Keurig B60 Coffee Maker
Problem for Keurig B60 Coffee Maker
Water leaking out the bottom
By ksnpjt on Aug 19, 2009
As soon as I push the button, after it says ready to brew, the water pours out the bottom of the machine. It won't even come up to the pod. I've opened the bottom, and all the pipes are connected.
Solution #1
posted on Aug 20, 2009
Not Rated)
HIRAM517
Rank: Wiz
Rating: 79%, 24 votes
CHECK THE SEAL WATER TANK ON TOP
Comments:
Aug 20, 2009
- HEATER IN TANK NOT GETTING ENOUGH VOLTAGE, THAT CAUSE THE UNIT TO HEAT VERY LOW. THE WATER SHOULD BE @ LEAST 190-200 DEG F. IF YOU KNOW BASISC ELECTRICITY CHECK FOR HOW MANY WATTS ,CURRENT. ALSO CHECK IF HEATER IS SHORTINGOUT
Was this helpful?
Yes
No
Popular Solutions for Keurig B60 Coffee Maker
Questions and Unsolved Problems for Keurig B60 Coffee Maker
Do you recommend Keurig B60 Coffee Maker?
Answer
Answer
the water will not drain from the holding chamber. The pump will run until after awhile it shuts off... (More)
Answer
when trying to brew a cup of coffee it drips slow like it is clogged
Answer
my machine will not stop blinking the not ready to brew and nothing else works no buttons work no... (More)
Answer
My coffee maker just today started making a loud sounds when heating up the water and when... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repairmen
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
