Question about Achiever CCS-1500 Cross-Cut Shredder
Achiever Shredder Goes in reverse, place paper in machine starts and stops. Red light comes on. Have cleaned machine. Machine works in reverse.
    Scholar:
  • 102 Answers
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pcAchiever Shredder - 1.gif board, contact manufacturer for more info.
Posted on Mar 02, 2008
Fix this shredder
The unit is probably clogged up with a bunch of shredded paper. Unplug it ! Clean out the paper using fingers and a knife to get most of the paper clips and paper out then plug it in and run forward and reverse. That's what i do and it works every time.
Nov 16, 2013 | Achiever CCS-1500 Cross-Cut Shredder
Red light and green light on but motor will not come on
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Sep 13, 2013 | Fellowes PS60-2 Shredder
Royal 85x paper shredder: The shredder will start to shred but stops shortly after "grabbing" the paper. In order to get it shredding again, I have to put the machine in reverse, remove the...
Sometimes spraying shredder oil on the cutting teeth wil work.
You should shred paper with a light weight machine oil poured on the paper to keep the cutting teeth working freely.
Good luck.
P.S. If this doesn't work then just take the head off and cleanj/lubricate any bearings you find.
Mar 23, 2011 | Royal 85X Shredder
When I try to feed a piece of paper into the shredder, the overload light comes on and the motor stops running. It will run in reverse. Oh and when the overload light comes on, the pull out basket is...
You say it runs in reverse...does it seem to run slowly??? Have you ever "oiled" the machine.???
This is a x-cut shredder and must be oiled...get some "shredder oil " and try pouring some of the oil across the cutting blades and running the machine in reverse. See if it seems to pick-up some speed after the oil in tried. Then see if it will run in the fwd direction for you.
Dec 07, 2010 | Royal VF1012mx Shredder
A Royal crosscut shredder that usually only runs in reverse
in the middle of the paper enterance clean sensor
May 22, 2010 | Royal CIA 12X Shredder
Shredder only operates in reverse
Check and try cleaning the "eyes" in the paper throat... if that dosn't fix it it could be the pcb inside...call Royal at 1-800-524-0799 for parts help.
Feb 17, 2010 | Royal CIA 12X Shredder
Red overload light is on
Try pouring some shredder oil into the throat where you normally insert the paper and run the machine in reverse.Put machine back into ready condition.
Put a piece of paper in the throat just enough so the machine should run but not all the way in so that the cutting mechanism catches the paper...all you want to do is make the machine run forwards but not actually be feeding in any paper.
If it wont even run in the forward direction you may have a pcb prob...give Royal a call at 1-800-524-0799 for parts assistance.
Jan 08, 2009 | Royal VF1012mx Shredder
SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Aug 01, 2008 | Office Depot Ativa DQ60M Shredder
Shredder will not shut off in auto mode
I work with Fellowes products but it sounds like a paper feed sensor problem this is usually a mechanical or electronic switch in the throat of the machine. If its mechanical trying jiggling the switch to make sure bits of paper are not jamming it up also make sure switch does not appear to be broken. If it is electronic you should only have to clean the sensors, on our machines this is a little bulb that resembles the bulb on a remote control, a little rubbing alchohol on a qtip should do the trick. If this don't work you will have to contact manufacturer because you probally have a broken sensor or a bad PC Board.
Feb 14, 2008 | Achiever CCS5000 Shredder
Shreder not turning on
where are the safety interlocks located??
Nov 14, 2007 | Office Equipment & Supplies
Achiever CCS-1500 Cross-Cut Shredder Logo
148 people viewed this question
Top Achiever Office Equipment & Supplies Experts
Marvin
Marvin
quennie732
ray gallant
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
