Question about EliteGroup 945GZT-M (V1.0) Motherboard
Computer shuts down y by itself
Installed motherboard successfully to do to the point of rendering proper BIOS readings, however computer shuts down without notice ( not even 5 minutes passes before this happens ) What to do? maybe its connectors or cables - hope its not more serious than that
  • robbyrob Dec 02, 2007
    AND fan is not spinning
  • Anonymous Apr 06, 2009
    my problem is my computer with 945GZT-M (V1.0) Motherboard can't be turn of after i choose shutdown from window xp os. if i choose shutdown menu in window xp, my computer act like if i choose restart. please anybody can help my problem? thanks
  • 656 Answers
Remove ur power supply socket from the mother board short the pin green and black in the connector if the smps start no problen with the power supply then the problems lies with ur mother board wiring or fault in your mother board if your mother board has secondry power fix it correctly to mother board sock et with has 4 pin if its not working cousult a chiplel engineer the fault lies in the power supply of the motherboard
Posted on Dec 04, 2007
SOURCE:
How to boot from usb on a powerspec
PowerSpec computers, as do all personal computers, have a motherboard inside that provides power and support to every piece of hardware that makes up the entire machine.
When your computer is first turned on, a small chip on the motherboard that houses a small piece of software called the BIOS (Basic Input/Output System) fires up before anything else and directs the startup processes for the rest of the computer.
By entering the BIOS settings, you can alter these startup procedures and control the power flow to certain components or stop them from starting up entirely.
The BIOS settings are only recommended for advanced users, as an improper change can stop your computer from starting up. Shut Down
Shut down your computer completely.
Do not make it hibernate or reset.
You need a fresh startup to enter the BIOS settings.
Waiting Period
Wait about 10 or 15 seconds after shutdown to allow the computer to become completely dormant.
Rebooting
Turn the computer back on and immediately begin pressing the "Delete" button on your keyboard at regular intervals (every two seconds).
Eventually the BIOS settings appear.
The display will look monochromatic and antiquated when compared to a modern Windows display.
This is typical of the BIOS setup screen.
Using the BIOS Menu
Using the keyboard arrow keys to move around the BIOS menu advanced bios features press enter change your first boot device to USB press "Enter" to select options once they are highlighted.
Press escape then press f10 to save to cmos to restart
and
Don't make random changes to the BIOS, as an improper setup can render your computer effectively useless.
Mar 10, 2014 | Computers & Internet
How to boot from usb drive on a powerspec
Waiting Period
Rebooting
Using the BIOS Menu
and
Hp pavilion a815n, ASUS PTGD1-LA motherboard. Specifications state can do processor upgrade intel pentium 4 3.6-3.8 ghz w/HT technology. I did computer doesn't support and shuts down. anything I c
Hi James,
Your best bet will be to visit the Asus website and click on the 'support' tab at the top of the screen. Select the link for 'drivers' and specify your motherboard model. It's possible that there will be a BIOS update for your Asus m/board.
If so, do a BIOS flash and check if your PC will then accept your new CPU. NB! Take care when flashing the BIOS. Make sure there are no power interruptions etc. while performing this procedure as this could corrupt your BIOS software and render your motherboard useless.
Feel free to message me should you need more details or further assistance.
Best wishes,
Graemevm
Jan 12, 2012 | HP Pavilion a815n (PS512AA) PC Desktop
On bootup win xp does not read hard drive... even a known good one. "cant find OS" even though it detects the drive is there in F2 I have even been able to format the HD. My question is .... Is...
Sounds like it might be a motherboard issue BUT the best thing to do is to put a known good working hard drive in that computer and try installing Windows from the cd. If it can't install then the motherboard is bad more then likely. You can also try swapping out memory and trying it in different slots as well. If somebody tried flashing the BIOS and the computer got shut off by accident, that can screw up a BIOS and render the computer useless.
May 25, 2011 | Intel Pentium Dual Core E2140 / 1.6 GHz...
Trying to enter BIOS on Gateway 7330GZ and it is requesting a password on a old dos type screen
To reset the bios you must clear the CMOS
There are two ways to approach forcing the Bios/CMOS to be reset to its default values: Option #1: Mechanically, by removing all power to the Bios/CMOS thereby forcing it to reset itself to its stored defaults, which include no password or the default password employed by the Bios manufacturer, and Option #2: Using a program to either locate and identify the password and reveal it to you or erasing the password entirely. These are referred to as password by-pass utilities or cracks.
Let's look at Option #1
By either resetting a jumper on the motherboard itself (referred to as a "clear CMOS" jumper), or by physically remove the power from the computer (disconnecting the power plug) and then removing a battery (used to maintain power to the PROM chip that contains the Bios/CMOS information) from the motherboard.
If the "Clear CMOS" jumpers are not present or not available:
Shut down the computer and disconnect the power plug. Locate, if possible, the instruction booklet for your motherboard. Now identify where the battery is located on the motherboard. It will be approximately 1/2 inch in diameter.Leave the battery our of the computer for about 20 to 30 minutes and then return it to its socket. Now plug the power cord back in and restart the computer.
for further information read
http://www.dewassoc.com/support/bios/bios_password.htm
May 02, 2011 | Gateway 7330GZ Notebook
What is bios?
A BIOS (Basic Input/Output System) is an electronic set of instructions that a computer uses to successfully start operating. The BIOS is located on a chip inside of the computer and is designed in a way that protects it from disk failure.
A main function of the BIOS is to give instructions for the power-on self test (POST). This self test ensures that the computer has all of the necessary parts and functionality needed to successfully start itself, such as use of memory, a keyboard and other parts. If errors are detected during the test, the BIOS instructs the computer to give a code that reveals the problem. Error codes are typically a series of beeps heard shortly after startup.
Oct 02, 2010 | Intel Motherboard
Unable to shutdown the computer
it is the problem your computer operating system or motherboard bios setup problem . You restart your pc after restart then press dell key then prevew your bios setup option then choice bios defalt setup then press F10 press Y restart your pc .
Jul 21, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
System reinstall
Go into the Bios settings and locate (restart on all errors) and disable it.Then do a normal install.
Jan 07, 2009 | HP Compaq Presario V5000Z Notebook
Cmos checksum bad...usb current status detected system shut down 15 sec
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
May 11, 2008 | ASUS M2N-MX Motherboard
Power down
Windows does not shut down. Additional information and causes that may cause Windows 95 or Windows 98 to freeze, hang or lockup when attempting to shut down the computer.
How to restart or shutdown the computer in DOS. If you are currently in DOS and need to turn off the computer press the power button. Note: some newer computers may not allow the computer to be shut down ...
Installing a pc computer power supply Write down important information from the top or bottom of the power supply such as the Model Number, Serial Number and specifications (such as voltage...).
Basic floppy disk drive troubleshooting Power down, unplug, and open computer, being aware of ESD and its potential dangers. Verify that the floppy connection is connected to the motherboard FDD .
Good Luck, Read and follow instructions/Please dont for get to Vote/Thank You.
Dec 23, 2007 | Intel Motherboard
Open Questions:
See all EliteGroup 945GZT-M (V1.0) Motherboard Questions
EliteGroup 945GZT-M (V1.0) Motherboard Logo
141 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
