Rca proscan PS35152 - power on ?
Hi - My tv has started not turning on everytime. If I unplug it for awhile it seems to fix the prob for a few days & then it starts acting up again, now it wont start at all.
I noticed when i plugged it back in this last time, there was an arc in the prongs where i plug it into the power strip.
Also, the plug itself on the back of the tv seems kinda "wiggly".
There are 2 buttons next to where the tv plugs into the back of the set,
one says polarity and the other says high low off - I was going to push them
but am concerned if i put the switches in the wrong position I may be doomed.
I had the power supply replaced one year ago.
any suggestions? My husband turns into a monster when his tv doesnt work.
  • Luther Fairley Oct 10, 2008
    I have the same problem with my Hitachi set.
    It plays and sometimes when changing channels or any of the other functions it dies. I have also observed an arch at the plug when it is plugged in.
I have the same problem - I know it is the power supply and want to repair/replace it myself. Where can I buy the Power Supply or what goes bad on it ? Need part # and where to buy. Thanks!
Posted on Oct 25, 2008
  • race73ta Oct 25, 2008
    I have the same problem with my RCA PS35152 - I know it is the power supply and want to repair / replace it myself. I need the part # and where I can buy it. Thanks!
SOURCE:
I try to turn my proscan tv on and the the power comes on but before anything the tv blinks a d it turns off immediately, any advice?
About 51,900 results (0.55 seconds) Search Results
    My Proscan 42 tv is turning on and off by itself, changing ...
    www.shopyourway.com > Manage My Life > Questions
    Oct 16, 2012 - My Proscan 42 tv is turning on and off by itself, changing channels on it's ... that is next to the power connection plug is discolored at the board.
    Proscan/RCA 123882 Power Supply Unit (PSU) Boards ...
    ? 2:48
    https://www.youtube.com/watch?v=TC908vQ8jaw
    Jan 17, 2013 - Uploaded by ShopJimmy.com
    RCA TV Repair for Blank Screen TV Will Not Power On How to fix... I have a Proscan PLDED3273A-E. Looks like my problem is the L1 (brown spot on board) - any suggestions? ... before it turns off the audio still works and the image still comes out if I ...Recently I tried turning it on and I get no standby light.
Jan 25, 2016 | Proscan Televison & Video
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 23, 2013 | Televison & Video
Tv will not turn on leave unpluged a few days plug
The DM power supply board,probobally have those dying leakages gases about to be dead parts call capacitors.U have tools and know basic soldering?Tries website like Tvrepairworld.com to buy a capacitors kit,to replaced those dying capacitors belong in the DM power supply board.
Jul 19, 2010 | RCA Televison & Video
TV channel sound from a different channel
I just unplugged the tv from the power source and disconnected the cable connection and then reconnected them back after sometime. The TV started auto programming after turning on and that resolved the problem.
Oct 18, 2009 | RCA Televison & Video
RCA surround sound system probs
power supply problem.can you open the circuit board.
Jan 06, 2009 | RCA RT2380 Home Theatre System System
Small rca truflat tv won't turn on
the problem is that the tv was probably set to pwr on only with remote control.........i have the same problem and lost the remote...........BUMMER! Trying to figure out how to reset the programming without the remote.
hope that helps someone!~
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
Proscan 36 inch tv
Good day.
The spark the you see means that your wall socket is loose. Have it fixed by a qualified technician. With regards to your unit, it has an internal problem. In my experience, the power supply is not dissipating power to the circuitry. The problem is contained in the power supply, have it checked by a technician.
chris
Mar 04, 2008 | Proscan PS36500 36" TV
Audio not working on proscan ps61700
I have a GE 46 in TV that had the same occurrence. I believe it is a sign that the amplifier is overheated or stressed. The way I fixed mine was to unplug TV and leave off for a few minutes -then plug in. I discovered this by accident when the power went off one day and the sound returned (had been using my vcr audio output plugged into my stereo for weeks!) This fix will work for weeks-sometimes months-evidently resets the circuits inside the amp somehow. Last time this happened I also removed the back of TV and blew out the dust with compressed air while it was unplugged-still have sound 4 months later without a "reset"-so I'm guessing it did help .
Feb 29, 2008 | Proscan PS35660 TV
60in. rca rear projection tv
1) Reset will not help
2) Older RCA projection tv's usually produce a good pix,
so you could fix it....
3) light box chassis pulls out to go to shop for repair...
4) For more info = provide service # and chassis # off back..
Please rate this solution...............
Nov 13, 2007 | RCA P46924 46" Rear Projection Television
Won't Turn On
I bought a proscan tv about a months ago. yesterday it stopped working. The red button is on which shows that it is receiving power however, there is no picture nor sound.
Aug 27, 2007 | Proscan 19LA25Q 19 in. LCD Television
Televison & Video Logo
186 people viewed this question
Top Televison & Video Experts
Ekse
