Question about Hotpoint VBXR1090D Top Load Washer
Leaking on floor
First of all, the model number from our "inherited" Hotpoint reads:
VBXR1070WOWW ... Was this changed at some point?
Looking under the machine on the left side, about 12 inches back
from the front of the machine, water drips are visible from the
framework. Sometimes there are puddles and sometimes not.
Any input appreciated...
  • 83 Answers
Sounds like your tub seal
Posted on Dec 07, 2007
SOURCE:
Rf266. Water collects under the bottom drawer of the refrigerator and results in leakage underneath onto the floor
Can you click HERE and read and or watch the video's so you can get an idea of what needs to be done behind the rear panel of the freezer to unblock the condensate drain Leaking Refrigerators.
Thanks, John Tripp Appliance 911
What is the model number?
May 01, 2014 | Refrigerators
Water leaking from detergent drawer Hotpoint WMD 962
what is your model number is then we can get started then okay
Feb 04, 2013 | Hotpoint Washing Machines
Periodically (once daily?) leaks up to one quart water onto floor.
This is a very common problem when the condesate drain behind the rear of your freezer wall becomes clogged with ice or other matter. If this is happining only under ther refrigerator it would indicate a drain pipe missing the condensate tray or the tray itself is cracked or leaking. Click here for moer= Leaking Refrigerators Just what may be happing and then here=> Leaking Refrigerators
Please read all the information because all leaking refrigerators act differently. I will be here should you have more questions, Thank You, Sea Breeze
Aug 29, 2011 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Our Hotpoint Aquarius Dishwasher BF11, built into the kitchen units is leaking steam from the door ( and starting to cause the wooden floor to bend ). Can I get a door seal for this model ? It's probably...
you gotta send the full model number,open the door and look at the very front of dw where the door closes into the machine,usually the tag is on the left side at 9 oclock,first are you positive that's where it's leaking remove the bottom kick panel and see if the motor or anything isn't leaking there too.if it is the door gasket it's an easy fix
Oct 07, 2017 | Hotpoint Dishwashers
Water on floor under freezer side csx20ea model hotpoint sems like twice a day a puddle the size of a cereal bowl is under front left hand side of my side by side fridg i have a pergo hard wood floor im...
If you have an ice maker, check for a leak in the water line. If no ice maker, there could be a leak in the pan for the defrost water, or the drain hose is out of position. Also, check to see if the water is actually leaking out from the freezer door. That would indicate a clogged drain. The bottom inside the freezer may have water, or ice on it. If so, suspect the clogged drain.
Jan 06, 2010 | Refrigerators
Water from my disposal backs up into my hotpoint ($300-model) dishwasher. The dishwasher works fine otherwise. Is there a one way valve in the diswasher that is suppose to prevent reverse flow and/or is...
If it's what I think, it's a simple fix. Does your dishwasher drain run along the floor of the cabinet, then up to the disposal? (my guess is yes). There should be an "air gap" between the disposal and dishwasher, this means when it comes out of the disposal, it should go UP and be clipped to the highest point of the inside of your cabinet, then down. Think about it, sh*t flows downhill, but it can't get over a hump. Good luck
Dec 26, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Dry-spin doesn't work, because after rinsing the clothes are still wet. MOD- VBXR1070WOWW SER-SZ107967H
I'm assuming this is a G.E. brand because of the model number. Take the four screws off the very bottom panel of the front of the washer. Inside you will see a twist off rubber cap. Place a pan under it big enough to hold 2 quarts, and twist the cap open. When the water comes out and it is empty remove any accumulation of lint, loose change, etc. This should be done monthly to help the washer discharge the water on spin cycles.
Also, inside the door is a flat rubber ring. At the bottom pull the flap back. There are small holes there for the water to drain out. Lots of stuff accumulates there too, even as large as a pocket knife or ball point pen. Check that daily when washing.
May 19, 2009 | Washing Machines
Freezer leaks into refridgerator
Your defrost drain line must be cleaned.
With a model number I could tell you where to find it.
Mar 10, 2009 | Electrolux Refrigerators
It leaks water onto the floor.
Where is the water coming from? unless you have a leaking ice maker fitting on the back or somewhere else, the most likely cause would be a stopped up defrost drain. check inside the freezer on the back wall and floor. if you see ice you will need to unstop the drain. (most newer models don't have a removable drain pan)
Nov 08, 2008 | Hotpoint HSS25GFP Side by Side...
Wiring Diagram
Have you looked under the main control panel for this??The other way is to contact Hotpoint(GE) support,they will have this information.Just have model & Serial number ready.
Jun 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint VBXR1090D Top Load Washer Logo
170 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
