Ariel connection for denon dm 31
Have installed an fm aerial ,but the connection into my denon will not fit , it says in instructions to fit an f type plug the plug from the ariel cable is a male connection . but the denon socket is to big for a standard coaxial plug , any idea,s
  • grumpybear Dec 02, 2007
    sorry i mean't that the plug from aerial is to big for the denon socket
    Problem Solver:
  • 12 Answers
Try going to your local tv store and ask for a male to male connector it looks like this:http://www.firefold.com/Products/RCA-Male-to-Male-Adapater__RCA-MALE-MALE.aspx
Posted on Dec 23, 2007
  • Tom Newman Dec 24, 2007
    sorry i meant female to female connector :s
When on FM tuner, stereo stops playing after a few minutes
Right then sounds like the connection from the aerial lead into the receiver - check out the socket where the aerial plugs into!
Is it loose at all or could there be a bad connection inside the unit.
Get the cover OFF and investigate yourself before you rush down to that very friendly repair man along the street.
Jan 05, 2014 | Denon DRA-365R Receiver
No or bad signal
Check in the Installation Menu that Antenna Power is set to OFF.
There is a chance that the water that came down the aerial lead has damaged the tuner module in the Humax.
Dec 28, 2013 | Humax PVR9300T HD DVR
I have an Alba 16 inch flatscreen tv with built in digital tv. When i try to do initial setup or auto install it says check antenna connection even although ariel is in. Can you help
Do you have an indoor or outdoor aerial?
Indoor aerials will not have the strength to pick up television broadcast signal.
Double check your connections, as you could have a loose wire or connection somewhere.
You might need to speak to someone who, can take a look at your aerial to see if it is configured correctly.
Also to make sure it isn't a problem with the aerial, do you have another TV that you can try using on the aerial. to see if you can get signal?
Jul 19, 2011 | Televison & Video
I've purchased Plexgear DVB-T stick and installed corresponding software, but when scanning channels have no result. That would be nice if somebody can help me in this matter.
If you are trying to use the ariel that is supplied with the unit you will never find any channels unless your house is next door to the transmitter. You will need to connect to your normal roof ariel.
Nov 03, 2009 | Computers & Internet
Alighn ariel for digital tv
The best type of aerial for digital reception is to use a wideband aerial this will give you a better spectrum to receive the signal. To locate the aerial position, if you know in which direction your local transmitter is situated, then point the aerial in that direction. The best way to find out which way to point is to simply look around at any of your neighbours aerials & then aligned yours in the same direction. If you are using a spectrum analyser as your sattelitte finder then you can use this to find other frequencies in the signal range.
Sep 06, 2009 | Televison & Video
I have installed a digital ariel but am unable to get any channels. Keep getting message no signal. The ariel works with other tv in house
You may need a digital booster when sharing 1 aerial.
They are quite cheap (£5 on e-bay is the cheapest I've seen) and easy to fit.
Also the coaxial cable can make a differance, you really need shielded and with as few joints as possible.
I hope this helps.
P.S. try tuning with just the problem set connected to the aerial direct.
Aug 24, 2009 | Televison & Video
Denon Receiver AVR-1600
Seeing as you can't put an aerial outside, can you put one in the loft space, if you have one. You could use a standard FM aerial. It wouldn't be as good as mounting it outside, but it would give you better results then a wire.
Jun 20, 2017 | Denon AVR-1600 Receiver
Kenwood micro hifi model rxd-m33v ariel output
You need a 75 Ohm standard aerial connector to 75 Ohm miniature RF connector adapter to fit the socket..
Jan 18, 2018 | Kenwood Audio Players & Recorders
Denon UDM3 SHELF SYSTEM
Hi MadLad,
There are several things to consider re this fault.....
Normally on small systems there is a selector switch to allow you to select what you need to listen to...for example if you want to play a CD then you select the CD mode, insert the CD push play and away it goes....
In your case you need to select Radio, or maybe select AM or maybe select FM, one of these should be accessed from a digital read out menu where you select your requirements.
Please have a good look at the operating manual to see if you can work out how to select the required listening mode, and you will be sweet...
Cheers From YUBEUT
Dec 14, 2007 | Denon DM-33 Shelf System
217 people viewed this question
 Grubhead
Grubhead
