Question about Black & Decker D2020 Iron
My iron bahaves very bad
I have Black&Decker Digital Iran (D2020). After pluging in it heats up but after about 1 minut, it starts to beep constatly and it looks as if it is overheated. Moreover, it smells as if the electric cable start to burn inside. Is it anyway to make it work beck or I need to say Goodbye :)))))))
Thank you for your help
  • 2 more comments
  • jlwilson Dec 12, 2007
    On Tuesday, December 10, 2007, I had the same problem with my D2020 Black and Decker. I ironed a shirt and was preparing to iron a pair of slacks when my iron started to beeping continuously. I unplugged it and plugged it back up and it stilled beeped continuously. I thought it was shutting down, so I decided to just press over the slacks, mistake. The iron was actually overheating and ruined the slacks.
  • Tech22 May 11, 2008
    Same thing. The Black & Decker D2020 iron started beeping continuously, and then it smelled as if it was burning up. I had to unplug it. I really don't know what to do.
  • abbeyg23 Jul 29, 2008
    Mine did the same thing.  Beeped continuously and seemed to be overheating.  After we unplugged it and waited a day, it has now stopped beeping but doesn't heat up at all.  The display still works, just doesn't get warm.  It's only about 6 months old!
  • catalyst36 Aug 04, 2008
    Same problem. I've had the iron for less than a year. One day it seemed to over heat and was constantly beeping like it had it's own fire alarm--also bad burning smell. Turned it off. Turned it back on the next day and it does not heat up. Digital display works but no heat. Everyone has said the same thing. This product should be recalled. I never filled out the warranty information.
We have had two D2020 Black&Decker Irons that did exactly the same thing. I love the iron...but they have both lasted about 2 months before burning!
Posted on Jan 20, 2008
How do i get my consew ces-300 to produce steam?
Jun 28, 2014 | Black & Decker D2020 Iron
"Standby" on Digital Screen
Leave It Out To Fully Dry Dont Plug In or You Mite Damage The Chip Board
Jul 11, 2008 | Black & Decker D2020 Iron
The steam wheel on black and decker digital advantage is stuck in the no steam position
This problem developed with our iron within the last week. Playing around with it today, I discovered that the dial WOULD respond to "persuasion". I forced it, and it cooperated. Find somebody with a stronger grip and try it.
Aug 03, 2013 | Black & Decker D2020 Iron
My Black & Decker d2020 iron immediately goes to auto shut off and will not stay on.
test the 1) fuse heat and replace it
2) test the board if there are voltage , if there are the board can be faulty or repair.
3) see your instruc. manual go to the section troubleshooting and see what is wrong.
God bless you
Sep 30, 2012 | Black & Decker D2020 Iron
Lights are on but not heatingup
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Iron not Heating Up or not Working Right
Jan 14, 2011 | Black & Decker D2020 Iron
Iron Blck & Decker: model D2020. I would like to clean my iron because is stared to stain all my clothes. I just open the white plastic parte on the back, but i dont see any other screws or how to get...
No need to dismantle the iron. Just fill it with a 50/50 white vinegar/distilled water solution and allow the iron to expel all of it as steam. Rinse with distilled water and allow to pass as steam. If you use distilled water from now on, you should no longer have staining problems. Hope this helps!
Jul 18, 2010 | Black & Decker D2020 Iron
Good morning, My iron black & decker d2020 overheats, cools down and then goes through the process all over again.
The Thermostat has gone faulty. This can be replaced if you can get the parts. You need to contact, B&D indicate your problem, and exact, make and model, and inquire as to where you can purchase the parts, or if you do not wish to do it yourself, where to send it for repair.
Apr 19, 2010 | Black & Decker D2020 Iron
How do I clean my Black N Decker Advantage Iron
I work for Black & Decker customer service. Our number is 800-231-9786.
You can obtain a new manual for free by visiting Below is the section from the manual on care and cleaning of your iron.
Care and Cleaning
This product contains no user serviceable parts. Refer
service to qualified service personnel.
It is not necessary to empty the water reservoir after each
use of the iron, if you iron frequently.
To empty the iron, hold the iron over the sink with the tip
pointing down. Water will stream out of the water fill
• Unplug and allow iron to cool completely. Wipe the
soleplate and outer surfaces with a soft cloth
dampened in water and a mild household detergent.
Never use abrasives, heavy duty cleansers, vinegar, or
scouring pads that may scratch or discolor the iron.
• After cleaning, iron with steam over an old cloth to
remove any residue from the steam vents.
• Use the self-cleaning system to flush out minerals and
lint. If lint is allowed to accumulate in the vents, it can
scorch and cause brown spotting.
For Models D2000 and D2020: Clean about once a
For Models D2010, D2030 and D2035: A "CLEAN"
indicator will appear in the digital display to notify you
when your iron needs cleaning (A).
• Fill the iron as described in "How to Use" but keep the
water level below the MAX line. Plug in the iron, set
the temperature to 6, and stand the iron on its heel
rest. Allow to heat about 3 minutes.
• Unplug the iron and take it to a sink. Holding it
horizontally over a sink, move and HOLD the variable
steam dial in the CLEAN position ( ). There may be
some hissing and spitting while self-cleaning. This is
• Stay clear of HOT steam and boiling water as it comes
out of the vents while lint, scale, and minerals flush
through! Continue to hold the variable steam dial in
the CLEAN position until all the water has emptied.
If necessary, rock the iron side to side and front to back
to empty it.
• When finished, release the variable steam dial, stand
the iron on its heel rest, and plug it in. Heat for about
2 minutes to dry out any remaining water then unplug.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 03, 2009 | Black & Decker D2030 Iron
Black & Decker model D1600 iron error message
I work for Black and Decker customer support. Our customer service phone number is 1-800-231-9786.
If the unit isn't heating anymore, it needs to be replaced. Unfortunately, the unit can't be repaired. The unit comes with a one year warranty from the date of purchase. Please call the number above so that we can determine your warranty eligibility and help you any way we can.
Apr 27, 2009 | Black & Decker ICR200 Iron with Auto...
Black & Decker D2020 Iron - Burning Smell & Beeping
The iron is probably junk...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
May 11, 2008 | Black & Decker D2020 Iron
Black & Decker D2020 Iron Logo
575 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
