Question about Compaq 242695-001 8-port KVM Switch
Compaq 4110 KVM - reset Password
How can i reset the Password in Compaq 4110 KVM
  • 4 Answers
Small hole in back stick a paper clip in it and while pressing button power on and hold foe 30sec this should do it
Posted on Dec 20, 2007
Reset password log in KVM SwitchView1000
This is the reset process for the SV1000 password. Enter all 0s in the password field, without pressing the Enter key and use a small pin to press and hold the reset button for 3 seconds or so that is located in the back of the sv1000 switch next to the power adapter#s connector. This process does not require the user to turn off the power for sv1000 and its connected target PCs.
#TreasureIt... It doesn't come easy.
Nov 28, 2013 | Avocent SwitchView 1000 - KVM switch -...
How do I reset the password on my Avocent AutoView® 2015 KVM Switch
I believe there is a reset button somewhere on that unit that you can press to just do a quick reset of it. If you hold that button down, you should be able to reset the settings on it, including your password. Hope this helps.
I hope this helps you.
Oct 14, 2009 | Avocent AutoView® 2015 (AV2015-001) KVM...
Compaq 8 port kvm switch
You Compaq unit is proabably a rebadged Avocent like my HP Analogue KVM. To open the menu on that, you simply press the Print Screen button to open the onscreen menu.
Hope this helps.
Mar 27, 2009 | Compaq Computers & Internet
Reset the password to default on an edimax ek16ro Need to reset the password on the KVM,
According to the user manual, the device needs to be sent in. The user manual can be found at:
http://www.edimax.com/images/Image/manual/KVM/EK-08-16RO/EK-08_16RO_M.pdf
  • Note: If you are not familiar with the operation of OSD menu, please don’t change the password – i.e. keep default eight zero (00000000) value.
  • Otherwise, if you have set the password and unfortunately forget the password, you need send it back to your distributor for resetting the password.
Jan 27, 2009 | IBM NetBAY 09N4291 8-port KVM Switch
KVM Switch 4110 8 port
so is the KVM (control side, PS2 mouse / kbd>??)
or are all PS2 ports wired to adaptors,? i cant guess this nor what was used before, no history stated.
what was there before, this act?
and what now?
Ill assume worse cases (tossed a coin)
18 (16+2) adapters now. all devices are USB but KVM
ok.?
what mode fails, both the KVM pushbotton switch and or the hot key commands on the kbd?
Oops no manual button as seen on modern KVM.
KVMs are very complex. the hard part is the vast number of different PC.
USB , PS2, VGA, DVI and HDMI.. yah,..
OK 16 +2=18 x ps2, and 9 VGA ports. it is.
NO KVM does it all, ,, old KVM' do NOT work , on new computers, all folks know this , if they tried. or took readings to learn why it fails.
I bet power to the KVM is dead., no LED./
no manual button ,oops.
pin 4 PS2 reads 5vdc and connected up, same?
we use breakout boxes (DIY) to test ports connected.'
that Compaq is very old and no support now, no books.
why not ask at real HP, maybe some old guy there can dig it lost books>
40 KVM? that what you said, really? (or 40/8=5 kvm)?
my guess is the adaptor does not work or power issues
KVM >>PS2>>>ADapt>>> USB.(server) (usb 1,2,or 3 at server?)
The KVM in most cases, here, steals power from PS2 ports but not this KVM , its better.
i'd bet that adaptor cant do that.
(is the caps lock key working on the KBD and laser LED glowing on said mouse?
ask here, real HP.
lets see tests:
1: pin 4 ps2 5vdc?
2: mouse glows?
3: keyboard led , caps lock toggles? (glows)
4: lost the hot key commands (y/n)
one other problem is the BIOS in the server may not like your adaptor at all. When BIOS scans the keyboard. it expects a ID response if missing or grabled, it drops that device port.
https://h30434.www3.hp.com/
btw, one way to cure this, is run headless server software
end KVM for ever.
i run a LAMP server, that comes in the box, no kvm no any thing on ports. it has a web page to go to and do service that way.
port IP+:12321
modern ways work best.
in a server farm, a keyboard/mouse/monitor on rolling cart
for the super sick servers is best...
the other problem is USB only PC or server
does not scan PS2 ports, it has none
so if the adaption fails, at boot time, all is lost.
(BIOS reports connected devices to the OS)(unstated by you)so if the report fails, problems happen
for sure after the boot.
this device is s business device, now ("Enterprise)
the posts on it are like 10 years ago. all links to books now dead.
infact the compaq server that had them is turned off. (grin)
here is my search there. Why not ask them?
https://www.hpe.com/us/en/search-results.html?client=&qt=kvm+4110&search=%EF%98%90&cc=us&charset=utf-8&hpa=http%3A%2F%2Fwww8.hp.com%2Fus%2Fen%2Fhpe%2Fcontact%2Fcontact.html&hpn=Home&hpr=http%3A%2F%2Fh41131.www4.hp.com%2Fus%2Fen&hps=Home&lang=en&qp=url%3Ah41131.www4.hp.com%2Fus%2Fen+url%3ANEW+URL+GOES+HERE
Aug 26, 2017 | Compaq 242695-001 8-port KVM Switch
How to set up Compaq Series 4110 8-port KVM Switch & select computer
The Compaq 4110 KVM switch was actually manufactured by Apex which is now part of Avocent. Your switch is Compaq's rebranding of the Apex/Outlook EL-80DT from Avocent.
The key to display the KVM switch menu should be PrintScreen. Here is a link to the user manual:
ftp://ftp.avocent.com/public/product-upgrades/Outlook/EL40-80DT/OL_DT_UG.pdf
Your answer seems to be on page 34.
May 30, 2008 | Compaq 242695-001 8-port KVM Switch
Compaq 8-port kvm switch firmware
HP Parts supposedly still stocks the EPROM for this model, so you can try to order it from the HP Parts Store. Check for part 340579-001.
Mar 13, 2008 | Compaq 242695-001 8-port KVM Switch
Compaq 242695-001 8-port KVM Switch Logo
1,148 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
