Projection Televisions
Problem for Projection Televisions
Generic problem for all Projection Televisions
Pt-53wx53 still have shutdown. replaced
By catrott4038 on Aug 19, 2009
pt-53wx53 still have shutdown. replaced convergence ic's and all resistors. double & triple checked all solder joints. projectors light up for about 5 secs and you can see them starting to auto converge then shutdown and code for convergence malfunction. one thing i do see is a (conv+18v) resistior has evidence of heat but still reads in range. into repairs for $30 and my time. am i going to put good money after bad. picture was perfect before problem.
Comments:
Aug 26, 2009
- replaced both ic's and discolored resistors from suburban electronics but still have problem. checked to see if anything was "glowing" on the boards when i turned the set on. saw nothing but can smell something "toasty" on the power board. can a power problem also give a conv. malfunction code?
Best Solution
posted on Aug 19, 2009
Very Helpful)
SD Tech
Rank: Guru  Televisions & Videos  Expert
Rating: 97%, 921 votes
Two ways to approach this; first replace any 2.2 ohm resistor that is even a little discolored; second you may have got a bad new IC---it does not happen a lot but it does happen; way to find out is UNSOLDER BOTH IC's completely and turn the set on---if it comes on (forget about no convergence) and stays on---one of the IC's is probably bad. HINT:follow the path from the discolored resistor to one of the two ic's and that is the most likely bad one---I have replaced hundreds of these and every once in a while I get a bad new one----I just get two more new ones and do it again---fyi---you can buy the 392-110's on ebay for less then 13 dollars for a pair---Suburban electronics is the best vendor and they come with a 6 month warranty---last time I got a bad one I just emailed them and they sent me 2 more free.
I do this here for free so if this has been helpful give me a vote here.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
I think the red bulb is out on my 8 year old Hitachi projection TV. How much should I expect to... (More)
Answer
I CAN'T SET UP MY CABLE CHANNELS WITH THIS TV MODEL #46GW947 . I CAN ONLY SEE ONE CHANNEL? LEASE... (More)
Answer
Mitsubishi WL-82913 will not turn on, green power on light blinks continuaously but unit does not... (More)
Answer
I have a Philips Rear Projection TV and the picture is cloudy. I've tried adjusting picture,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Projection Televisions:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 801
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
