Question about Refrigerators
Our fridge does not make ice - Whirlpool Gold side-by-side GS5SHAXNT00
Our fridge stopped making ice a few weeks ago; we did not notice until last week when we emtyed the ice bucket - it was 1/2 full; after that it was no ice and we could not hear the water running into the ice-making-chamber - we usually could hear when it was running.
We checked the water filter, we checked the switch on the right side - it is on; the temp is '4'; the water from the dispenser is coming - what could be the problem? thanks, Zam Oyvetsky.
our email : [email protected]
  • 12 more comments
  • Anonymous Dec 23, 2007
    almost exactly the same problem-we emptied the ice container on the door and replaced it and the refridgerator has stopped making ice. The switch is on, the water is hooked up and the freezer is cold.
    Stacey
  • clayg Jan 31, 2008
    I have same fridge and exact same problem. Any one figure out what is wrong?
  • Anonymous Apr 14, 2008
    Same deal, water through the door works but ice maker doesn't make ice. Anyone got a clue?
  • jecha May 23, 2008
    Had ice, and now the filter is good, water goes in auto ice tray, but nothing come out now,.  and today, the light for the fridge side went out, and went to replace and notised the number control for the fridge & freezer are blank.  Fridge &  Freezer are cold, but no light on fridge & no lited display working
  • Anonymous Jun 02, 2008
    Have defrost the refregarator by power it off for 12 hours, turn it back ON; however, it's not making an ice though...
    Advice....
    [email protected]
  • Anonymous Jun 04, 2008
    My Whirlpool Gold is not making ice either and everything is hooked up correctly and turned on-water dispenser works but no ice. Very frustrating! Not happy at all with this Whirlpool. Also, the water dispenser leaks a few drops after dispensing and have flushed the lines repeatedly-there is no air in them.
  • Anonymous Aug 17, 2008
    water dispenses from the door but the ice maker quit making ice.
  • Anonymous Aug 20, 2008
    Exactly the same problem.
  • Anonymous Aug 28, 2008
    I have exactly the same problem. It just stopped making ice for no apparent reason at all.
  • Anonymous Sep 05, 2008
    No ice is being made. Infa red is in on position, but how do I know if it is actually communicating as it should be? No ice is being made, however, water is coming out without a problem. Is there anythig I can check before having it serviced?
  • Anonymous Sep 13, 2008
    mine stopped working t oo does anyone help on this website?
  • grackler Oct 12, 2008
    same problem. Whirlpool Gold side-by-side. Stopped making ice. replaced water filter to see if that would fix. everything else seems to be fine, but still no ice.
  • clevelandolt Apr 07, 2009
    One day making ice perfectly, next thing I know there is no ice being made. Can anyone tell me what is going on?
    Mary
  • Anonymous May 21, 2009
    Exact same problem.
Same as others. Whirlpool Gold side-by-side. Water was running yesterday but minimal ice. Now that's gone and I don't even hear the water. Turned on/off the infrared sensor. Still get drinking water, just no ice in the bin. There's a couple cubes in the maker itself when I open the door (which I've closed completely). Help?
Posted on Aug 04, 2008
I'm having the exact same problem with the same brand of refridgerator. Has ANYONE found a solution?
Posted on Sep 03, 2008
Same problem. Whirlpool Gold side-by-side. The other day there was minimal ice and I heard the water fill for ice. Nothing falls into tray. I turned off infrared and turned back on. Nada but I can get water, just no ice. Help?
  • daysjay Feb 05, 2013
    Hi, did you ever get this fixed? i am having the same issue! grrrr
SOURCE:
8 year old Whirlpool Gold refrigerator: Freezer icing up. Found ice on shelves and on the bottom under the vegetable hydrators. The shelves and drawers constantly have a humid film on them. Last week,...
for no frost type;cleaning of freezer cub underneat is a must...cloggged drain outlet buildup thick frost on your freezer cub..
.ie..for frost type;you must set your thermostat setting to normal,replace it with new one
Oct 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
98978yi
May 10, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Defrosts/refreezes
IF YOU TAKE THE BACK PANEL OFF INSIDE THE FREEZER YOU WILL FIND A PIECE OF METAL UNDER THE EVAPORATOR COILS IN MIDDLE OF THIS METAL PAN IS A HOLE THAT LEADS THE WATER TO THE BOTTOM OF THE REF FOR EVAPORATION THE HOLE IN THE PAN IS PROBABLY PLUGGED TAKE THE ICE OUT AND CLEAR THER HOLE
Aug 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold makes banging noise
If the refrigerator is working fine the banging noise you hear is the isulation inside the refrigeratior walls that exand and cotract with the change of temperatures. you don t have to worried about it.
Apr 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool sidebyside FF stopped working after ? motor stopped ...
this refrigertor is leaking refridgent gas it needs checked by an engineer
Feb 15, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Whirpool gold
I did some research online, and read that the Start Relay is most commonly the problem. My husband bought the part, (about $50) and reattached it to the side of the compressor....and was cold immediately! apparently a very common problem on these fridges.
Jan 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Ice Maker Quit Working
IF THE FRIDGE IS COOLING AND FREEZING WITHOUT AND HASSLE THEN YOU DONT HAVE A PROBLEM WITH YOUR CONTROL BOARDS.ALSO IF THE WATER IS STILL COMING OUT THE WATER SIDE OF IT.YOU NEED TO LOCATE THE WATER VALVE AND CHECK IF THE VALVE TO THE ICE MAKER IS NOT BLOWN THAT MIGHT BE THE CAUSE OF THE FRIDGE NOT MAKING ICE.
GOOD LUCK.
MOHAMED
Sep 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker is not working
hi. thanks for the question. because the door was left open . moisture got into the small tube that lets water in to the ice maker.. and froze. use hair dryer to thaw the tube. remove and clean. thanks the appliance doc. please rate me
Sep 11, 2008 | Whirlpool GD2SHGX Refrigerator
Can you lower the ice maker temp on that model.
Thanks J
Jan 05, 2008 | Freezers
Refrigerators Logo
3,318 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
