Question about Lands Phones
Half-ringer I think a phone tech hooked up the wrong phone lines going into the house.The module in the user half of the interface is new to me. the house has a splitter, so i'm assuming that all four colored wires should be connected.
SOURCE:
CoachTim
  • 202 Answers
SOURCE: connecting
jon, I am assuming you have DSL modem. Sending a fax by DSL requires one of two methods: 1. You obtain a DSL line filter suitable for connecting a standard voice telephone to the DSL line, then connect an analog fax modem to the line through the line filter. Good Luck, Tim
Posted on Feb 04, 2007
sally_ice
  • 10 Answers
SOURCE: "fail: Test ADSL Line Sync" per AT&T Tech Readout
hi,there are a lot of possibilities y ur dsl light wont stop flashing red, 1.could be hardware failure,2.defective lead light for dsl,3.or line issue on the network...i strongly recommend that you contact your isp or att provider so that test would be done by their tech support,...basically you have checkd all inside wirings n as you have said you even tested the nid already...have you tried changing the dsl cable or phone cable? have you tried using another modem? were you using a filter for your dsl? you have to consider also other emi/rfi or electronic interference....but most probably you might try upgrading your modem n see if your gonna get a steady dsl light...the ethernet plugs has no effect on the dsl light...its just the cable connection or line issue or defective modem...i hope this will help, pls feel free to ask if you need further astnce...
Posted on Dec 01, 2007
  • 38 Answers
SOURCE: new phone wire from box to home need diagram to show how to
The phone company should make that connection. Use a phone jack assembly with alligator clips to find the dial tone. The first line color should be a pair, blue&blue-white, 2nd line, orange& orange-white, then green followed by brown pairs which would be 4 line numbers in that color code order. Each line is just a single pair. Thank you. Jer
Posted on Feb 25, 2008
AvioriX
  • 689 Answers
SOURCE: lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Posted on Nov 11, 2008
SOURCE: Ericofon ringer
Everything you need to know is right here: http://ericofon.com/work/wire.htm
Posted on Jan 08, 2009
The visual ringer will not flashing.
At an educated guess sounds like dial tone is set to decadic if there are two phones the other phone will set off ringer when numbers dialed. May need to get phone provider to change dial mode in exchange line interface circuit to be Dual tone Multi Frequency Dialing and then switch phones to Tone dialing rather than pulse dialing.
Jun 01, 2015 | Lands Phones
How do I unstuck my Phone from line in use?
unplug all the phones in the house, or go out to the NID (network interface device) on the outside and disconnect the "line" from the "network". It should have a standard modular plug. You should be able to plug a regular phone into that jack and see if the line has cleared. Chances are there's a phone in the house that's partially off-hook.
May 15, 2014 | Nortel T7316 Executive Business Phone...
Ringer buzzer not supported
I think there's no such error message on this phone,if the buzzer or ringer does not work,it can be fix by this steps.
* Remove the front cover of the phone
* unscrew 6 screw using T6 precision screw driver or anything that can release the screw up
* lift up the entire module(mainboard and the frame)
* upon separating the module,you see a circular object attach on the back housing,that is the buzzer we are looking for,check if it's clean and the pin are well align and proportion.
* on the mainboard,clean the buzzer interface where the buzzer pin is connected,you can use a cotton and any rust solution.
* now assemble the phone and try if it's ringing now.
Otherwise,you need to buy a spare buzzer,can buy on any mobile shop if they sale the parts,or else let them fix the problem to make sure it is.
Thank you for visiting FixYa...
Aug 16, 2011 | Nokia 2626 Mobile Phone
My Nokia 3120 Ringer Problem Ringer not working
If you can't the ringer of your phone,check the settings on your profile if its activated and volume is up,otherwise,it seems your buzzer/speaker is the problem,sometimes when the phone gets drop on the ground, buzzer contacts may be dislocated or probably need a buzzer replacement.
To work with this problem and can DIY,
* you need a T6 precision screw driver or any tool that can release the screw.
1. Remove the battery cover
2. Remove the battery pack.
3. On the front panel/housing,release the 2 clips on the bottom using even your thumbnail and lift up the front housing.
4. release the 6 screw using the said tool.
5. lift up the entire module which is the LCD with frame and together with the mainboard.
6. On the back housing,you will see a 2 gold plated pins on the upper potion,that is seems to be the connector were the buzzer is connected and hide underneath.
7. clean it first,check if there's a corrosion and align it as well.
8. located the interface were the 2 metal pins is align connected unto the board.clean it as well.
9. Now assemble the phone and try if it is working then.
If not working,need a parts replacement and this could be possible if you bring to the a mobile service shop near you for replacing the said part.
Hoping this method helps you in a way. Thank you for visiting FixYa.
Jul 16, 2011 | Nokia 3120 Cellular Phone
Two phones in use with Motorola VT1005 result in very low volume
disconnect the POTS line incoming to your home on the outside of your house. This will make the phone wiring within the house a standalone network. Plug the Line 1 jack of your TA into any available phone jack and the remaining jacks in the house will be energized. This will create the same environment as you had with POTS.
Jun 07, 2009 | Panasonic KX-TG2740 Cordless Phone
Phone Ringer
I dont think you can do that. I can send you a manual. What processor release do you have?
Mar 14, 2009 | Lucent PARTNER18 Corded Phone
Lowering ringer volume on handset v tech 5.8 digital phone
Ringer volume
- OR -
Good Luck
Nov 11, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Got new phone, answering machine dead?
There is no two horizontal lines error description in user manual.
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
Based on my experience, I think, maybe it is related to parrellel phone dectection. ATT 1717 already think, the system is busy or in use. The line voltage is too low when you hook up other phone.
Your house phone line maybe far from switch (3km to 5km).
Dec 28, 2007 | AT&T 1717 Digital Answering Machine
Intermittent ring and now fading display
You may have the problem fixed by now; but I had the same thing happen to me with the same phone and also hooking up to a voip type phone connection. The person installing it hooked it from the modem straight to the phone. He didn’t know why and when he left I still had the problem. The problem being the phone would not ring. After thinking about it I decided to hook the modem phone line to my house phone wiring and then hook the phone to the phone house wiring. It worked and I am not sure why but I think that the house phone wiring is grounded and that makes more voltage for the ringer
Aug 30, 2007 | GE 21028GE3 Cordless Phone
Programing
Here are some suggestions Volume You may adjust the ringer, speaker, handset and headset volumes independently with the VOLUME ^ and VOLUME v buttons. Your telephone comes with predetermined settings which can be adjusted to individual taste. You will hear an error tone when the maximum or minimum volume level is reached. During volume adjustment, a ?dashed line? icon shows in the display. Adjusting the Ringer Volume Press the VOLUME ^ or v button while in on-hook mode. And/or 1 Selecting a Ringer Tone You may select the ringer tone for each line independently. You may choose to turn the ringer off or select one of the four available ringer tones for each line. 1. Press STORE. The red indicator blinks indicating unit is in Store Mode. 2. Use the number pad to select a ringer tone 0 through 4 (selecting 0 turns the ringer off). 3. Press STORE and then press the desired line button. NOTE: The line indicators continue to flash for incoming calls even with the ringer disabled. You may not select the same ringer tone for both lines. Checking the Ringer Settings Check the setting or each ringer (on, off) by pressing STORE, followed by LINE 1 or LINE 2 button when the phone is on the hook. The ringer setting of the selected line will be shown in the display. If there are any further questions or comments please post here. Please rate this solution through fix-it. Thank you.
Jun 23, 2007 | GE 29485GE2 Three - Line Speakerphone w/...
Lands Phones Logo
134 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
