Question about LG RU-42PX11 42 in. EDTV-Ready Plasma Television
TV changes input and sound on its own
The TV will automatically change inputs and then the volume increases on its own to level 100. I can then change the input and volume manually from the TV, but after 10 minutes or so, it does the same thing all over again. Please help!!?
    Scholar:
  • 87 Answers
The only simple thing you can do is to check the manual buttons on the set for any sticking. When pressing a button down you can feel the detent.(click) When releasing the button it should raise up freely. Sometimes while cleaning the cabinet moisture gets on the switch assembly under the buttons causing random activity. I have experienced three common causes for your problem. 1 sticking buttons 2 defective switch assembly. The assembly can be unplugged from the circuit to see if the problem goes away. 3 a problem with the microprocessor that controls the functions.( requires a qualified tech to repair
) hope this helps
Posted on Dec 12, 2007
    New Friend:
I bought my Toshiba t.v two years ago and i don't use it often so it's brand new. it was acting up last night.. it automatically changed inputs and then the volume increased on its own to level 100. i unplugged it from the circuit and it is working fine now. thank you so much. you saved me a lot of money :)
Posted on Jan 08, 2014
SOURCE:
Pioneer vsx-d411 after 15 minutes the input changes automatically
Changes how? does it go to another input, change volume level etc?
Apr 02, 2018 | Pioneer Audio Players & Recorders
When i first turn on tv sound is fine . then it will drop down in volume badly .
Many newer types of TVs have what's called "Volume Leveling", which means the TV automatically lowers the volume if a sudden increase in the broadcast signal volume is detected. Check to see If "Volume Leveling" is present on your TV and currently turned "on". Refer to your owners manual for this. It should be in the Audio section in the menu on your TV. Turn the "Volume Leveling" to the "off" position to disable "Volume Leveling".
Jan 23, 2016 | Televison & Video
The audio output level is too low. How do i increase it? I have to turn the volume up on the TV almost maximum to hear a "normal" level of volume.
my experience says that the VCR/DVD recorder does NOT has a volume setting inside. Cables may be bad or connected to wrong input but most likely, the TV has a setting for the volume for any source and that is probably set to mid-range like on a PC sound control panel. Go the audio setup on the TV and see if you can adjust the level for each input.
Mar 03, 2014 | Memorex MVD4544 DVD Recorder/VCR
How to connect a vocal processor to a peavey6 mixer
Set the voice input level on the voicelive2 by following this guide from the live 2 manual... Step 4: Set Mic Level This step informs VoiceLive 2 how loud you plan to sing with your particular mic. We'll use VoiceLive 2's automatic MIC GAIN feature to quickly set the optimum level. 1. Press and hold the REVERB footswitch 2. If you need to activate phantom power for your condenser mic, adjust the onscreen PHANTOM parameter which will restart the level test 2. Sing for five seconds with peaks that are as loud as you plan to sing 3. Follow the prompts in the display to finalize mic level setting, cancel or redo the procedure During performance, if you see the CLIP indicator light in the HOME screen, you can return to the automatic
MIC GAIN feature to adjust the input level.
When input level is set on the voice live ;
on the mixer set
the gain control to 12 o'clock position and
individual channel volume level to 7 ....raise the master volume
slider to hear mic input at desired level and without feedback
Jan 15, 2012 | Peavey PV6 Mixer
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Low Volume using Kaoss Pad Mini while DJing
I'm having the problem too...I'm thinking that maybe getting the DC adapter MAY fix it though as stated in the Manual: "...The output level of the mini-KP will be smaller than its input level. This is because the attenuator circuit is connected at the input section, considering that the mini-KP is used on battery power." so maybe the dc connector will increase output volume?
Aug 22, 2009 | Korg Mini Kp Kaoss Pad
Faint sound when watching TV with Bose GSX 321 System
I connected my surround sound to the audio output on my samsung tv and it works fine. Of course I don't have an hdmi input on my surround sound system because its an older model, but it works great. Just got to put the surround sound to audio instead of dvd or tuner setting
May 07, 2009 | Bose 3 2 1 GSX System
Volume when on tuner is very different than when on DTV
Under the input menu, there is a volume trim function which allow you to increase or decrease the volume level of each input. It is designed so that the volume of different components can be matched to prevent a blast of sound when changing to a lounder output. You can increase the alevel of the dtv input, and decrease the level of the tuner. Tuner volumes are usually high.
Jan 24, 2009 | Yamaha RX-V1400 Receiver
Low audio through tv speakers
It sounds like a connection or signal level problem, your audio system may have a greater sensitivity than your TV, has the DVD got an output volume level to adjust, some do via their remote control also some TV's have independent volume levels for their inputs within menu settings.
Looks to be phono audio so if its none of the above then you will need a small audio pre-amplifier to increase the signal level, though for my thoughts this might produce a buzz problem because an amplifier might pick up stray noises from the TV or DVD.
Amazon or ebay may help there for small units, in a metal box is best for screening, it would not require a massive pre-amp with high gain, a battery type would need to be powered by AA types for long working periods if you go that route as a PP3 will fail over extended working time.
Hope this helps........
Jan 18, 2018 | Toshiba SD-2700 DVD Player
Using headphones with Logitech X-230 speakers
I really don't know, because some of the newer gadgets come with fixed volume control due to law suits, ect. Try to see if you can bring you TV menu up and see what the sound setting is.
Dec 25, 2007 | Logitech X-230 Computer Speakers
Open Questions:
See all LG RU-42PX11 42 in. EDTV-Ready Plasma Television Questions
LG RU-42PX11 42 in. EDTV-Ready Plasma Television Logo
232 people viewed this question
Ekse
