Question about Acer AL1715 (Black, Silver) 17" LCD Monitor
Acer Am I not able to get the piece of equipment myself and then pass it onto someone I know who has this type of knowledge and can do it for me.
Cant connect monitor to emachine computer
Posted on Dec 10, 2007
I have an Acer extensa 5220. When it was set up, "someone" segregated the main hard drive, and put a password onto it. This drive has never been used, and I am running out of memory to update programm
If you mean someone made an additional partition or two, you can start typing "create and format hard disk partitions" and click on it.(Assuming Windows 10) Depending on several things, it should allow you to delete the unused partition and "grow" your current partition.
Dec 24, 2017 | Computers & Internet
I have a 1990 ford f150 with 302 that will cutout that it will run good It will drive along fine, sometimes for 2 days without this problem, and then... Starts all over again. Sometimes it will continue...
My guess is a failing fuel pump but there are a lot of things that will cause a similar problem. It really needs a bit of test equipment connected up when the problem happens. A pressure gauge in the fuel line where you can see it while driving will show if the pressure drops the same time as the engine fails. You need someone who knows what they are doing to T piece a pressure gauge into the injector supply line, a fuel leak could well start a fire so not something for someone without the required knowledge and experience to mess with.
Hope that elps
Terry
Nov 25, 2012 | Cars & Trucks
I need to replace the clutch in my 1998 Toyota Corolla, Should I pay for someone to do this or is it easier to do it myself. How would I change this out myself?
Pay someone. This is a difficult job that should take a trained technician in a well equipped shop 5-6 hours to complete. That does not include having the flywheel resurfaced. Unless you are very organized, have adequate tools, torque specs, knowledge of what parts to replace and inspect while in there, and what not to destroy when removing the transmission and what to replace when putting it back together, you might get in over your head rather quickly. I am not out to doubt anyone's ability but this is not a as simple as an oil change or a brake job that even a novice can perform in a driveway unless you are 100% positive you are up to the task of removing the transmission, properly replacing the clutch and reinstalling the transmission I advise you not to open that can of worms until you are better trained. There are a ton of snags that you can and will run into during this job and you will need to know what to do. You can't get everything from a manual or how-to book.
Good luck.
Oct 02, 2010 | 1998 Toyota Corolla
Can i fix the electric power steering myself on my '03 saturn ion? the power steering light hasn't gone on yet, but when i turn the wheel, it makes a sound. if it wasnt electric, i would add the power...
That system is better left to someone with knowledge and experience with it...after all if it is messed up its the streering that wont work, and your life may depend on it
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Jan 12, 2010 | 2004 Saturn ION
Why is my acer constantly stalling? When typing
sounds like your processor is busy doing other things could be a number of things too many to suggest i would recommend using "tuneup utilities 2009" there is a 30 day free trial brilliant piece of software i use it myself and it keeps my pc tip top it has many suggestions for speeding up your pc and keeping it secure.hope this helps
www.tune-up.com/download/
Oct 31, 2009 | Acer Aspire One PC Notebook
ARE YOU AWARE OF ANY PROBLEMS WITH THIS MODEL? Acer 3300
Ive been down the acer road myself, i had nothing but problem, and i know people that have laptops,desktops. all having problems. Actually i know someone with that same model , they said the first month was good.. then things started going downhill. My opinion would be keep your money. 2 of my top trusted companies are toshiba and hp. 2 that i personally hate are acer and dell.
Sep 30, 2009 | Acer Computers & Internet
Error - server not found
maybe u need to ping ur internet address with command prompt. the way to know ur email address :
1. enter ur commad promp then type ipconfig, the first address under ur DNS is ur address
2. type "pingADDRESS(internet address)
Sep 07, 2009 | Computers & Internet
Car doesn't move in reverse or neutral.
It may be in the linkage that runs from the gear shifter to the gearbox, could be a simple thing, if you have someone under the car while you try to move the gears you may be able to pinpoint the problem.
Make sure the wheels are chocked and the engine is off before letting someone under the car.
I would not think the fine screen inside the gearbox would allow a big enough piece of metal to pass into the valve body etc to cause this problem.
hope this has helped
May 27, 2009 | 1994 Chevrolet Camaro
Tomtom go 300
Its likely to have blown IC's 24 , 25 and also sometimes possibly 26. You might also have blown the reverse polarity protection diode. Tomtoms damaged this way require a specialist repairer as the solder joint are much too small for the average electronics guy to solder. If you have no knowledge of this type of soldering or if you have not got the special soldering equipment then it will have to go to someone who has repaired these before or go back to TomTom for repair.
Jan 20, 2008 | Tomtom GO 300 GPS Receiver
Acer AL1715 (Black, Silver) 17" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
