Dell Dimension 8400 PC Desktop
Problem for Dell Dimension 8400 PC Desktop
Dell dimension 8400 fan runs at high speed upon
By lvang on Aug 19, 2009
dell dimension 8400 fan runs at high speed upon power on. fan continue to increase speed very loud unable to power off with power switch
Comments:
Aug 19, 2009
- I was doing research on the internet. It says to replace the motherboard. Luther Vang
Best Solution
posted on Oct 12, 2009
Very Helpful)
slafauci
Rank: Apprentice
Rating: 100%, 2 votes
I too experienced the Dell 8400 high speed fan problem. I purchased some CPU thermal compound, cleaned the old hardened compound from the CPU and heatsink with isopropyl alcohol and applied the new compound according to directions. This solved my problem.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Aug 19, 2009
Very Helpful)
jdensonjr
Rank: Guru
Rating: 87%, 13 votes
You need to replace the fan because it is bad and will only get worse until it no longer works. The noise alone says that it is bad. Any computer store will carry them for a cheap price, so no reason to worry. Good Luck.
Fehdi
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
Helpful)
bob_computer
Rank: Guru  Dell Computer Hardware  Expert
Rating: 87%, 1268 votes
Your fan speeds up and slows down in response to temperature inside the computer. More so the CPU.
I would suggest getting a can of compressed air made for computers
take it outside, take of the side and blow all the gunk out of there, Really go to town around the fan (you might want to wear eye protection)
While you are in there just check that the CPU cooler itself is not loose
If it is it will have to be re-seated.
If it needs re-seating don't just take it off and put it back on as that might make things worse with your temperature problem they have to be cleaned and new thermal grease put on ($2-5)
DON'T remove the CPU just the fan/cooler assembly.
You must clean both the surfaces without scraping anything off. Use isopropynol alcohol and cotton bud sticks until both surfaces are clean, you can use your finger nail to scrape harder residue if you wish but nothing else.
DON'T pour the alcohol over the CPU
Now apply some new thermal grease (most computer shops have it)
Be careful about how much you put on
Here are
some basic instructions
Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
If everything went to plan you should now be back in business
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 8400 PC Desktop
Questions and Unsolved Problems for Dell Dimension 8400 PC Desktop
Do you recommend Dell Dimension 8400 PC Desktop?
Answer
Answer
When the computer comes on its giving the data error message
Answer
I have an AcerVeriton M264 and I bought a graphics card for it yester day and installed it but all I... (More)
Answer
can not find lead or plug to connect to tower
Answer
I cannot get like super multi-blue (LG) to play blue ray disc
Answer
My Medion MIM 2260 will not start when when i push the start button, it was working ok yesterday... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktops Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
