Question about Samsung DVD-V4600 DVD Player/VCR
Video channel how do i set up the video channel
    Guru:
  • 1,463 Answers
Hello dessy 367
have a look here might explpain better Online User Manual and Guide for Samsung DVD-V4600 DVD Player / VCR Combo by FixYa, Page #1
riz.
Posted on Mar 26, 2008
SOURCE:
Need to add amazon channel on roku
Amazon Instant Video on Your Roku - Amazon.com
https://www.amazon.com/gp/feature.html?docId=1000776221
Amazon Video Originals TV Shows Movies Help Getting Started Settings Your Video Library Your Watchlist. There's a problem loading this menu right now.
Amazon Video - Roku Channel Store
https://channelstore.roku.com/details/13/amazon-instant-video Roku provides the simplest way to stream entertainment to your TV. On your terms. With more channels than any other streaming player.
Amazon Instant Video ' Roku Guide
https://www.rokuguide.com/channels/amazon-instant-video The Amazon Instant Video offers a Watchlist that lets you queue titles for ... How do I get the Amazon Prime channel code to add this to my Roku manually?
add amazon channel on roku Google Search
Apr 30, 2017 | Roku Televison & Video
The tv is a RCA f20632se tv model I am trying to play my wii on it but don't know how to get to wii video screen please HELPPpPPp
From the image on that screen set is not on the video input--you may need the original remote but try this, cycle the set with the channel down button below channel 2 as some of these sets had the video input on a channel between 90 and 99.
Dec 20, 2012 | Televison & Video
I have a sharp crt tv model:25c-bs370,although i'm using cable signal which more than 100 channels,still the channel it receive is limited only to 35 channels...how to rechannel the unit?my tv came...
Hi,The Television from japan have no lowband channel,It can be rechannel but the channel additional is onlly the lowband channel it maybe add only 2 channel.So the best things you do is to buy and install a channel converter to your TV.A channel converter is 100 plus channel thats why you can use your cable to japan television.To install the channel converter you need to set your television to Video setting and use RCA connector and plug it to video/sound input of your TV and video/sound output of channel converter.The cable connected plug it to channel converter.
Jul 11, 2011 | Sharp Televison & Video
No audio
just check that the audio or this channel hasnt been set to zero and saved that way go to channel 4and select the volume up on the remote to ensure it is set to on
Jul 30, 2009 | Panasonic PV-DF2735 27 in. TV/VCR/DVD...
Auxillary channel for dvd
You need to determine what output options your DVD player has. Take a look at the rear of the player. It will certainly have RCA jacks for video and audio outputs (yellow for video, red and white for right and left channel audio). It may also have RCA jacks for component video (marked Y, Pb and Pr). Finally, it may have a threaded connector marked "out to TV" or "antenna out" or something similar. This is called RF output.
Most players today don't offer RF output because nearly every TV has direct AV inputs available. If your DVD player has RF output, connect the output connector to the TVs antenna input. You need a coaxial cable with F-connectors on the ends. One may have been supplied with the player. RF output is on channel 3 or 4, set by a switch on the back of the player or by its on-screen setup. Just set the TV to that channel to watch a DVD.
If your player doesn't have RF output, you connect it to the TV using the AV jacks. You need cables with RCA plugs to to connect the video and audio from the player to the TV. Then you switch the TV to its video input to watch the DVD.
This is where you might run into problems. Many TVs need the original remote control to switch inputs. (Some older RCA sets used channels 90, 91 and 92 to switch to their video inputs so any remote would work, but these sets were made before 125-channel tuning became standard. If your set is one of those models, those are the auxiliary channels you heard about.) If you can't switch the set to video input with front panel buttons and you don't have the right remote, you're not completely out of luck.
If you can't use your set's AV inputs or it just doesn't have any, you need an RF converter. These cost around $15. They take the audio and video from the DVD player and convert it to channel 3 or 4. Then you hook that output to your TV as described above.
May 17, 2009 | RCA Universal Remote Control
Video mode on GE 27GT610
Try hooking up the dvd player and turning it on. Then use the setup and add/erase channel feature to look thru all of the channels. On my older GE tv I found that channel 91 was the correct channel for the video input. I saw the logo for the dvd player on this channel. I just added that channel and now it works. Your channel might be different.
Feb 22, 2009 | GE 27GT616 27" TV
Video channel
if your DVD player supports a HDMI cable a single cable is enough for both audio and video channel.
but both your player and TV must support HDMI.
Aug 12, 2008 | Samsung DVD-V4600 DVD Player/VCR
Rca guide plus gold 32'
pull the ac plug for about 5 min and start your set up again paying atention to the features you want and don;t.set the menu to suite your requirements.
Jan 16, 2008 | RCA 32F531T 32" TV
Samsung DVD-V4600 DVD Player/VCR Logo
114 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
