Amana ASD2625KE Side by Side Refrigerator
Problem for Amana ASD2625KE Side by Side Refrigerator
My refr. comp. is runs but the evap.fan motor do not run
By d1955on on Aug 19, 2009
The Refrigerator is running the Compressor is running but the Evaporator Fan motor not running the Condenser Fan is running also
Comments:
Aug 19, 2009
- The fan has no ice.The fan do not have 115v coming to it.
Solution #1
posted on Aug 19, 2009
Not Helpful)
hiltonjug
Rank: Guru
Rating: 92%, 202 votes
Look inside the freezer at the back panel. Is it covered with ice? If it is you most likely have a bad defrost heater and the ice has stopped you fan. If not you will need to replace the fan
Please rate this solution if it is correct. Thanks.
Comments:
Aug 21, 2009
- You will have to replace the fan motor. Find your model number and go to this site. http://www.partselect.com/ They will have what you need at a fair price and they take credit cards.
Please rate this solution if it was helpful.
Aug 24, 2009
- If you have not got 110v coming to fan, You either have a bad door switch or a bad timer.It's hard to diagnose these over the computer and with so little information. But I try to help. If I was there and see it and hear it, there would be no problem. I do this work every day and have for 18 years. Sorry I didn't get it correct the fist time.
Was this helpful?
Yes
No
Popular Solutions for Amana ASD2625KE Side by Side
Questions and Unsolved Problems for Amana ASD2625KE Side by Side
Do you recommend Amana ASD2625KE Side by Side Refrigerator?
Answer
Answer
refrigerator freezes up and the water freezes and the refrigerator does not cool and the freezor... (More)
Answer
I changed the water filter ran several pitchers of water as directed. The filter ok light does not... (More)
Answer
The refrigerator lights and fans are on but it will not get cold
Answer
My Amana side-by-side fridge (model SZD26VW) stopped getting cold about 10 days ago, I bought it new... (More)
Answer
I took it out to fix it because the bar that turns the ice came off. The front assembly with the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Amana ASD2625KE Side by Side...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
