Question about RCA T25062 25 in. Combo
RCA T25062 On my TV when it cuts on the video won't work. For instance when I plug my cable into it sound will come out but no video the screen remains blank, but the menu screen will pull up. When I instert a VHS the video will cut on and cut over to the VHS and from then on the video will work until you eject the VHS then it cuts back to the way it was.
SOURCE:
techman
  • 3130 Answers
SOURCE: rca (tomson)t25062 keeps shutting off
First thing to check would be L401. Its a small coil from the secondary side of the horizontal driver transformer to the Base of the horizontal output transistor. Not a solder problem, You must take it out and scrap off the leads to remove the excess enamel paint the reinsert and resolder. Also check connections on the driver transformer too(horizontal). Next check for bad solder connections on the flyback transformer too. Good Luck PS please dont forget to rate this thread.
Posted on Oct 21, 2006
SOURCE: TV RCA SCENIUM D52W136D 52in
Problem solved, it was my green driver this time and only $25 to replace.
Posted on Mar 28, 2008
jomabug76
  • 1148 Answers
SOURCE: Digital compatable
You need a converter box or just get basic cable,, no its not digital,, its standard,,, thanks
Posted on Oct 05, 2008
  • 159 Answers
SOURCE: Jail bars in picture on analog cable tv only
this kind of intermittent noise has to be researched in the bench specially because the lines are there and then go out. it can be any component false contact, or solder joins.
Posted on Apr 15, 2009
  • 121 Answers
SOURCE: remote does not program tv/vhs combo
Try 835. 102 or 342 I hope those were helpful for you! Thank you for using Fixya.com........Enjoy your evening!
Posted on May 30, 2009
Does the Magic Sing ET19KV require a special "3.5mm to 3 RCA" cable? How to get it to work with aftermarket "3.5mm to 3 RCA" cable? "3.5mm to video only" works.
Hi
firstly check that the 3.5mm plug has the same number of contacts as the original there should be 4 segments
The three rca plugs are coloured red white and yellow
white is left audio,red is right audio and yellow is video
usually composite video.
some tv,s have an rca input some have two
and some have rca outputs
the sockets on the tv are also coloured to match the plugs
please check that the plugs are inserted into the correct
coloured input sockets
I would plug in the 3.5mm plug then the yellow untill i get video,once i have video i would connect the red plug untill i have sound,same with the white
Dec 03, 2017 | Televison & Video
I am having no luck connecting a DVD player to this RCA TV/VCR Combo model T25062 even though I am plugging into the correct audio/video outlets? Is it not compatible with a DVD player? Any suggestions? ...
Just to make sure, red/wht is for audio, and the yellow is for video. other then plugging them in you will most likely need to go thru the menu system and find the right location to except the feed from the dvd player.
Mar 08, 2011 | RCA T25062 25 in. Combo
I have a RCA T25062 TV Combo problem is, it was connected to 220volts. Do you have a schematic of chasis? Regards George
If 220 volts was connected to it, you might be looking at a few parts to repair that wont be available. It looks like the main power transformer and line input transformer are no longer available.
Sep 16, 2010 | RCA T25062 25 in. Combo
After a power cut, my samsung sv651b vcr won,t display tapes, it will auto install and display tv channels but without sound. it also appears to have lost some menus, is there a ''engineer menu'' ? (yes i...
try using rca jack cables if your not already doing so for video and sound. If you are already using rca jacks, then try using coaxil cable instead
Jul 11, 2009 | Televison & Video
Installation of wii
I had the same problem on a 32" rca crt. It worked fine, power was cut during electrical work and when it came back, "unusable signal." I went into the menu, then channel, then video input source. had to change it to the correct input "s-video in my case" Then it worked. GOOD LUCK!
Feb 14, 2009 | Nintendo Wii Console
Digital compatable
Oct 05, 2008 | RCA T25062 25 in. Combo
Universal Remote Code
when programing your remot control
program under vcr not tv
any uneversal rsa will do
May 25, 2008 | RCA T25062 25 in. Combo
No Picture on TV
? What is the model # off the back ?
Does the video work on the RF coax cable input?
For instance,as a test,can you hook-up from VCR coax RF out
to TV coax in,put the TV on Chan. 3,play a tape and get audio and video?
Are you matching colors when trying the A/V inputs?Yellow,red,
and white out of DVD to yellow,red and white in on back of TV?
Then select video input on tv===dial "00" or use input button on
original RCA remote. Are you using original RCA remote that
came w/TV ? Do you have the owner/operator manual for the TV?
   Sorry to ask so many  ?????   Let me know how it goes!!  T.
Oct 17, 2007 | Televison & Video
Rca (tomson)t25062 keeps shutting off
Oct 21, 2006 | RCA T25062 25 in. Combo
RCA T25062 25 in. Combo Logo
53 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
