Question about Zanussi FJD1666W Front Load Washer
Drum Bearings replacement
How do I remove and change the drum bearings?
  • 3 more comments
  • navyken Dec 30, 2007
    loud knocking when washer is on spin
  • Anonymous Jan 08, 2008
    How do you change the drum bearings
  • Anonymous Jan 20, 2008
    cant undo the centre bolt it is solid
  • Mogsey Feb 06, 2008
    The machine is rumbling badly. It is a Jetsystem 1600, Model FJD1666W Type number P6359639, I have changed the bearings several times on our old Hotpoint machine. Is this Zannusi fairly easy or difficult to do? any advice appreciated.
  • clan108 Sep 14, 2008
    I have an AEG Lavamat 74640 my husband can not remove the old bearings, does anyone know the best way to get them out? Thank you
This is Mogsey above, I have now renewed the bearings in my Zanussi Jetsystem 1600, Model FJD1666W. Had a man in to help. It really is a two man job and I put my back doing this with him. The bearings were much larger than previously encountered. Very! basically you have get out the residue water, release the door seal and (pipe attached) spit the m/c casing, unclip all hoses attached to drum, unclip all drum wiring ,remove belt (note position) remove motor &, lay to one side, withdraw nylon pins from shock absorbers, Look for and remove the little earthing cable set just inside the pulley rim. Carefully release drum/case supporting springs (mark positions top and bottom) and, drop drum/case onto some blocks and lift/pull/take out (really needs two people) (minding other modules). Split drum/case ring of bolts, remove front half (careful here not to damage the heater). take half containing drum outside, lay drum face down and use a drift to hit the socket headed screw securing pulley hard to shake up the taper. Remove this screw (needs good quality allen key) and use wedges to the force off the drum drive pulley. Support drum casing on blocks or put drum on its side, support the drum if on its side and use a heavy drift and hammer to knock through the drum spindle. Careful now to avoid grating hands on the sharp drum holes. With drum now removed place the casing drive end up (ensuring protuding heater is clear of the ground!) put a large bolt (head down) inside the first bearing and rest it on the edge of the inner bearing. Carefully working round the inner bearing edge use a hammer and the bolt head as a drift to knock out the inner (the larger of the two bearings and inturn the drum seal) (note seal postion). Turn over the casing and knock out the outer bearing from inside the drum casing. Clean all and check condition of spider/spindle & renew if damaged. Fit the new outer bearing then the new inner followed by the seal. Dig out the old and renew the (green) O ring seal between the drum casing halves. Replace all, but give a quick test run before replacing casing to ensure belt is positioned correctly. The job would have cost £115 which I think is well worth paying someone to do.
Posted on Feb 15, 2008
  • Mogsey Feb 16, 2008
    This is Mogsey above again! Upon reading this I decided to revise it adding even more hoping it might help someone. I have now renewed the bearings in my Zanussi Jetsystem 1600, Model FJD1666W. Had a man in to help as it really is a two man job and I put my back doing this with him. The bearings were much larger than previously encountered. Very! Basically you have get out the residue water, release/slide apart sideways the door seal clip ring (crocodile toothed) and undo the hidden pipe attached (you will need a pair of pincers to replace this pipe clip). Then spit the m/c casing by first undoing the two screws at rear of the top and sliding the top off backwards. Undo the linking straps now revealed covering the drum hanging springs noting the positions of all. Remove the 2 screws and white plastic bung/washers holding the bottom halves of the casing together and any other screws at rear of casing to enable the two halves to come apart. The power lead and inlet valves quadrant just lift out as one. Unclip or just twist out all hoses attached to the drum casing, unclip most drum/motor/heating wiring, remove belt (note position) and motor screws, motor then slides off its spigots. Remove motor &, lay to one side,there is no adjustment for the motor belt it is elasticated. Withdraw the 2 nylon pins from the two shock absorbers, Look for and remove the little earthing cable fitted just inside the pulley rim. Carefully release drum casing hanging springs (mark which way round positions top and bottom) lift drum to take weight off these springs, push screwdrivers through the looped ends and then thread rope or wire though the loops to improvise as handles. Using these with gloved hands unhook and drop each spring though its slot thus lowering the whole drum assembly onto some blocks. Then and lift/pull/take out the complete drum assembly (this really needs two people to avoid contacting with other modules and hoses etc). With drum assembly removed split the casing ring of bolts (need long extension bar to facilitate this easily), remove front half (be careful here not to damage the heater). take the half still containing the drum outside, lay drum face down and use a drift to hit the socket headed screw securing pulley hard to shake up the taper to aid removal/loosening. Remove this screw (needs good quality Allen key) and use wedges to force up and off the drum drive pulley. Support drum casing on blocks or put drum on its side, support the drum whilst on its side and use a heavy drift and hammer to knock through the drum spindle/spigot. Take care to avoid grating hands on the sharp drum holes. With drum now removed place the casing drive end up on blocks or slab but (ensuring protruding heater is clear of the ground!) put a large diameter bolt (head down) inside the first bearing and rest it on the edge of the inner bearing. Carefully working round the inner bearing edge use a hammer and the bolt head as a drift to knock out the inner (the larger of the two bearings and in front the drum seal) (noting right way round for refitting seal). Turn over the casing rest It on suitable blocks or a short piece of large pipe and knock through the outer bearing from the inside of the drum casing. Clean all and check condition of spider/spindle spigot & renew if damaged (particularly where the seal lip sits). Fit the new outer bearing then the new inner followed by the seal. Dig out the old (green) O ring between the drum casing halves and renew. Replace all, but when rejoining drum assembly bolts tighten opposite bolts working around the drum to pull it together evenly. When drum is back in give it a quick test run under power before replacing casing to ensure belt is positioned and running correctly. The job would have cost £115 and took 3.5 hours which I think is well worth paying someone to do. The original inner bearing fit is SKF 6307-2Z/VT223 ID 35mm OD 80mm 21mm thick. The outer one is SKF 6506-2Z/VT223 ID 30mm OD 72mm 19mm thick. The seal is marked CFW plus 47-80-11/13.5 plus RWDR KOMBI plus 12496610. Hope this all helps.
  • Mogsey Feb 19, 2008
    Mogsey again
    My apology I misread the bearing designation for the smaller outer drum bearing on the Zannusi FJD1666W. It should have read SKF 6306-2Z and NOT SKF 6506-2Z. Both bearings have shields on both sides.
  • 76 Answers
Whats the model number
Posted on Dec 04, 2007
Ive just replaced the bearings on my candy 6kg go 126-80 took just over 1.5 hours to remove and refit and that was a one man job i just removed the concreat weights and marked them up and in fact the machine is better balanced now then when i bought new .
BEARING KIT P/No 06015542 £15.55 PLUS £3.59 P+P
YOU WOULD HAVE TO BE MAD TO PAY SOMEONE £115 FOR A JOB THAT IS SO EASY TO DO YOURSELF AND SO CHEAP
Posted on Mar 17, 2010
Bearing replacement
One of the biggest jobs to do on a washing machine. Remove the drum from the machine, remove the washer drum, knock out bearings, replace drum spider (shaft) fit the new bearings, and drum seal, put everything back together again. Job for a experienced engineer.
Oct 03, 2014 | Washing Machines
How do you replace the bearings in the drum?
It involves a complete strip down of washer,literally down to the last nut and bolt.
Some models have one piece tub assy, so it is not possible to change the bearings.
Remove the top cover, and see if the drum is a one piece assy, if it is not, you should be able to see the screws securing the 2 drum halves together, if you cannot see any screws, then the whole outer tub assy has to be replaced, an expensive repair!!!!
tTo change the bearings, the whole tub assy has to be removed from the cabinet, and then the drum has to be split to gain access to the bearings.
Until you get to this stage , you will then be able to determine if the drum shaft is worn, if it is then this will have to be replaced.
All in all a long expensive repair to undertake.
Take my advice, and if the washer is more than 5 years old, then buy a new one.
Good luck.
Nov 07, 2010 | Hotpoint WMA48 Front Load Washer
The bearings on my Whirlpool Cabrio WTW6400SW3 make a racket on the spin cycle. The Whirlpool parts diagrams show that to replace the bearings, the entire drum is replaced. I can see one of the bearings...
Yes you can just replace the bearings but be careful. they say to replace the entire drum as the materials they are made out of is not very strong and you can distort or damage the drum when removing the bearings.
Oct 25, 2010 | Washing Machines
Dryer squeaks when clothes are drying
Squeaking can mean bearings going bad or the pulleys needing some oil on them. The pulleys can usually be accessed from the rear of the dryer. The bearings are a different story, you would need to remove outer casing of the dryer to remove the drum to get the bearings behind the drum. I would recommend trying to oil the motor and idler pulleys and if that doesn't fix the problem if your handy you can try to replace the bearings. Its a big job, the bearings are behind the drum and are screwed in from the inside of the drum. In order to remove the drum the casing of the dryer had to be removed, usually the front and the top (the top will sometimes tip back on hinges). After that the drum should slide out with the bearing assembly attached. Installation is the same as removal. {Note: If you find it to be too much trouble, I would just leave it squeak, other than being annoying it won't hurt anything. Also, some dryers have a compartment in the back where you can see the bearing assembly, maybe you can spray some WD-40 in there and see if it stops squeaking. The time you really need to replace the bearings is if your drum is loose, as the bearings have gone bad, not just squeaky}
May 12, 2010 | Dryers
Is there a reason for the bearings in a front loading machine to keep needing to be replaced
It could be that the new bearings are being fitted onto a worn drum shaft, this would soon cause the bearings to fail again.
If it has not been replaced, then it should be done so.
Jan 27, 2010 | Washing Machines
Hotpoint WMA54 - in middle of attempting to replace the drum bearings. I've split the drum apart and am attempting to remove the existing bearings and spider; however, I'm unable to separate/unscrew the...
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Jan 09, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Change Bearings for HotPoint WMA62N
Hi, I also have the bearing problem on a hotpoint wma and have just stated the repair job. I have found the following on different forums, so maybe it might help others. You do need to remove the drum and there are two different sizes of bearings 30mm and 35mm. To find the size you need you have to get to the bearings and measure them.
. Ok,Hotpoint wma series drum bearing failure.Firstly very common problem since i work on these things every day-i think there is a design fault-nothing new in this trade!What follows is
the sequence of problems in changing the drum bearings:If the machine has been thrashed into oblivion just changing the oilseal/bearings will have you back to square one within a
couple of months since you would`ve damaged the drum shaft as the bigger bearing of the 2 goes into shapnell mode!So you`d best change the drum shaft(in the trade known as the
spider) however this thing is aluminium usually held onto the the drum via torx headed screws either in steel or soft Al2 also-forget it as your not going to get these out unless your mega
lucky,what we do at work is to replace the whole tank/drum/bearing assembly which comes with a new element and belt ie the whole tank unit,the trade price of this part is less than
£100.00-you can draw your own conclusions as to the retail price as you wish.If you haven`t thrashed the machine you can get away with replacing just the bearings or easier still the rear
half of the tank(trade price 30.00+vat) in which the bearings are already fitted via the factory and reuse the existing spider/drum shaft so long as it isn`t damaged by disintergrated bearing
shapnell.I hope this clears up this problem for you.Please note that this machine`s filter which is at the rear doubles up as the air trap-the oval section 8" long semi transpatent plastic tube
thing-the part that allows the water to compress the air so turning off the level of fill at the right level via the round swt behind the soap dispenser-called the pressure swt-if the filter gets
bunged up the machine o/fills and either overfills or overfills and floods or tries to spin with aload of water still inside the drum or perhaps no spin at all.Hope this helps someone.
The drum comes out through the front on this one. Take off kick plate and remove screws holding front panel to frame. Take out soap drawer & remove screws behind it. Take off band
holding door seal & peel seal back. Remove 2 screws holding door lock &push lock through. Pull control panel forward at left side & slide to right to remove being careful with board &
wiring. Remove screws holding top end of front then lift slightly &remove front. Remove back panel & take wiring off heating element & pump. Disconnect the pump hose at the drum end,
disconnect the hose from the soap dispenser, note that wiring is fastened to the drum at several points and will need to be disconnected. Remove panel from behind control board then
carefully move everything away from the front of the machine, the drum can now be lifted clear.
Forgot to mention unplugging motor but common sense will prevail.
Mar 11, 2009 | Hotpoint WMA64 Front Load Washer
Bearing noise on Indesit WDG1295
you will have to open the machine lid to see if its a plastic drum or metal.
the metal drum is easier as it has a 'spider asssembly'. remove this after taking off the pulley by taking out the bolts that hold it and bang it off being carefull of the heater element. remove the bearings and seal and refit in reverse order you took it off.
i would not advise replacing plastic drum bearings as they are a pain, removal of the rear of a plastic drum easy but not putting it back !
Feb 01, 2009 | Washing Machines
Replacing rear wheel bearings on 1999 hyundai sonata
  1. for drum brakes with sealed hub(all one piece) remove lug nuts and wheel.
  2. spray penetrating oil around studs if there is a big phillips head screw visible remove it with impact driver/if not use big ballpeen hammer ,tap on flat of drum near studs(becareful not to hit them) until drum loosens(your creating a shockwave to loosen rust)
  3. once drum is off there are 4-bolts coming in from behind backing plate, remove them then hub should be able to be removed w/a little persuation from hammer.
with out sealed hub ,
  1. remove wheel
  2. remove dust cap,cotterpin,star washer(if equipped) do not re use cotter pin
  3. remove nut then washer, wiggle brake drum and front bearing will come out.
  4. put nut on shaft tighten 2-3 turns grab drum by sides and pull towards you this should remove drum leaving inner bearing/seal on shaft
  5. to replace reverse procedure making sure to pack new bearings w/grease(take drum and use long punch to remove bearing races, use race/seal installer to install new races
with disk brakes
  1. remove wheel
  2. remove caliper/bracket
  3. remove rotor
  4. remove 4-bolts from behind,tap old hub out
  5. reverse procedure
Jul 19, 2008 | 1999 Hyundai Sonata
Drum will not rotate
im confused as to why you think no drum rotation would be caused by bearings. typically worn bearings would cause noisy spin. only if bearings were completely seized would that cause no drum rotation. can you rotate drum by hand? if so bearings are not seized. can you hear motor rotate when you select spin? if not, then likely cause is motor brushes. do these simple tests and get back to me if you want. and bearings are quite difficult to replace on this machine
Apr 26, 2007 | Zanussi F1045W Front Load Washer
Zanussi FJD1666W Front Load Washer Logo
1,681 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
