Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
The tv is not turned on.
When i turn the tv on..it is not on, no power...nada, not even the lights on the front or inside of the tv.
Please help...it is a 8 year thing so i do not know it is feasible to fix it...
Thanks
  • weng2 Dec 03, 2007
    I have the same problem! Was watching the tv, fell asleep woke up turned off the sky and left the tv on. Went to turn on again and it just wont work have unplugged, fiddled with batteries but nothing seems to be working!?! The standby light is blinking and the button on the control is flashing when I press the on button but with no results, is the solution below the same for my problem? thanks! x
  • 55 Answers
IF YOU CAN , AFTER DISCONNETCTED THE PLUG (MAY BE DANGEROUS) YOU HAVE TO CHECK THE FUSE ON THE BOARD . IT MAY BE OPEN - IF IS IT YOU HAVE TO CHANGE WITH THE SAME RATE ( 2 OR 3.15A) AND AFTER TRY TO
SWITCH ON TV - DELFO
Posted on Mar 20, 2008
No power on LG TV
Could be power supply failure
Oct 16, 2016 | LG Televison & Video
Sony Trinitron color TV 36 inch
hello,
You should examine the input power of the TV. If you dare to open the back of the TV You should examine the by using the tester to test the continuity of the voltage input of the TV. i guess voltage regulator need to be tested.
Be careful high voltage inside the TV.
The best way is to contact the vendor of the TV or sony service center in your area.
may this help,
melnavz
May 12, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Hi MY TV HAS NO PICTURE OR SOUND, AND IT WAS FLASHING RED WHEN TURNED ON, BUT NOW IT WILLNOT EVEN GO ON AND I COULD NOT HEAR THE FANS ON EITHER, PLEASE HELP
Follow the money or this case the voltage--follow power cord into the set and to the power supply board--there will be a fuse there---extremely unusual for there not to be blinking lights if the set does not turn on---
May 28, 2012 | Sony KDS-60A2000 60" HDTV
Panasonic 60" LCD Projection TV Turns off every 1-2 hours
What is the model# of your TV?
Do you see any blinking (LED) lights on the front of the TV?
How many blinks?
Which LED light is blinking, Power, timer or lamp?
Nour Sabre
www.aaatvservice.com
Nov 15, 2011 | Panasonic Televison & Video
My TV just turned off and the red power light started to blink, why?
In most cases this error will dissapear by switching your television off at the wall and then switching tv on (via power button on TV front/side panel) "Whilst still switched off at wall outlet"
This will discharge all capacitors inside the TV
Now turn TV power button off then switch back on at the wall outelt then try to resume watching TV.
This solution may clear the blinking red light however if it does not it could be a more serious issue such as a blown fuse or even blown control circuit on the TV, In this case you should decide whether a repair is economical or to replace the TV.
This solution is based assumption this a CRT television and not an LCD.
Hope this helps
Feb 28, 2011 | Toshiba Televison & Video
Hi,experiencing a problem with my LG tv.It is left on Standby when not being watched (not turned off at the mains) and especially in the morning it has to attempt to turn on a number of times before...
Hello, Thank You for the opportunity to assist.
What you might want to do is unplug the TV from the wall, Allow it to rest there for 1-5 mins. Then plug it back into the wall then try turning it on.
If the TV does not turn on after that then there is some issues with the internal power supply inside. You issue could be caused by a internal component called a electrolytic Capacitor. But before we put the cart in front of the horse please get back with me if the power cycle did or did not work.
Then I will explain repair details with you!
Thanks for usinf Fixya.com We hope you found this information Very helpful!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jan 25, 2011 | LG 42LC2D 42 in. LCD HDTV
My samsung TV won't show any picture/sound.
When the TV is on, need to check the back light is on(go back side & look into through)
If the back light is on -- need to exchange the Main Board
no back light -- exchange the Power Board --- 95%
exchange the LCD panel --- 5%(inverter)
Jan 31, 2009 | Televison & Video
No picture
IF YOU NEED MORE INFORMATION ABOUT THIS MODEL
VISIT
www.tv-solutions.redtienda.net
Aug 07, 2008 | Zenith R40W46 40" Rear Projection...
No sound no picture
This is a common problem with older Philip Magnavox projection sets. Over time one of the IC chips on the main power board begins to fail. You can find replacment chips and repair instructions on www.magnavoxhelp.com.
Mar 28, 2007 | Philips 50P8341 50" Rear Projection...
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
24 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
