Question about Logitech ChillStream Game Pad
Won't play my games
My instructions say that I don't need to install disk on windows vista to use it. but it won't work.
  • 3 more comments
  • Anonymous Dec 26, 2007
    installed the disc still wont work i also have windows vista what do i do!
  • GoldnAvenger Dec 27, 2007
    I have the same problem downloading the driver from microsoft. a status bar pops up and then it says not enough storage is available to process this command. I have 63 GB of space! what is it talking about? where do i have to go deleting things so i have space to install this driver!
  • general13 Feb 05, 2008
    I'm old and new to pc games but I couldn't figure out what all the buttons are used for on the Chillstream .The info sheet just numbered them.I tried to play madden 07 but had no idea what was happening.The buttons didn't seem to do anything.I'm using Vista.
    How about using the keyboard,no instructions there either.
    Thanks.
  • Anonymous Feb 18, 2008
    i tried to play doom 3 and doom 3 Resurrection of evil because the key board sucks. my chillstream wouldn't work at all. i installed the disk i changed usb ports
  • Anonymous Mar 26, 2008
    My Gane Pad will work in the test scren on my PC but will not do anything on CALL OF DUTY4. How do I get it to work.
Im also having a similar problem. I went to logitech site and downloaded the driver from windows. When I try to install it it shows me a status bar that means nothing at all to me, goes through the entire thing, and then at the end it says "Failed to install." and disapears without a trace, leaving me without drivers and no where else to look to get this stupid peice of crap working.
HELP!?
Posted on Dec 26, 2007
My logi chill. dont work..the light flash but when i start the game only the kerboard i can use
Posted on Jan 06, 2008
Will Heroes of the Pacific run on Windows 7? When I click on 'play', it reads the disk, but then nothing else happens. Any thoughts?
Looking around google this game is old and it only works on windows XP. When am looking at the list of compatible games for windows vista and 7 it don't even have the game listed.
Jun 08, 2011 | Codemasters Heroes of the Pacific
I have Mahjongg variety pack. I was using windows xp. I now have Vista. It will not play on vista.
I just installed it tonight. (Yes, I have Vista.) Two of the games work great. All I did was right click the icon that was on my desktop (I made copies and put them on my desktop - the program didn't do this), clicked on properties, clicked on the tab called "compatibility", checked the box that said, "Run this program in compatibility mode for", and from the dropdown list, I chose Windows 98/Windows Me. Also, I had to temporarily disable Avast, and turn off "real time protection" on Microsoft Security Essential (I turned it back on after the games were installed.).
The games that work for me are Mahjongg Empire and Mahjongg Master 3. Rahjongg the Curse of Ra is being obnoxious (I came on here to find a solution) and the other one won't do anything, not even install. Anyway, I hope this helps you get at least the first two games installed.
Aug 26, 2010 | eGames Rahjongg: The Curse of Ra for...
I have windows 7. When i try to play Nancy Drew: Danger by design a box pops up requesting i insert disc 1. There is only one disc! It seems to work ok on windows xp. Ca you suggest anything to make it...
From the Nancy Drew web site:
Windows Vista/7 Support Installing older games (#1-13) with Windows Vista/7.
While our older games are not completely Windows Vista/7 compliant (notably games #1-13), there is a workaround which has been successful for most players. Please take the following steps to manually install.
If you had previously installed, uninstall the game and then delete all remaining game file folders from your computer, including emptying them out of your Recycle Bin. These files may be in one of the following locations:
C:\Nancy Drew\
C:\Program Files\Nancy Drew\
In your Documents folder: C:\Users\Username\Documents\
Once this is done, make sure you're logged on as an Administrator for your computer and manually install by taking the following steps:
1. Go to your "Documents" folder and create a new folder. Rename the folder with the title of the game.
2. Insert game Disk 1 in your disk drive and open "Computer" from the "Start" menu.
3. Double-click on your CD-Rom/DVD drive, look for a Setup or Setup Launcher Installshield file. Double-click this file to start the installation process.
4. When install asks what directory you want your game to install to, click "Browse".
5. Navigate to the game folder you created by selecting "C:" drive, then "Users" (or User name), then "Documents", then select the game folder.
6. Continue forward with the installation process, when asked if you want to install DirectX, check "No, I will install myself".
7. Upon completion, uncheck the "Play Now" box, click finish and exit setup.
For game titles #1-5, follow these three additional steps:
1. Right-click the game icon that is now on your desktop, select "Properties".
2. Under "Properties", click on the "Compatibility" tab.
3. Check the "Run in Compatibility Mode" box and then select "Windows 98/Me" from the drop-down menu.
You should now be able to open and play the game. If you installed an older version of DirectX with the game, please go to Microsoft's Download Center to download and install the latest version of DirectX for your version of Windows.
Aug 03, 2010 | Computers & Internet
The game is installed but won't let me play
Try running and setting "Compatability Mode" for XP SP2. Right Click, on the programs .exe, and set it there. Also RUN in Administrator Mode, always.
Mar 05, 2010 | CDV Software War Front: Turning Point for...
Interactive Magic Apache Windows 95 program disk does not load into HP Pavilion - Light Strobe DVD/CD Burner. I have Windows Vista. Can it be done?
You must use Dosbox, get it at www.dosbox.com. Follow instructions and you will be able to play most old dos games. I started playing Apache 95, the game before the one you're trying to load and it plays just fine with graphics, etc... I love that game and when computer technology got better my old dos games fell by the wayside until I found dosbox.
Aug 31, 2009 | Interactive Magic Apache for Windows, Mac,...
I have no HD on my PS3, it was working previously
some games need to use hdd installed in your PS3...
Uncharted is one example...the game runs if you install part of it in the Hdd..if you don´t...the game won´t play...
I think that some games that you need to update the firmware you need to install the hdd too...
Install a Hd...this will solve your problem!
Godd Luck!
Dec 09, 2008 | Video Game Consoles & Games
Initialization failed
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
After the game is successfully installed right click on the game shortcut or the game "AOM.exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply". (You can also try with the other options also)
The same set of steps can be used for installation of older games installation on Windows Vista.
Nov 19, 2008 | Microsoft Age of Mythology for Windows
Let's Ride Corral Club will not run
To make the all the files of the game compatible to Windows Vista you need to install the game and then make changes to the game exe file.
Some game ".exe" file (executeable file) would let you make changes in the Compatibility option, whereas older games might not give that option at all.
9. After the game is installed go to the game directory and find the "LetsRide.exe" and click on "Properties" and repeat step no.7
There are lot of files that need to be changed in order to get full functionality and to communicate with operating system and the hardware, hence there is no guarantee that the game might run even in cases where you will successfully install an older version of the game with the above mentioned steps.
Nov 11, 2008 | ValuSoft Let's Ride: Corral Club for...
I haven`t got a installation disk for my printer, so it won`t connect to my computer .
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printer does not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Sep 04, 2008 | Lexmark P706 Photo Jetprinter InkJet
I just installed rainbowsix/vegas2 the gameis installed the music plays but the game screen remains blank an the music keeps playing my computer is running windows vista.
you need to to check the display settings and the system requirement before installing and running the game
System Requirements
Windows XP/Vista
3GHz Processor (3.5GHz recommended)
1GB RAM
7GB Hard Disk Space
4x speed DVD-ROM Drive
128MB DirectX 9.0c compatible, Shader 3.0 enabled Video Card (256MB DirectX 9.0c compatible Video Card recommended)
Latest DirectX 9.0c compatible Sound Card
DirectX 9.0c (you may need to download the latest drivers for your video and sound card)
Keyboard, mouse / X-box 360 Controller for Windows
Online multiplayer: broadband Connection with 128Kbps or faster.
*Supported Chipsets: ATI Radeon X1600-X1950/HD 2000 series / HD 3000 series / NVIDIA GeForce 6600/6800/7/8 series.
Laptop models of these cards are not supported but may work.
These are the only ones that will run this game. Additional chipsets may be supported. For an up-to-date list please visit http://support.ubi.com.
System Configuration may require minor adjustments to the configuration of your operating system and/or updates to hardware component drivers
Notice: This game contains technology to prevent copying that may conflict with some disk and virtual drives.
May 23, 2008 | Computers & Internet
Logitech ChillStream Game Pad Logo
189 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
