Home | Acer | Aspire E360 PC Desktop | I am trying to rep...
Acer Aspire E360 PC Desktop
Problem for Acer Aspire E360 PC Desktop
I am trying to replace my motherboard
By annelyseq on Aug 19, 2009
I am trying to replace my motherboard with the exact same one but can't find what I need to order it. I've done searches but keep finding different answers.
Solution #1
posted on Aug 19, 2009
Not Rated)
joecoolvette
Rank: Guru  Computer Hardware  Expert
Rating: 92%, 567 votes
From my searching I find that it is a Nvidia 520LE.
With much tact and diplomacy, I would like to 'talk' to you straight up.
That motherboard is junk.
The motherboard is just an ordinary, ATX form factor motherboard. The most common used form factor size, used in personal computers.
Uses the Nvidia nForce 4 chipset.
By the time you buy an exact replacement motherboard, you will have spent the same, or more, than you could spend for a much better motherboard. (That will fit! Only the I/O shield at the back of the computer, may not line up with the motherboard below. The motherboard does come with an I/O shield anyway)
I found from my recent search also this motherboard,
1.http://www.newegg.com/Product/Product.aspx?Item=N82E16813135075&nm_mc=OTC-pr1c3grabb3r&cm_mmc=OTC-pr1c3grabb3r-_-Motherboards+-+AMD-_-ECS+%28EliteGroup%29-_-13135075
$70 US.
Instead of the Socket 939 processor socket, or AM2 processor socket, you have now, you will have an AM2+ processor socket.
If your processor you have now, is an AM2 processor socket model, it will work on this motherboard.
Your ram memory won't work. You have DDR ram memory. This motherboard uses DDR2 at 800MHz. (Or also can use DDR2 at 1066MHz)
This = a PLUS!
You can buy 2GB's of DDR2 ram memory that operates at 800MegaHertz, for $30 at Tigerdirect. (Patriot Dual Channel-PC6400. It's two ->1GB sticks of dual channel capable ram)
Uses the AMD (Nvidia based) 780G Northbridge chip, and the AMD SB700 Southbridge chip.
Here are the specifications of this motherboard straight from ECS,
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=866&CategoryID=1&DetailName=Specification&MenuID=1&LanID=0
Was this helpful?
Yes
No
Solution #2
Not Rated)
buffalonyman
Rank: Guru  Acer Computer Hardware  Expert
Rating: 85%, 715 votes
You cannot always buy the same motherboards because as technology changes, so do motherboards. I checked the specifications of your motherboard, and it appears that you have socket 939. Socket 939 is no longer manufacturered, but I may be able to find a new mobo that is socket 939. I just replaced my own Asus Socket 939 with a Foxconn brand.
Your processor will not work with the new AM2 sockets nor will your RAM be compatible. If you would like me to locate a compatible board, email me at buffalonymann@yahoo.com
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire E360 PC Desktop
Questions and Unsolved Problems for Acer Aspire E360 PC Desktop
Do you recommend Acer Aspire E360 PC Desktop?
Answer
Answer
I want to clean the inside of a sony v3s but I cant figure out how to get in. Can you help?
Answer
I cant get my Toshiba Equium to work off the mains. I have had it on charge over night to try and... (More)
Answer
how do you know if you get fcpga or fcpga 2 on the motherboard? it is socket 370 and fc pga 2 is... (More)
Answer
Cant find short cut for games on Pc Advisor
Answer
my computer just keeps clicking at the multi socket will not make a starting connection
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire E360 PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
