My compact fridge is not getting cold and the fan doesn't seem like it is blowing strong...I have only had it three months...there is a little bit of air on the inside but it is not cold...any help will help...thanks
Comments:
Aug 21, 2009
- thanks...I took it back and they replaced it with no problems...thank you...
have a 5000 watt coleman generator pretty old but never used much , went to start it but electric...
(More)
have a 5000 watt coleman generator pretty old but never used much , went to start it but electric currentwas not there where should i start first thanks barri
I have a Coleman 1850 generator that will not turn over. The problem is that something is jamming in...
(More)
I have a Coleman 1850 generator that will not turn over. The problem is that something is jamming in the generator portion. How do I pull out the centre rotating part without damaging it?
Fan(s) run slowly and irregularly....stop after awhile. Motor replacement? Lubrication?Coleman...
(More)
Fan(s) run slowly and irregularly....stop after awhile. Motor replacement? Lubrication?Coleman powerchill 40 qt.
I have a coleman 564 and the fan is not running. Is it supposed to be running all the time? I bought...
(More)
I have a coleman 564 and the fan is not running. Is it supposed to be running all the time? I bought the extension cord for it and it said that when reversing polerization it ould heat but when I did, a burned rubber smell came out so I put it back the way it was. Is it just a cooler or also a heater?
Have older series 54 w flo-jet 2 pc carb. Had crack in float, replaced w/new one. Set float with old...
(More)
Have older series 54 w flo-jet 2 pc carb. Had crack in float, replaced w/new one. Set float with old needle seat. With carb upside down seals completely, can't blow air thru fuel inlet. With carb installed right side up of course, starts and runs, but once stopped, even with fuel shut off, will drain float bowl into air filter tube.??? Is this normal???
