Question about Breadman TR2200C Ultimate Bread Maker
Breadman ultimate....power but blank screen
My Breadman Ultimate is not working; it is receiving power, because the light turns on when the lid is opened. The screen is blank, however, and nothing happens when I push the buttons. There is also no tone when it is plugged in (usually there is).
  • 10 more comments
  • Anonymous Dec 24, 2007
    We are having the same problem!
  • Anonymous Jan 14, 2008
    ditto
  • Anonymous Feb 09, 2008
    yep same problem
  • Anonymous Mar 01, 2008
    I've got the same problem. However when I removed the PC board I could not find the "Reset" button, I was wondering if there are any more details or if a picture is available?
  • Anonymous Mar 10, 2008
    My machine is getting power but the buttons will not work ,It appears to be a circuitry problem? My husband attempted to look for a reset button but nothing has worked.
  • Anonymous Feb 01, 2009
    I had the same problem. Dave Kristol solution worked great. Used a metal bread twist tie to short the GND to VCC and VDD. Took 5 minutes to do complete fix and I'm an amateur.
  • lethaboust Mar 06, 2009
    The screen was blank for me, too. I'm using a borrowed model from co-worker while waiting for replacement breadpan for TR900S model. My husband followed the steps and finally got the keypad to register again and I'm back in business, but this is a major inconvenience and one I hope that engineers for Breadman fix in future models. I haven't been pressing and holding the stop reset button before unplugging on either model, and maybe this is what triggered the panel to go blank.
    I do like the bread it makes.
  • Anonymous Mar 07, 2009
    I had the same problem until I read and followed Dave Kristol's solution. He's no apprentice, he must be the Pro from Dover.
  • stephan255 Apr 20, 2009
    My TR2200C just went blank as well. I plug it in and nothing happens. I don't know if it's getting any power - the red light does not come on.
    Is there an internal fuse anywhere inside the machine? I checked the PC Board and did the "Factory Reset", but without any luck.
    If the PC Board battery is the problem, where can I order a new one?
    Thank you in advance - this board has been terribly helpful already!
  • Troy Dean Wiler
    Troy Dean Wiler Aug 08, 2012
    http://www.scribd.com/doc/66216795/Diagn...
  • Troy Dean Wiler
  • Quentin Vasseur
    Quentin Vasseur Jul 28, 2014
    The Posting by Dave Kristol worked perfectly! One thing worth mentioning for the long term fix is that capacitor C13 is bulging and about to explode, this will need to be replaced, bad ESR rating for the capacitor.
(N.B. I think there may be two variants of the Ultimate Plus, TR2500BC. They can be
distinguished by the number of rivets in the pan, 3 or 4. Mine has 3.)
I had a similar problem. Holding down the Reset button and plugging
or unplugging the machine didn't work for me. (Note: I've been
pretty careful to hold the Reset button when I unplug the machine
after baking a loaf.) This procedure worked for me:
1. Unplug the machine.
2. Remove the plastic keypad housing. There are three screws: left,
right, rear. (Note: One has a different thread from the others.)
3. Rock the housing back and forth to remove it.
4. Remove the white protective cover. It has two screws.
5. (You *did* unplug the machine, didn't you?)
6. Identify the ribbon cable and locate where its connector seats on
the circuit board.
7. The circuit board has little printed labels opposite each pin.
At one end are the labels GND, VCC, VDD, in order.
8. Short together GND and VCC with a small piece of wire by sticking
the ends of the wire into the top of the connector to touch the contacts.
9. Do the same with GND and VDD.
10. The machine should work now. With the keypad housing, circuit
board, and cables safely away from the metal body, plug the machine in.
You should hear a beep, and all should be well.
11. Rejoice, be glad, and make some bread.
Posted on Oct 12, 2008
  • 6 more comments
  • afe7 Dec 25, 2010
    I tried this and it WORKED....awesome. There is not a reset button on the printed circuit board that I can see...also no battery. But shorting the GND to VCC and GND to VDD made it beep and reset itself withing a few seconds. THANKS, Ron
  • WDM08 Feb 26, 2011
    Feb 2011: I tried this and it worked. The screw on the outside right has a different thread, as noted.
    I had difficulty removing the housing. I pushed in on the silver/bottom part and the housing popped off. I used a pair of scissors to make the connections.
    To Breadman: Add a Reset button on the bottom!! This is a design flaw.
  • synthman Mar 26, 2011
    I can't believe it! I found something on the internet that actually does what it says - it works!!! Dave Kristol, you are a genius and my wife loves you! Thank you for bringing our machine back from the dead!
  • Rick Paquin Jan 02, 2012
    Thanks Dave. That did the trick!!
  • Flaria Parker
    Flaria Parker Jan 09, 2013
    Thanks Dave!! Now working like a charm <3
  • Quentin Vasseur
    Thanks Dave, did the trick! You may want to add to replace C13 Capacitor as mine was bulging and is most likely the long term fix.
  • Andrew Middleton
    Andrew Middleton Jan 18, 2015
    Holy Cow! Never done anything like this before and this worked like a charm! Back in the bread making business thanks to you Dave!!! I owe you the drink of your choice ;)
  • Thomas
    Thomas Apr 18, 2015
    Just tried this and it worked perfectly. Apparently the company has never heard of blead resostors. LOL
  • 3 Answers
Don't try this unless you know what you're doing. But, if all else fails, give it a shot. I have a TR2500BC next model version up with the same problem. I tried the fixya solutions for my model, but none of them worked. Since I still had power to the light when I opened the lid, I assumed it was a problem with the keypad microprocessor. With the breadmaker plugged in, remove the ribbon cable connector connected to the PCB board. This will short the pins leading to the keypad. You might have to touch the connector to the pins on the circuit board a few times to make the microprocessor go "wacko" and reset itself. Once you hear the beep, the display should be working. If the convection fan or motor starts running while trying to get the display to work again just hit the reset on the keypad and choose any cycle and hit the start button. It may take 30 seconds or so for the machine to reset itself to normal operation. If anyone knows which pins to short out, I can solder in a reset button, so if this ever happens again I won't have to open the control panel. Or maybe the keypad needs to be properly grounded.
Posted on Mar 16, 2008
    Problem Solver:
  • 6 Answers
The microprocessor in the keypad probably needs to be reset. With the unit unplugged, remove the keypad housing (one screw in back, one on the left side, rock it up enough to get a small screwdriver inside, then push back the soft plastic fingers to release the housing -- force it a bit, you won't break it). You do not need to remove the bottom cover.
Remove the keypad cover (4 screws) and the PC board (one screw). You'll see a factory reset button near the middle of the left side. Press and hold that for a couple of seconds.
If you want to test the unit before re-assembly, hold the PC board so it doesn't short against anything (there's nothing more than 5v on the board, so you won't get shocked), and plug the unit in. The display should appear. Unplug the unit, re-assemble, and then bake some bread!
There is also the possibility that the backup battery on this PC board is bad. Check it with a voltmeter -- it should be about 5v.
Posted on Jan 26, 2008
  • Mike McBirney Oct 04, 2008
    The button is on the left side of the circuit board, just to the lower left of the blue battery. It's the only button that's not in-line with the other buttons, and cannot be accessed by the front panel pushbuttons.
  • Lynn R Guerra
    Lynn R Guerra Feb 10, 2015
    perfect solution! Thank you!
No reset button other than the one accessible from the top with keypad in place, and no easy access to the circuit board to short the pins. However, disconnecting, then reconnecting the keypad (three cables - the ribbon and two others) fixed the problem. Thanks to this board my problem is solved.
Posted on Feb 23, 2012
  • 4 Answers
Hold down the start button then switch power on.
Try other buttons for different models if no joy.
It reset OK for me
Posted on Jul 09, 2008
I have had this problem and finally came across a representative from the manufacturer who knew what she was talking about. The problem I had was that when I was finished with a loaf of bread, and turned it to "off", I didn't hold down the off button long enough so, what happens is that the machine will continue in that mode of operation you were in previously to the end of the cycle. It has something to do with the inner workings of the memory. For instance, if you shut it off right at the end of the cycle, there is usually a warming cycle etc. that it goes into, and if you don't hold down the off button for several minutes, the machine doesn't know it's at the total end of the cycle yet. So you actually should wait for another 20 minutes or + before trying to start it again. Does that make sense. Anyway, it worked for me. Good luck. MB from Michigan
Posted on May 21, 2008
    New Friend:
I had this exact same problem. The display panel was blank, but the light would turn on when the machine is opened. Holding down the Start button or the Reset button had no effect. Before opening the machine to fiddle with the electronics, try this: Per the instruction manual, there is a backup battery that will maintain the bread machine's memory for 7 minutes in case the power shuts off. So try unplugging the machine for 7 minutes (actually I waited 10 minutes to be sure), and then plug it back in. I got the power on beep, and the machine powered up normally.
Posted on Jul 14, 2017
    New Friend:
What worked was plugging in the machine with the ribbon cable unplugged. Got the beep right away.
Posted on Jul 12, 2014
    New Friend:
I had the exact same problem with my bread maker. It had the initial beep on startup, but no display and the buttons did not work. After taking the machine apart I tested the vdd and vcc voltages with a multimeter and noticed that the vcc was low around 1.3V. It should have been close to 5V, just as Vdd. I traced the issue to a faulty diode D14 on this board. I replaced it with a 1N4001 and the machine came back to life!
Be careful if you attempt this fix, and unplug the machine because the AC mains is directly connected to this board where the relays are.
Ps. BTW there is no battery in the machine. Those black and silver round things are capacitors.
Posted on Aug 13, 2013
MIne was dead new out of the box. I ended up running a dental pic along the solder joints of the two microprocessor chips and it worked. Must have been bad soldering.
Posted on Sep 14, 2012
    Problem Solver:
  • 15 Answers
I had the same problem - light in the oven portion came on, but display was blank. I followed the instructions given by Dave Kristol, which worked perfectly, thanks, Dave!
The one thing I would like to add, and this is for the sake of people who are willing to try to fix things like this but don't understand anything about electronics or circuitry (like me): For Dave's steps 8. and 9., he means that you should *temporarily* short the connectors - do not leave them connected! The point is only to "reset" the circuit board with the power off. I nearly (permanently) shorted out my poor breadmachine, but thankfully I had my electrically adept husband inspect my handiwork before plugging the machine back in. (His reaction: "Uhhh, I don't think you want to leave those connected...")
Posted on Dec 29, 2009
I have the big silver breadman ultimate +. My wife made a loaf today and when she tried a 2nd loaf tonight it would not beep when plugged in. The light would work when the lid was lifted. I took it apart but no reset buttons. The power on the 1st power circuit bd comes from the transformer on 2 brown wires and 1 white one on a heavy connector on the corner of the bd. The outside solder connector had a cold solder and I resoldered it and wa la it beeped and is now making bread. I could see the cold solder because there was a ring in the solder surrounding the peg and the other pegs had a smooth shinny solder flow around the peg. REMEMBER TO ALWAYS UNPLUG MACHINE!
Posted on Nov 27, 2008
This fix worked fine.
Posted on Mar 15, 2008
Main control panel does not power but inner light is on.
The light is probably powered directly from AC but the display is dependent on a (probably primitive) small power supply which may be separately fused internally. If you find no obvious fuse inside, you really need a multimeter to check after opening the housing. You can buy these now cheap digital meters at auto parts stores or electronic outlets.
Once you have one, you could comment back here for further guidance. It would help if you attach a snapshot of any boards you find inside.
Mar 28, 2010 | Breadman TR2200C Ultimate Bread Maker
Lost manual for breadman ultimate bread maker
I found the info on the internate. I have a copy of the book in my files.
Went directly to the manufacturer.
Jan 09, 2010 | Breadman TR2200C Ultimate Bread Maker
I need manual and recipe book for breadman ultimate, model TR2200
Found it online at http://lee.org/cooking/Breadman Ultimate Manual TR220C.pdf
Mar 05, 2009 | Breadman TR2200C Ultimate Bread Maker
Breadman tr2500bc pan popping out
I read in a review that the pan can warp if you read instructions because it said to fist run the machine in quick bread mode to clear factory coating. Review said to run in quick bread mode with lid open so it doesn't overheat, heat warps the pan, so it pops out . However manuel never mentions to leave lid open. I just got one and hope they are right. I just ran it new no ingredients quick bread lid open...
Nov 15, 2008 | Breadman TR2200C Ultimate Bread Maker
We have the 'breadman ultimate' and have lost the paddle.  Please advise how we can replace it, thankyou
I had great success in finding what I wanted for my breadmaker at http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Nov 12, 2008 | Breadman TR2200C Ultimate Bread Maker
Breadman Ultimate - finding a part
http://www.nelsonappliance.com/BreadMan+Mixing+Paddles+for+Bread+Maker+(20145).html
Look up the link and order.
Mar 06, 2008 | Breadman TR2200C Ultimate Bread Maker
Breadman Ultimate Plus TR2500BC
i need the bread pan from breadman ultimate model tr2500bc
Dec 08, 2007 | Breadman TR2200C Ultimate Bread Maker
Breadman TR2200C Ultimate Bread Maker Logo
3,532 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Irene Tulloch
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
