Check your "HI-LIMIT" switch on heating element,they can get defective
I had the same problem. Very tricking thermister. Most thermistor or temperature sensors start out in the 10k Ohm area. Fridgidare requires 50k. I had one that read 40k and it turned out bad. The board must recongnize the low voltage resistence of 50k in order to through the switch on the heater relay that is on the board. That sends the other leg of the 110 volt current to the heater
fixed dryer it was the thermistor .
the parts place gave a different model number to me'
all thermistors are not the same even if they read the same {mine was 50k ohms}.
