Adapters.com FREE Genica Realtek A-8100 10/100 PCI Network Interface Card  Network Adapter
Problem for Adapters.com FREE Genica Realtek A-8100 10/100 PCI Network...
Have realtek 8185, vista, keeps loosing signal
By bluebonnet on Dec 02, 2007
only 75 feet from router and it keeps dropping signal and i have to reboot
Clarification Request
Posted by ampaino14 on Jun 22, 2008
I've had those updates since they came out and they haven't helped at all. I'm not far from my router and my internet mysteriously disconnects all the time. I can't even play online games anymore. I'm not positive but I'm pretty sure I didn't start having this problem until I updated to Service pack 1. The only difference is that I don't have to reboot, I can just reconnect.
Same Problem
May 25, 2009
-   What if the Rollback button is not available.. its there, but grayed out..cannot push it. -   Guest
Jan 30, 2009
-   i have the same problem, where is that vista update people are mentioning? -   eedwin3
Jan 30, 2009
-   i've got the same problem here! how to fix it? -   eedwin3
Jan 24, 2009
-   This is my son's laptop. He was always frustrated because it would drop the signal. I thot it was a setting. Just got the thing back on warranty with new motherboard - restored the harddrive and can't get the realtek 8185 to work properly. It did for 2 downloads and now, nothing. Have tried all the config possibilities on the utility. It' won't even detect the wireless networks.-   Guest
Jan 20, 2009
-   exactly the same problem here as well-   Guest
Best Solution
posted on Feb 05, 2008
Helpful)
Seanah
Rank: Apprentice
Rating: 85%, 11 votes
There are two optional updates through Microsoft for the realtek wireless card. I've had to reboot my computer 3 to 4 times a day, and I finally got sick enough of it that I went onto Microsoft's windows update site. Since my computer only downloads the "mandantory" updates, who kows how long the optional ones have been waiting. Since I downloaded the updates this morning I haven't had any problems. Keeping my fingers crossed! Good luck to you!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Aug 02, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
There is tremendous variation in the hardware between devices that contain the Realtek 8185 chipset. If there wasn't a vista driver in the box that came with your card, then the chances are you are using the generic one that comes via Microsoft update.
I am using this one too, and it is rubbish. The device randomly stops functioning and I have to disable and reenable it to get it working again. Basically, it is not 100% Vista compatable. Buy a new card that comes with a Vista Driver. Or solve all your problems and upgrade to Windows XP SP3.
Solution #3
posted on May 26, 2009
Very Helpful)
mfb139
Rank: Apprentice
Rating: 97%, 8 votes
Go to the Device manager and bring up the properties to the realtek 8185 device. There is a tab called Power Management. Click on this tab. There is a checked checkbox that says Allow the computer to turn off this device to save power. Uncheck this box. This should stop the random disconnects.
Was this helpful?
Yes
No
7 people thought this was helpful
Solution #4
posted on Dec 21, 2008
Somewhat Helpful)
t1dude
Rank: Apprentice
Rating: 80%, 5 votes
My Realtek 8185 wireless adapter on Vista and I also have the same constant problem with the adapter dropping the signal for no reason at random times all day long. This Realtek 8185 is a total POS.
anyway, the "solution" I came up with is to open device manager and disable then re-enable the 8185 network adapter. This works about 75% of the time. The other 25% of h time rebooting is necessary. Seems like the suggestion to get another wireless card is the best one. The Realtek 8185 SUCKS. ...and Realtek apparently doesnt care at all because they have not released a new driver and this has been a problem for a long time.
Was this helpful?
Yes
No
Solution #5
posted on Mar 10, 2009
Somewhat Helpful)
xtothemax21
Rank: Apprentice
Rating: 79%, 6 votes
its easy all you folks roll back your driver in the control panel for your realtek 8185 wireless card. this exact same thing happended to me when i bought my laptop. I installed the lastest driver and all of a sudden it didnt work so what i did is ROLLED BACK THE DRIVER.
1. Control panel
2. Device manager
3. Network adapters
4. Find realtek 8185 card and right click on it to select the properties tab.
5. Go to the driver tab on top of the page which will bring you to the drivers tab.\
6. and last click roll back driver and restart and you should be good.
Dont ever install the new driver again i havent since ive had my laptop and i havent had a problem since
Was this helpful?
Yes
No
Solution #6
posted on May 22, 2009
Somewhat Helpful)
Xeo NoX
Rank: Apprentice
Rating: 75%, 1 votes
if you update the drivers from microsoft, your wireless adapter will stop functioning properly, use the default drivers or the drivers that came with the laptop. DO NOT USE THE WINDOWS UPDATE DRIVER.
Over all this Realtek 8185 Card is a POS, it's even a problem under Linux. very unstable card with horrble range. Thats why i like atheros chipset wireless cards, broadcom chipset would be my 2nd choice.
Comments:
May 22, 2009
- BTW: my testing was done on a MT3707 Gateway laptop
Was this helpful?
Yes
No
Solution #7
posted on Mar 29, 2009
Somewhat Helpful)
everettk
Rank: Apprentice
I went into the device manager and went to Roll Back Driver it now it connects and is stable. I guess the latest driver is just ****... Hope this works for you guys.
Was this helpful?
Yes
No
Solution #8
posted on Nov 18, 2009
Not Rated)
noname2
Rank: Guru
Rating: 91%, 50 votes
If nothing else works and you are using a secured network i suggest downgrading from wpa2 to normal wpa, this greatly improved my signal stability and range. Remember as long as your using better than WEP it is your passphrase that is the weakest link so if thats strong WPA-WPA2 not much difference for home user
Was this helpful?
Yes
No
Solution #9
posted on Sep 20, 2009
Not Rated)
bob1607
Rank: Apprentice
Rating: 0%, 0 votes
Try installing this driver from Realtek
http://www.realtek.com.tw/downloads/RedirectFTPSite.aspx?SiteID=1&DownTypeID=3&DownID=430&PFid=1&Conn=5
Was this helpful?
Yes
No
Popular Solutions for Adapters.com FREE Genica
Questions and Unsolved Problems for Adapters.com FREE Genica
Do you recommend Adapters.com FREE Genica Realtek A-8100 10/100 PCI Network Interface Card (GENICAREALTEK) Network Adapter?
Answer
Answer
I accidentally deleted Realtek Audio driver (Windows XP) and I downloaded the software again (.rar... (More)
Answer
I accidentally deleted the audio drive from my computer, so I install realtex hd , but still no... (More)
Answer
I recently crashed my hard drive and replaced it. Now when you go to Sound in Control panel it shows... (More)
9 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 07, 2009
Same issue, I guess you get what you pay for...
Comment by hawkeye25, posted on Jun 08, 2008
Having the same problem.
When the PC and the wireless router is in the same room - it works intermittently, but when PC upstairs, the signal strength is good, but will not connect.
Comment by thoard, posted on Apr 21, 2008
I have the same problem, droping the signal less then 50 from the router. Using Microsoft Vista. Any ideas on how to fix this problem is appreciated.
Comment by Guest, posted on Jan 12, 2008
same problem vista keeps loosing signal and have to reboot
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Adapters.com FREE Genica...:
Top Network Adapter Experts
Rank: Guru Guru
Solutions: 1447
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Network Adapter Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
