Question about Magellan RoadMate 700 GPS Receiver
Magellan roadmate 700
When I power the unit on I get a product demo that repeats. How do i get out of the demo screen so that i can use the device.
  • egser Dec 03, 2007
    How do I turn simulation off. I can't access anyhting other than simulation screen
  • 1,113 Answers
In configuration, under diagnostics, simulation needs to be turned off
link to web site
user manual link
Are maps unlocked?
https://www.magellangps.com/users/keysIntl/ssl_index.asp
Posted on Dec 03, 2007
SOURCE:
I have magellan 700 roadmate .it is not take signal.it just search and search.
I woud do a reset on the gps device....I have attached a link to the manual for the Roadmate 700....http://www.starbatteries.com/maro700vegps.html
You are going to look for this
Magellan RoadMate 700 Vehicle GPS View the product manual [Download- PDF, 1MB]
Good Luck
cbinny1
Oct 20, 2008 | Magellan GPS
All navigation units are GPS Receivers - that is - they receive satellite signals. So, no there is no difference.
Apr 19, 2008 | Magellan RoadMate 700 GPS Receiver
Roadmate 700/760 freezing/locking up
i use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it and they start to have alot of problems.i own now a mastreo 4000 so far so good no problems.
Feb 29, 2008 | Magellan RoadMate 700 GPS Receiver
Power wont come on
get a new unit like any magellan mastreo series 4000 or higher or roadmate 800 or higher,i had a 700 they start having alot of problems after i did my research on here.i have the mastreo 4000 and the roadmate 800 both work great.
Feb 23, 2008 | Magellan RoadMate 700 GPS Receiver
Demo screen
call the magellan company they will help you out,you can get it and try it but may be the unit itself.but call the company before you do anything
Dec 03, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700
J...
at the user menu press the "-" zoom out key the "+" zoom in key and the repeat button which is on top of your unit. Once your in the "hidden" menu, select reset user data.. your unit will reset and everything will be clean. If your trying to delete specific addresses I would use software to sync up and explore your MRM's files.
- If needed please ask more questions prior to rating -
Nov 03, 2007 | Magellan RoadMate 700 GPS Receiver
MAGELLAN ROADMATE 700 ON THE FRITZ.
I had the same problem with myRm 700, too. Solution : connect your unit into the AC power pack . Turn it on. Then reinsert an address into the unit while plugged into the 110 volt ac wall outlet power supply. You may need to repeat this operation a few times.
Also, used mine in my 18-wheeler using a ac to dc power inverter. It seemed to work everytime. Note make sure the ac to dc inverter you by has enough dc output to feed your Gps all the juice it needs. That ac to dc inverter can be used to run other ac powererd appliances, too.
Aug 30, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 freezes up
Try resetting user data. At user menu, press "-" zoom out and repeat button at same time. select reset user data, it will reboot automatically, then check to see if it is any better. If not, hopefully the software came with your unit and you can re-install it. Good luck and let me know if you need help with the installation. Daniel
Mar 03, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS unlockmap
Steve, In this case I would replace the Hard drive. But, since you probably don't have spare HDD's lying around.. do you atleast have the Software version? Some CD that came with it hopefully. If you do, then you may be able to stay alive here. Once your system boots to the user screen.. press + and repeat key at the same time.. "secret" menu now. ONLY IF YOU HAVE SOFTWARE TO INSTALL!! Select NAND FLASH FORMAT.. The unit will shut down after formatting. start up your software installer on computer. plug usb in.. and power on unit. This fix isn't %100, but it's the best shot you have. Otherwise you've gotta send it down here to Texas (where magellan repair is) and pay for the new hard drive. OR.. you could call customer service and see what they have to say. you'll probably be transferred to overseas.. --good luck with that -Dan
Feb 07, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
77 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
