Question about Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens
Flash doesn't work
I have a new Canon EOS Rebel xti and last week while taking indoor photos, I deceided to try my external flash, after which time I can't get the built in flash to pop up or flash when I manually pull it up. What do you thing the problem is?
  • niksok2 Dec 05, 2007
    when I put the camera mode on P and press the flash button on the left side of the camera(the flash does pop up) and then press the shutter button nothing happens. The shutter will not open. Thank you for any help. Nick
  • Anonymous Dec 17, 2007
    I just had the same problem as yours. Canon eCare wants me to mail it back to its service center for a repair. :-(
    Problem Solver:
  • 9 Answers
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-upFlash doesn't work - 1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Posted on Feb 19, 2008
  • 52 Answers
Flash must be raised for AF assist.
Go to the setting and select which flash u need to use internal or external.
Posted on Dec 02, 2007
SOURCE:
Can I use Speedlight SB-50DX with Canon EOS Rebel Xti
It is not possible to use the Nikon SB-50DX directly on a Canon EOS Rebel camera. The Nikon flash gun hot shoe contacts do not match the Canon hot shoe contacts.
You can use the Nikon as a slave flash gun with a PC flash cord that matches the Nikon's flash contacts then connect the end of this flash cord to a flash trigger. The Canon's flash can then trigger the Nikon flash gun via the flash trigger.
Dec 27, 2011 | Nikon Speedlight SB-50DX TTL Flash
I have a canon rebel xti and the flash pops up but doesn't flash even when its dark this is when the setting is in full auto. any ideas? could the "bulb" have broken?
The short answer is yes, that is possible. It's also possible there is a circuitry problem. You will want to verify by trying to use an external flash and making sure it still works. The flash assembly is replaceable if needed.
Thank you.
Mar 08, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
With my Canon EOS digital rebel xti i have the
I think it got exposure problem so need to adjsuted exposure and shutter speed or need to replace either top cover or finder unit i recommend to repaire with canon authorised centrre only.
Jul 02, 2010 | Canon Digital Rebel XTi 10.1MP Digital SLR...
Canon Internal Flash will not Pops up and will not flash. Is there something I can check for or replace? I have a cannon rebel xti, the external flash works great, the button to make the flash pop up will...
Is it trying to pop the flash and making noise, or is there no noise at all?
If it's audibly trying and it won't pop up, it's stuck and something is blocking it. May need to send it in.
If there is no sound, then something is making it think that there's an external flash attached. Check out this photo here:
http://www.flickr.com/photos/dougpardee/133066175/
Doug Pardee on flickr may be able to help as well.
Hope this helps you! If so, leave me a rating!
Feb 26, 2010 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon xti and canon 420ex flash giving
Make sure the 420EX is set to E-TTL and set the camera to "P". If is need of more light, increase flash exposure to +1 or 1.5.
Oct 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
Why does the word, ''busy'' pop up on the canon rebel xti?
If the flash fires a full charge(eg. in a dark environment) then this message will appear whilst it recharges. If the message appears all the time and you cannot take a photo there is most likely a problem. Try taking some pictures without the flash card to eliminate that first.
Apr 13, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
The flash on my Canon EOS 400D won't work
Can you pull it up manually, Be careful when doing this but try opening it manually, it is possible that the catch for the flash is just stuck temporarily.
Jan 05, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel XTI Flash issue
Maybe there's a problem with your camera's pop-up flash.
Contact Canon Customer Support, and see what they can do for you. Probably they will point where you can get your camera repaired.
Feb 13, 2018 | Canon Rebel XT / EOS 350D Digital Camera
Built-in flash does not work
DO NOT MESS with a new camera (or any other new equipment).
Take/send it back to the vendor, The purchaser has rights also. Number one it must work.
I don't know your location but in UK (& Europe) we have very strict consumer legislation.
Mar 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel XTi/EOS 400D
I made the mistake of putting ahotshoe protector from my old camera on the new EOS 400D. It stopped the flash from popping up. I took it off and things now work.
Mar 11, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens Logo
458 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
