Built-In Single Electric Wall...
Front big burner not working
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
Jul 10, 2009 | GE Profile JSP47 Electric Single Oven
GE Double Oven doors locked and circuit not responding
Hi, well this is a brain tester!! I think you need really to look at this in a simple way. Check to see where the door lock wires come from first? Find where the mains power comes into? then if it goes directly to the main control board then check to see if there is any power getting through the board to the otherside where the wires disapear into the cooker. I would consider checking the control board for any signs of burn damage and then look at the clock unit to as these are normally the main components in the cooker that will stop it from working.
Good luck,,,,,,,,,,,,,,,
Jan 02, 2009 | GE Profile JTP56 Electric Double Oven
Control Panel
Yes actually i do..... open the lower oven door next to the hinges are 2 small phillips screws, securing two long metal side trim pieces. remove trim. Exposes two more phillips screws Control lifts up and off then Make sure unit has been powered down !!!!!!!!! If the old control is totally blank there is a thermal fuse that has gotten too hot. PLEASE rate my solution...Thank you
Oct 02, 2007 | Whirlpool RBD245PDS Electric Double Oven
No heat or rotate
did you check the door switches?
Aug 18, 2007 | GE JKP85 Electric Double Oven
Thermador SEC272BPSS Electric Double Oven Logo
Top Thermador Ovens Experts
goober123
Level 1 Expert
Oloyede Monsuru
Marvin
Marvin
Are you a Thermador Oven Expert? Answer questions, earn points and help others
