Question about GE Profile Spectra JGBP90 Gas Kitchen Range
F-1? I am suddenly getting an error "F-1" with constant beeps, for no reason the oven is not even on. Ideas? getting an error "f7" with constact beep
  • 22 Answers
There are generally three reasons for this. 1. The oven latch may have been moved, even slightly from the locked position. Check to see if it is stuck and not moved all the way to the right. The mechanism may be clogged due to grease, or other foreign matter. 2. You have an error code. Touch the Clear/Off pad. 3. Disconnect all power to the range and wait 5 minutes. Then reconnect the power. If that does work, call an authorized GE service  company for repairs.
Posted on Dec 03, 2007
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
My Kenmore wall oven has a code F7 and is constantly beeping. What does this indicate?
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 11, 2011 | Kenmore Ovens
I am getting an F7 error signal and a constant beeping that will not go off no matter what I do. I even turned the circuit breaker off ... but the beeping and error signal persists. What should I do?
Hello there
Normally when you have this errr code it isreferring to the keypad or touch pad that is failing or has failed and needs to be replaced
Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button
Jun 05, 2010 | Ovens
JKP15 Electric Single Oven: Oven keeps beeping with F7 error...
F5 Loss of relay drive circuit If this fault code cannot be cancelled, replace the oven control (also called clock or ERC).
May 07, 2010 | GE JKP15 Electric Single Oven
Constant beeping and F7 is displayed
Hi tahitian,
The error code F7 means that the Function key is shorted or stuck. To fix this error, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Dec 16, 2008 | Magic Chef 31000 Gas Kitchen Range
The lcd scrren on my range displays F7 in red and flashes d6 in g
The code is because of bad keypad/the control panel.Have it changed.It probably non-functional and constant beeping sound is followed as you mentioned.Theres a link to explain more about this for reference.The only solution is to replace the control panel.
http://www.askgene.com/2007/06/23/oven-error-codes/ge-oven-error-code-f7-and-how-to-fix-it/
Dec 13, 2008 | GE Spectra JBP78 Electric Kitchen Range
F7 error steady beeping
short inthe key pad, thinks a button is being preesed for an extended period of time youll need to replace the keypad/ electronic control
Nov 17, 2008 | GE JKP45 Electric Double Oven
Oven error code
See my solution to OVENMAN/April 12, 2007. I have supplied my fix to over 650 individuals and have had a high reported success rate.
Mar 29, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
151 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
