It was random and now is consistent. Dishes no longer clean well either. I have run vinegar and bleach to clean it out over a full cycle that took 2 1/2 hours. Still not working. Is it the control board or do I need to pull the unit out and check the pump and connections?
the only possible reason it to take 2 1/2 hrs for a cyc is if you selected pots/pans and sani and or heated water... possible cures for this is use only power soap also jet-dri if unsure if dispenser is working on buy to solid hanging type then turn on hot water at sink b4 you start a cyc then if you have a watersoftner do not put more than 2 tsp of soap per opening on the soap dispenser then place a clear jar with no cloudyness, do not prewash the dishes b4 washing in unit only scrape and do not select the heated wash using liquid soap is able to be broken down in cold water so if this cleans your dishes and you inspect the clear jar you placed in the unit and not cloudy... this is the way youll have to use this unit if the cloudyness is able to come off the best way is to get citric acid available at most pharmacys wear glove and wash by hand if comes out saveable if not other are destroyed then as a last remecomended use product lemme fresh for dishwasher this is not a soap but assist in keeping a sheen on you siliverware and glassed
I have a Bosch SHE44C05UC/43 dishwasher about 2.5 years old. It just started recently to stay in the...
(More)
I have a Bosch SHE44C05UC/43 dishwasher about 2.5 years old. It just started recently to stay in the wash cycle forever. The number on the LED panel decreases in the normal fashion, but the dishwasher never changes from the wash cycle to the drain and then rinse. I have verified the incoming water temperature is adequate
timer changes super slowly and it keeps going on. We had to stop the dishwasher and even after we...
(More)
timer changes super slowly and it keeps going on. We had to stop the dishwasher and even after we disconnected it, it was still set at the same setting and we couldn't change it. don't know what to do. Please help! I don't have any of the manuals as it was a gift to us.
