Home | Konica Minolta | DiALTA CF910 Copier | The printer says the L1
Konica Minolta DiALTA CF910 Copier
Problem for Konica Minolta DiALTA CF910 Copier
By chrisharrisl on Aug 19, 2009
the printer says the L1 door is open, when it is closed
Solution #1
posted on Aug 20, 2009
Not Rated)
firecontrol7
Rank: Guru
Rating: 88%, 56 votes
The sensor for the door mayhave dust on it, also the mirco switch which is activated by the door may be pushed into far due to the door being closed to hard:(. As for the sensor use some can air. lastly the door actuator mounted on the door mite be broken off the door.
Was this helpful?
Yes
No
Popular Solutions for Konica Minolta DiALTA CF910
Questions and Unsolved Problems for Konica Minolta DiALTA CF910
Do you recommend Konica Minolta DiALTA CF910 Copier?
Answer
Answer
How do I separate housing to get at bulb to replace it? I have the housing out of tv but can't... (More)
Answer
pixma MP800 need software to be compatable with my Compaq presario v6000 hp
Answer
why is there a higher expected reading on the Minute Volume Display of Model: Bear 3 Adult... (More)
Answer
wont print, was printing with this display for awhile, then after a paper jam, stopped working. have... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Konica Minolta DiALTA CF910...:
Top Copier Experts
Rank: Guru Guru
Solutions: 709
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
