Question about Nintendo Wii Console
Wii cosole When disk inserted it says press A to continue, when we press A it comes up on the screen system files are corrupted, please refer to operations manual. We have tried turning off and restarting but it does it every time with all our disks. Please help Thanks.
  • Daisy1221 Dec 02, 2007
    Try turning the disk around upsidedown
  • XavAcid Nov 22, 2008
    operations manual. But this doesn't happen to all the games, though.
    President:
  • 4,402 Answers
Http://www.nintendo.com/consumer/repair/repair_charts_wii.jsp
have to send in for repair.
Posted on Dec 13, 2007
My toshiba satellite L455D-S5976 Laptop says A disk read error occurred, how do i fix this, cause i wanna restore to factory settings but i have no disc for the laptop... Please Help!!!!
hi,
that error message is referring to your hard disk. Some of the sectors are corrupted and it might have to do with the part that contains your operating system or boot manger. You're advised to get a new disk, install a fresh copy of your operating system, and recover your files from the other disk by attaching it to the system like an external drive.
hope this helps
Jul 04, 2011 | Computers & Internet
Tip
HOW TO REPAIR MISSING OR DAMAGE FILES PLEASE NOTE THAT THIS APPLY TO BOTH...
PLEASE NOTE THAT THIS APPLY TO BOTH LAPTOP AND DESKTOP COMPUTERS.
Hi there if your computer has missing files or a file is corrupt and you need to repair the damage file, you can do this by using a recovery disk for the computer if you have one. If you do not have a recovery disk for the computer you can use the operating system disk to repair it, please follow these steps: insert the operating system disk into the CD/DVD drive, restart the computer, press F12 and choose boot from CD save and exit. While the computer is loading it will ask you to press any key to boot from CD, so you will press any key, a blue screen will appear while its loading, when it get to the first set of options you will press enter to continue. when it get to the second set of options it will ask you to install the operating system or repair it, choose repair and follow the steps from there, once you choose repair, the computer will go through different stages. The next step is to enter the keys for the operating system the computer will continue until it finish the repairs and this should solve the problem of missing files. But you should backup your files before doing this even though no files should be lost but its better to backup just in case something goes wrong. Backing up the file is always an important part of having a computer, you should also create a recovery CD and this can be done during the process of backing up your computer files. The back up files should be store on one or more DVDs or other storage device and this along with the recovery CD should be store in a safe and dry place. The purpose of the recovery CD is to repair damage or missing files on the computer and each computer require its own back up and recovery disk to repair the problem.
on Jun 17, 2010 | Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Computer turns on but will not load windows. Freezes after gateway comes on. Plus cannot start in safemode
Enter the BIOS and ensure that the Hard drive is indeed being seen by the computer.
Open up the chassis side panel and ensure that all conections are making contact.
damnor01
Apr 14, 2011 | Gateway 3250S PC Desktop
My Hitachi Microdrive 4gb hard drive seems corrupt, but my computer still shows photos as jpg files (about 1000kb) and jrg files(30000kb, impossible). When I try to open them, the computer shows "no file"...
H there this mean a file is corrupt and you need to repair the damage file,you can do this by using a recovery disk for the computer if you have one.If you don't do not have a recovery disk for the computer you can use the operating system disk to repair it,please follow these steps:insert the operating system disk into the drive,restart the computer, press F12 and choose boot from CD save and exit.As the computer loading it will ask you to press any key to boot from CD, press any key, a blue screen will appear while its loading, when it get to the first set of options you will press enter to continue. when it get to the second set of options it will ask you to install the operating system or repair it, choose repair and follow the steps from there, this should solve the problem. But should backup your files before doing this even though no file will be lost but its better to backup just in case something goes wrong.
Jun 16, 2010 | Hitachi Microdrive (HMS360404D5CF00) 4 GB...
My pc is lock .my dauther try to many password
Some times the CAPS Lock key may be on, so please make sure that the CAPS Lock key is off.
If the issue still exists, I request you to perform the full system recovery using the recovery disks. To perform this full system recovery, you can use the recovery disks that you have created using the recovery partition.
Use the recovery discs to restore the PC by following the steps below:
1. Insert the recovery disc in the optical disc drive and start the computer.
If the computer is running, insert the recovery disc and immediately click Start and select Restart to force the computer to start from the recovery disc.
2. When prompted, Press any key to boot from CD or DVD, press any key on the keyboard.
3. Allow the recovery disc to start and load the required files while the Microsoft loading screen is displayed. It may take several minutes to load the required files.
4. When the HP Recovery Manager window displays, click Advanced options , System recovery , and then click Next to open the Recovery Manager.
5. Follow the on-screen instructions and perform the required actions.
NOTE: Do not interrupt the recovery process even though the computer may restart and the Windows desktop may display at various times.
· When prompted, follow the on-screen instructions to Backup the user files.
After performing the backup, when prompted, re-insert the recovery disc, and then click Next to continue the recovery process.
· A status box is displayed to indicate the status of the recovery and the estimated time remaining.
· If you used multiple discs when you created the personalized recovery discs, follow the prompts to remove the first disc and insert any requested discs.
6. When prompted to Insert the Supplemental driver disc , take one of the following actions:
· If you purchased a replacement recovery disc from HP, and it included a Supplemental driver disc, insert the disc and click OK or Next . The recovery program checks the supplemental disc and installs the specific needed files.
After the Supplemental files are installed, a prompt is displayed to remove the Supplemental disc and insert the original recovery disc.
· If you purchased a replacement recovery disc from HP, and it did not include a Supplemental driver disc, click Skip or Cancel . The recovery program will ignore the request and install the next file on the recovery disc.
· If you created a personal recovery disc, press Next to continue.
7. Continue following the on-screen instructions to complete the recovery process.
NOTE: If you have not created a personal recovery disc, or the recovery disc fails or become corrupted, see HP Notebook PCs - Order Recovery Discs for Vista as your notebook is preinstalled with Genuine Windows Vista Home Premium with Service Pack 1.
For detailed steps you can refer the provided web link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00809678&product=18703
NOTE: Clicking the above link may give an error indicating that it is invalid. If this occurs, copy the link and paste it on the address bar in your browser until the complete address is displayed in the Address box.
If you do not have the recovery disks you can order these recovery disks from the local HP phone support. Please use the provided phone number to contact the local HP phone support.
Phone number: 800-474-6836
May 29, 2010 | HP Pavilion dv6000z Notebook
PS3 stuck on screen saying hard disk corrupted
Hi
Please refer to this link for ways to troubleshoot the hard drive and sometimes if you are lucky you can recover the problem - however if these solutions fail the unit will have to be sent in for repair I am afraid.
Check out this link
http://playstation.custhelp.com/cgi-bin/playstation.cfg/php/enduser/std_adp.php?p_faqid=441&p_sid=LcojCxNj
Thanks for using FixYa.
Nov 21, 2009 | Sony Playstation 3 (PS3) Console
I have a Epic notebook ACE 1314 model no. MS_1314 and when i turn it on it comes up with NTLDR is missing can anyone help me please? Cheers Dylan
the windows system is trashed - boot from a xp cd and choose repair -
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Sep 10, 2009 | Computers & Internet
Hard disk's file system is corrupted.
Most likely your hard drive is completely corrupted. It could be as simple as a new Hard Drive replacement or as complicated as a motherboard issue.
Check out ccgamingonline.com
They give you free estimates for your broken system.
May 09, 2009 | Sony Playstation 3 (PS3) Console
Insert system disk push any key to continue. 445 cdx
maybe your system is corrupted that why you need to insert the system disk or installer. if you have a windows installer try to insert in the cdrom if the system look for the corrupted files in the installer to replaced the damage files
Apr 14, 2008 | Computers & Internet
Nintendo Wii Console Logo
135 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
