Question about Lexmark X2250 All-In-One InkJet Printer
Printing in red ink only
My printer is printing only in red despite having a new black cartridge
  • 2 more comments
  • ashvinb Aug 19, 2008
    My lexmark Z612 is printing only in Red with a color 27 cartrige. I am printing a word document where all fonts are in black color(default).
  • Anonymous Aug 26, 2008
    my printer is alos printing in red only although selected text is of black color...
    Please provide solution asap...
    Thanks
    I have the same problem...
    my printer is also printing in red color only although selected text is of black color...
    Thanks
  • skeetmcdoogl Sep 01, 2008
    I'm having the same problem on the Lexmark x1270. This printer was never used. I thought maybe it was a driver issue. Possibly just faulty ink cartridges. Anybody have luck troubleshooting this?
  • 624 Answers
SOURCE: Black ink print failure after cartridge replaced
The Edge, -Clean the electrical contacts on the printer where the cartridge connects with alcohol. After it dries clean the same contacts with a regular pink, non-abrasive pencil eraser making sure you remove all the debris when done. -Its also possible there is an air bubble preventing the flow of ink. You can try inserting a full cartridge of ink in the printer and letting it sit overnight then running a nozzle clean job or two. Another alternative if you have a syringe you may want to try gently forcing ink into it. If you?re really desperate you can try drilling a small hole into the cartridge to give gravity feeding a hand. BE WARNED the air hole will let ink flow pretty well and you run the chance of making a mess. Before you pull the cartridge out of the printer make sure you cover the hole with tape so the ink doesn?t make even more mess. -Check the cartridge alignment making sure the contacts are mating to the printer. -If it still doesn?t work I would try cleaning your nozzles. Even though I doubt you have clogged nozzles its worth a try because of the following: If you search the Internet you?ll find that this specific model is know for failing to print some or all colors after about 1 ½ to 2 years of use, even with Epson inks. Most of the posts I?ve seen blame it on clogged nozzles but I suspect a good number of them, like yours, have another explanation for their failure. Ink jet printers use resistors to create heat to create a bubble in the ink to eject it out of the nozzle (Bubble jet) or in the case of Epson, vibrating crystals push ink into and out of the nozzles (piezoelectric). We?ve already cleaned the electrical contacts and cleaned the nozzles so what remain are defective nozzles, short between the nozzle and the controller board or a defective controller board. Since the printer is only worth 1 or 2 hundred dollars repairs at a shop or buying these repair parts can easily exceed ½ its cost. Hope something here works for you, I just recently had to toss a great printer too. Let us know what happens and please don?t forget to rate the posting.
Posted on Jan 20, 2007
agent1463
SOURCE: Colored Ink problem
Good day sir, My Lexmark z35 color printer doesnt work. I already tried to use the printer settings properly but still failed to print the color ink. Only black ink in printer is printing. Im still hoping that you have any solution for this. pls.. help. thanks!
Posted on Jun 16, 2007
  • 619 Answers
SOURCE: My Canon i455 will not print black ink
Hi , try to clean head until the black color will complete visible .clean also the ink retainer or tank replace with clean absorbent.
Posted on May 09, 2008
SOURCE: Printer not printing black ink
The problem you are all having is with the print head (The black tray that your ink cartridges sit in).
Most of the time a simple cleaning of this will correct the problem, if it does not then you will have to call Kodak support and they will send you out another print head.
But lets try and see if we can get your troubled one to work again by following these steps...
1 - turn printer on and open the lid as if you were going to change the printer ink cartridges.
2- when the ink tray moves into the center and stops, remove both the black and color cartrdiges from the print head.
3- To remove the print head simply place your left thumb inside the head all the way to the left facing up and pinch the upper left lip of the print head to release it, then pull the entire tray out with your other hand ( there is a release inside the tray above the sticker of a finger and bullseye to the far left in the upper left corner inside the tray)
4- With the tray now removed be sure to look at the bottom and you most likely will find a build-up of black ink... clean this off using DRY paper towel as much as you can.
I used rubbing alcohol but if you do this make SURE it is completely dry before reinstalling.
5- Once you have cleaned the print head reinstall it in reverse fashion than you removed it, if you installed it right you will hear a solid CLICK noise.
6- replace the ink cartridges you removed if they still have ink in them and then close the printer lid.
7- You may get a notice that there is a new printer head and or cartridges and it will want to align and or calibrate the printer...be sure to do this!
8- Once the printer is recalibrated hit the menu tab on the printer and choose " clean ink head"... Do a deep cleaning 2 times!
9- Now try to print something that contains something black like a text document. If it works you are all set, if it did not then you will need a new print head from kodak. simply explain that you did the above steps and it did not work so that you can avoid support trying to run you through all this. They will send you a new one in 2 days.
Hope this helps and good luck!
Posted on Sep 04, 2008
vegakitten20
  • 685 Answers
SOURCE: Lexmark x2650 printer not responding to new cartridge
yes you have to have both of them then everything should be fine.if you have the color cartridge that is empty put it in for now and see if it will work it will let u know that it is empty but at least you will be able to print in black
Posted on Jan 04, 2009
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
Black ink does not print
If your printer have a separate printerhead with the cartridge just try to replace the printerhead of that printer it is because the printerhead have a problem on that.
May 28, 2010 | Brother MFC 240C All-In-One InkJet Printer
Wont print in black
Forgive me for asking this, but roughly speaking about 80 to 85% of problems involving ink or toner are resolved by the following:
Are you using a manufacturer’s factory new ink cartridge or toner? I
f you are using a refilled (worst possible choice) cartridge , toner or ink, or third party cartridge (2nd. worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Feb 27, 2010 | Brother DCP-110C All-In-One InkJet Printer
Brother mfc 5840 won't print clearly
you need to check the maintainence kit and see if it's full. Also if it isn't, use some iso-proponal alcohol and some q-tips to clean the print section of the cartridge and the cartridge tray.
Aug 21, 2009 | Brother MFC-5840CN All-In-One InkJet...
I have a Lexmark X1150 printer that is printing purple only.
Try the "better" or "best" print options - They give more ink - might do the trick - (beware it also prints a lot more slowly....)
I have not had that type of problem as such as both my ink slots work, but I did have purple/bluish print instead of black once - It worked for me -
Hope that helps -
I have also found that despite cartridges being new somethimes they are not as full as they should....
May 03, 2009 | Lexmark X1150 All-In-One InkJet Printer
Hpdeskjet 970cxi only prints blue and black
When refilling cartridges it doesn't always work. replace the ink for known good or new cartridges.
Feb 19, 2009 | HP DeskJet 970cse InkJet Printer
Standard black printing has faded to grey.
Could just be a faulty cartridge?
My hp printer developed a similar fault, and despite all my attempts to clean, realign, whatever, the problem wasn't solved till I fitted a new ink cartridge. It's worth a try.
Nov 15, 2008 | HP Officejet Pro L7680 All-In-One Printer
Brother MFC640CW
My printer wouldn't print in black even do i change the ink? what should i do!
Aug 25, 2008 | Brother DCP-110C All-In-One InkJet Printer
May 09, 2008 | Canon i455 InkJet Photo Printer
My magenta will not print well
Here's what you should do. Remove all ink cartridges. Get some rubbing alcohol, preferrably 91% proof (leaves less moisture) Get a couple normal paper towels. Check each cartridge for dried ink and remove it using an alcohol wetted paper towel. (The deep cleaning procedures aren't always effective.) The gold contacts on each cartridge should be gold when you are done. Use the same procedure on the gold contacts of the ink cartridge housing inside the printer. Take your time, do it well. If that does not fix the problem, then do the following. Switch the black and magenta cartridge. Some printers won't print when you do this, other printers don't know the difference. If your printer is the later, then attempt a print job using a page that has a line of both black and magenta text. If you see a black print, then the problem is your magenta cartridge (despite having installed a new one) If the magenta prints, then you know the magenta cartridge is good. If the magenta prints but the black doesn't, then you have a printer failure. Let me know your results. ZT3000 Beta tester of "0"s and "1's"
Aug 18, 2007 | Canon i860 InkJet Photo Printer
Lexmark X2250 All-In-One InkJet Printer Logo
564 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
