Kyocera CS-2550 Black and White Copier
Problem for Kyocera CS-2550 Black and White Copier
Kyocera 2550 Scanner I'm unable to connect via browser
By erik_richard on Aug 19, 2009
I was able to connect yesterday and I went into the browser ip address and made some changes. Now I am unable to connect via browswer. I checked the settings at the scanner/copier. The ip and subnet and default address are correct. Tried restart, uninstall program and restart scanner. Not sure what to do. Thanks for any help
Comments:
Aug 20, 2009
- I can ping it from the desired computer. Yesterday when I was connected to it I used the quick setup from the cd-rom and the ip address along with the ip address of the copier and scanner and another copier showed up. Now the scanner ip address doesn't show up. I check all physical connections and restarted everything. I know it has something to do with a setting I changed while connected via the browser. I will check tomorrow at work on the installation cd to see if I can see a screenshot of the setting I think I changed. Is there any way to reset default settings at the machine? Thanks
Aug 20, 2009
- P.S. How do I print a service status page related to the scanner? Thanks
Aug 21, 2009
- QUOTE"Check the PC that you are trying to scan to amd make sure that the Scanner File Utility is up and running. You can check this by looking for the scanner icon in the bottom right corner, if it's not there click on start, all programs, scanner user software, scanner file utility, click on Scanner Utility to bring it back up, it just might have gotten closed accidently. If none of this works go into the control panel and click on firewall amd make sure file and printer sharing is checked, if it is you may have to turn Windows Firewall off to make the Scanner work."QUOTE Tried all of this previously, but tried it again step by step and still not able to view access through browser.
Clarification Request
Posted by FixinFax on Aug 19, 2009
Print out a service status page to verify the ip address. Can you ping it from your workstation?
Solution #1
posted on Aug 20, 2009
Not Rated)
bolinlamar
Rank: Guru
Rating: 88%, 50 votes
Was this helpful?
Yes
No
Popular Solutions for Kyocera CS-2550 Black and
Questions and Unsolved Problems for Kyocera CS-2550 Black and
Do you recommend Kyocera CS-2550 Black and White Copier?
Answer
Answer
Unable to print from an AS/400 to a sharp MX-453. Job ends on the AS/400 side when the print job is... (More)
Answer
Just purchased an old minolta EP4050. Says preventive maintenance time. Call for service and provide... (More)
Answer
I need a copy of a service/operators manual for Lanier 5025mdf
Answer
i used canon for my copy shop, I have a lot of problems with my machine. I brough it from second... (More)
Answer
how can i test the colour of canon IRC 3220N? how to test cyan color? how to test red color? how... (More)
Describe your Copiers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copier Experts
Top Copier & Fax Repairmen
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
