Whirlwind -Air Cooler with Heater and Humidifier, FH-778 Air Conditioner
Problem for Whirlwind -Air Cooler with Heater and Humidifier, FH-778...
My A/C blows out hot air every couple days
By Anjel77 on Aug 19, 2009
My a/c is set at 78 degrees. it works fine and then starts blowing out hot air. i will turn it off before i leave for work and keep the ceiling fans on. when i get home, i turn it back on and it works fine. a couple of days later, it is blowing out hot air again. why?
Solution #1
posted on Aug 19, 2009
Somewhat Helpful)
pedigo_tyler
Rank: Apprentice
Rating: 75%, 1 votes
The only problem I could think of is that the air conditioning needs to be recharged as they call it because over time it will run out. You can usually go to a place like Firestone and they will do it (depending on how much you need) for around 100 or you can find a way to do it yourself you would buy either R134A or Freeze 12 that might be harder to get but cheaper
Was this helpful?
Yes
No
Solution #2
posted on Aug 23, 2009
Not Rated)
Squeegeeboy
Rank: Apprentice
Rating: 0%, 0 votes
It's freezing up. The evaporator is probably dirty and when it is used for a couple of days, it freezes up and the warm air you are trying to cool as woking its waya round the blocked fins and not exchanging heat for cold.
When you shut it off, the ice blockage melts and you re-start and it works fine until ice forms again. Get it cleaned!
(The House A/C unit evaporator, not the car at firestone?????)
Was this helpful?
Yes
No
Popular Solutions for Whirlwind -Air Cooler with
Questions and Unsolved Problems for Whirlwind -Air Cooler with
Do you recommend Whirlwind -Air Cooler with Heater and Humidifier, FH-778 Air Conditioner?
Answer
Answer
Just missing the piece that holds the vent in the window for an Everstar portable a/c. Is it... (More)
Answer
Installed a new Hunter thermostat a few weeks ago. All was cool (pun intended) until yesterday when... (More)
Answer
MPMI-10CR-BB6 DONT WORK THE AC DOES NOT TURN ON AND WHEN ITS PLUGGED ALL THE LIGHTS ARE ON, WHY ITS... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air... Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
