Question about Apex Digital AT3208S 32" TV
MANUAL BUTTONS REMOTE CONTROL IS MISSING AND I NEED THE TV ON CHANNEL THREE (3) TO PROGRAM MY CABLE AND VCR TO IT. WHEN I TURN IT ON IT HAS CHANNEL TWELVE (12) CABLE AND THEN A BLANK BLUE SCREEN. HOW CAN I CHANGE THE CHANNEL TO THREE. I UNDERSTAND THAT THE TV IS NOT COMPATIBLE TO UNIVERSAL REMOTE.
Check the manual page at the link below for instructions on how to use the on screen menu to add channel 3 to the "active channels" list.
http://www.fixya.com/support/p197903-apex_digital_at3208s_32_tv/manual-18780/page-10
Posted on Feb 20, 2008
SOURCE:
I am trying to program my urc-4220 all for one remote to my tv and dont know how, i have an older zenith tv and need to know the steps to programing it to my tv
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program before starting step 2.
2. On the remote control,press a device key once (i.e.,VCR/PVR,DVD,CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press VCR/PVR once. After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes (starting on page 36) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn’t work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
Download the full manual for FREE with codes included from http://www.replacementremotes.com/One-For-All-Manuals/Download-FREE-URC4220-MANUAL-OPERATING-MANUAL.html
Aug 11, 2010 | One For All URC4220 Remote Control
Channel three is missing
Hi pasu, Normally if you can get/program Chs 2 and/or 4 as well the other channels, then Ch 3 should also be programmable. If this is not possible, perhaps you can try to manually program by selecting "03" and add to the memory "+" in some brands/model. If this is still a no go, perhaps you should seek the services of qualified professional since this would apparently be an internal software problem. You can also try a hard/full reset by unplugging the TV from the mains for couple of hours or as prescribed by your TV's user manual. If the TV has Video input features, a possible temporary work around the TV's Ch3 problem is to use the Video1 or the Audio/Video INput of your TV and use an old VCR to connect to your cable box. Remove the coaxial cable from your cable box to your TV and connect it to the RF/TV INput of your VCR. Use a 3 way RCA to RCA connector (usually Yellow, Red & White) to couple the Audio/Video OUTput of the VCR to the Audio/Video INput of the TV. Select Video mode in your TV (so it doesn't matter even if you cannot program Ch3). Power up your VCR, select Ch3 in your VCR's tuner. I assume that to select channels you wish to view, you use a remote and channel selection is done in your cable box. What worries me is "...went to a fuzzy black and white screen..." which is indicative of another fault. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 15, 2007 | Philips Magnavox SC3127N 27" TV
Tip
DISH VIP612 Program AUX Remote Code 2
DISH Solo DVR VIP612 Program AUX Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your receiver, tuner, stereo, second TV or second VCR using your remote's AUX mode? (Instructions to setup a primary TV or a VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a device with the AUX mode:
  1. Turn the device you would like to control on.
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR VIP 612 User Manual.
  3. Press and hold the AUX mode button until all the other buttons light up, and then let go. The AUX mode button will flash.
  4. Press 0 for a TV, 1 for a VCR, or 2 for a receiver, amplifier or tuner.
  5. Enter one of the three-digit codes from the tables in the manual.
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 7 with the next device code from the tables in the manual.
Your device control codes for your amplifier or other AUX device are now programmed into your DISH Solo DVR ViP 612.
Now you probably want to set your Dish Solo DVR VIP 612 Universal Remote up so that it always controls the volume of your stereo, rather than of your TV, regardless of whether it is in SAT, TV, VCR or AUX mode. Help for this remote control programming can be found here.
(Help for programming a TV or VCR using the TV or VCR mode buttons can be found here.)
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | Televison & Video
Tip
I hope that helps.
on Jul 05, 2010 | DISH Network ViP 612
JUST BOUGHT AN OPEN BOX TOSHIBA T.V. MODEL #26LV61OU LCD-HD AND IT DIDN'T HAVE A REMOTE. IT'S WORKING WITH MY VERIZON FIOS BUT I CAN'T CONTROL THE SOUND. WHAT TYPE OF REMOTE SHOULD I GET FOR THIS T.V. AND...
The remote that came with your Verizon FIOS can be programmed to control the sound on your TV. There are four different remotes can come with Verizon FIOS, and there are three different procedures to program them. I will give you all three to print out try to fix your remote control problem.
Does your remote look like either of these two?
If so you have a Philips universal remote. Here are the steps to find the code that will control the sound on your TV:
1) Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
2) Press and hold the device button for the device you turned on in step 1 (DVD, AUX, TV, STB) and press OK. Release both buttons. The mode buttons blink twice.
3) Press 922.
4) Point the remote control toward the device you are setting up and press the upper part of the Play button.
5) Press the Fast Forward button. If the device you are setting up does not turn off, keep pressing the Fast Forward button until the device powers off. (You can use the Rewind button to go back, if necessary.)
6) When the device powers off then you've found the correct code for that device. Press OK to assign the code in your remote control.
Note:
There are over 200 possible combinations for TV and DVD codes. The most common codes are tried first but you may still need to press the Fast Forward or Rewind buttons over 200 times to find the correct code for your device.
If you reach the end of the list of codes, the entire remote flashes twice and returns to normal operation. You can exit programming at any time by pressing the Exit button.
Does your remote look like this?
If so, your have a Motorola universal remote. These are the steps to find the correct code to control your tv:
  1. Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
  2. Note: The DVD/VCR button can control a DVD, VCR, or a combination TV/DVD, TV/VCR, or TV/DVD/VCR.
  3. Press and hold for six seconds the device button for the device you turned on in step 1 (AUDIO, DVD/VCR, TV, CABLE).
  4. The lights for each device button light up and the light for the device button you selected remains on.
  5. Press the Power button on your remote.
  6. The device button blinks three times then turns off.
  7. Press the Up arrow button (this is the button directly above the OK button, not the Page Up button).
  8. Did the device turn off?
    Yes: Congratulations! You've found the correct code for that device. Press OK to store the code in your remote control.
    No: Repeat step 3 and 4 until your device turns off, then press OK to store the code in the remote control.
    Note: To retry the previous code, press the Down arrow button (not the Page Down Arrow button).
If so, you have a Scientific-Atlanta universal remote. Here is how to find the control codes for your TV:
  2. Press and hold the Select button while also pressing the device button for the device you turned on in step 1 (AUX, DVD, VCR, TV, CBL) until the device button blinks twice.
  3. Press 991.
  4. The mode button blinks twice.
  5. Point the remote control toward the device you are setting up and press the Play button.
  6. The remote control tests each code in its library. The mode button blinks once each time the remote transmits a new code. When the last code is reached, the mode button blinks twice.
  7. When the device powers off, press the Select button.
  8. Verify the new code is correct by pressing the Power button.
    Did the device power on again?
    Yes: Press Select to assign the code in your remote control.
    No: Turn the device on and press the Channel Up or Channel Down button to step forward or back to the correct code. When the device turns off, press Select to assign the code.
___________
One of those three should work for you.
Hope that helps.
Oct 02, 2009 | One For All URC-3021 Remote Control
Need remote code for 22lv505 for dish network
Your code is 750....... Program the remote control in TV mode and then in VCR **repeating the steps** (or AUX - press 1 before entering the DVD code) mode.
How to program your dish network remote for your tv:
1. Use the device’s buttons or its remote control to turn on thedevice.
2. Press and hold the mode button for the device you want the remote to control, for about three seconds. When all the other mode buttons light up, let go of the mode button - that mode button should now be flashing. For example, hold the TV mode button for a TV until all of the other mode buttons light. When you let go, the TV mode light will flash.
3. Only for the AUX mode, Use a number button to enter 1 for a second VCR or DVD player
4. Use the number buttons to enter one of the device codes that I have given you.
5. Only for Limited Mode, Press 1.
Limited Mode- allow you to only use the remote to Power, Mute, and adjust Volume on your tv.
You cannot change the tv channel when the remote is in limited mode. You can only power on your
VCR in limited mode
****Note: Skip this step if you do not want to use Limited Mode.****
6. Press the POUND (#) button. If you entered the code correctly, the mode button flashes three times.
7. Press the blank POWER button to test if the code works for the device. If it does, the device should turn off.
8. Turn the device back on and try some other buttons to make sure they work. Sometimes, the blank POWER button works when other buttons don’t. If the code works for other buttons
** Stop Here**
Let me know if this helps..
1388f48.jpg If I have helped you, dont forget to rate!!!
Jan 03, 2009 | Toshiba 22LV505 22 in. LCD TV
Tip
DISH Solo DVR VIP612 Program TV or VCR Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR 612 to control your primary TV or a VCR? (Instructions to setup a receiver, tuner, stereo, second TV or second VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a primary TV or a VCR:
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR 612 User Manual.
  3. Press and hold the mode button (TV or VCR) until all the other buttons light up, and then let go. The mode button will flash.
  4. Enter one of the three-digit codes from the tables in the manual.
  5. If you want to program Limited Mode, press 1. If not, skip to the next step. (You can add or remove Limited Mode later.)
  9. If the code didn't work, repeat steps 3 through 8 with the next device code from the tables in the manual.
Your device control codes for your TV or VCR are now programmed into your DISH Solo DVR VIP 612.
Help for programing a tuner, receiver, 2nd VCR, or 2nd TV using the AUX mode button can be found here.
I hope that helps.
My allinone tv remote
PROGRAMMING DEVICE CONTROL
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
then release SET.
4. Use the Manufacturer’s Codes (starting on page 18) to
For future reference,write down each working device
Here is a link to your manual:
http://www.ofausa.com/remote_manual/CTGA...
Dec 02, 2007 | One For All URC-3021 Remote Control
I have codes but no instructions
CBL/SAT,or TV).
then release SET.
Dec 01, 2007 | One For All URC-3021 Remote Control
URC-3021B00
CBL/SAT,or TV).
then release SET.
Nov 26, 2007 | One For All URC-3021 Remote Control
Apex Digital AT3208S 32" TV Logo
218 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Ekse
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
