Dell UltraSharp 2407FP Power Button slipping
I purchased the Dell UltraSharp 2407FP from DELL on July 15, 2006 and now the Power Button is slipping. I understand that the power button has to be in the upright position in order to power on and off this monitor, but know the button is loose and keeps slipping to right and left making it so that you cannot power the monitor on unless it is in the upright position. Seems like something got jared loose, for the fact that all the other buttons next to it are firm and stay in place after pressing on them. I have to take a needle nose plyers ever time the button slips to the right or left and twist it until it is the upright position. It feels like the button is pressed in and does not pop back in the firm position like the other buttons.
I am trying to figure out how to get access behind the button so that I can diagnose it further. I do want to go back to Dell for the fact that I did not get the extended warranty. My monitor still works and keep in on all the time with Power Save, but it is a pain in the neck to know that something so darn expensive would have an issue like this.
Any feedback or help would be greatly appreciated
Brian,
BMCARDLE88@YAHOO.COM
I can't help but I can say I have the exact same problem with mine...
Posted on Oct 13, 2009
Dell? 1703 FPT. Where can I obtain a manual?
Actually there are not many options to contol manually a Dell monitor.. Here you have a setup manual
http://www.manualslib.com/manual/36463/Dell-Ultrasharp-1703fp.html
Found these specifications.
http://www.itema-pg.com/promo/2008/Mai2008/15-Philips/Specifications_%20Dell%201703FP%20Flat%20Panel%20Color%20Monitor%20User's%20Guide.pdf
Up to my knowledge, controls are mostly intuitive. Monitors have some buttons under lover right border, where you can manipulate some properties. Search for them.
Dell UltraSharp 1703FP Setup Manual
Manuals Dell US
Dell 1703FPT DVI LCD Monitor
Oct 08, 2015 | Computers & Internet
The monitor just made a pop and no longer works. How do you take apart to check if there is a fuse
2407 is almost the same as 2408 picture I have here, just be real careful not to move the front bezel too far from the chassis or you will break the cable! Use thin flat blade screw driver or special tool as shown in the video and work around the bezel REAL SLOW!
http://s807.photobucket.com/albums/yy352/budm/Dell%202408WFP%20Rev%20A02/
Replacement and instructions:
http://www.lcdrepair.us/2407fp-power.html
Apr 22, 2010 | Dell UltraSharp 2407WFP 24" LCD Monitor
Dell 1707FPt monitor doesn't display
Make sure you have the plug in tight or maybe your need a new monitor
Jan 13, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Power Button Broken?
Yes, I think your right, if it is under warranty send it back to Dell for repair, I had the same issue about a year ago.
May 20, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Power on/off button not working on Dell 17 in. Ultrasharp 1707FP
hi. probably de botton is damage or broken. if you have experience opening electronic devices like monitor you can replace that button you can purchase online. depending on the type of button, you can see a full tipe of button here: https://www.sparkfun.com/categories/145?page=all
Sep 16, 2017 | Dell UltraSharp 1707FP Monitor
19" Dell Monitor
some of the AC plug for dell monitor need to force little more than others. make sure the plug on the button is fully seated. (pull it out and reseat it).
the power button is the first one on the lower right hand corner.
Oct 22, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Monitor problem
It sounds as if the backlights are failing. It is probably cheaper to replace the monitor than anything.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Feb 18, 2018 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Dell ultrasharp 15 inch flat panel lcd
It totally sounds like the backlight is toasted. If that is the case you will have to replace them. Normally if the power inverter is shot, the monitor will power up briefly at least and then shut off. If you can use a flash light and see some sort of image on the screen you know that your VGA chipset works however your backlight(s) are burnt out. If not, more than likely your power supply (power inverter chipset) is broken and needs to be replaced..
Mar 28, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
