Question about Microsoft Xbox Console
Xbox original how to change hard drive in xbox
  • mikewt45 Dec 03, 2007
    red and green flashing light after 3 seconds of image ocasionally it works but its about 1 every 60 trys plz help
    President:
  • 4,402 Answers
The Best way to change the hard drive is to purchase a mod.
heres more info http://www.llamma.com/xbox/Repairs/hard_drive.htm
Posted on Dec 08, 2007
My xbox 360 is now showing flashing 1 red light on and off
These steps are taken from the support site as always, it's the first website where you should look.
Solution 1: Disconnect and reconnect cables
Here's how:
  1. Turn off your Xbox 360 console.
  2. Unplug all memory units, controllers, and accessories from your console.
  3. Unplug everything from the back of your console, including power and video cables.
    Don't remove the hard drive.
  1. Reconnect your console's power supply.
  2. Reconnect each accessory one at a time, starting with a controller.
  3. After you've reconnected every accessory, turn the console on.
Solution 2: Remove the hard drive
To see whether the problem involves the original Xbox 360 Hard Drive, temporarily remove the hard disk drive. Here's how.
Note Not all Xbox 360 consoles include a hard drive. If your Xbox 360 console doesn't have a hard drive, to go Solution 3.
  1. Turn off the console.
  2. Locate the hard drive on the top of the console (or on the left side, depending on how the console is oriented).
  • Press the release button on the hard drive.
  • Lift the hard drive away from the console.
hdseparating.jpg If these steps resolve the issue, reattach the hard drive to verify that the error occurs only when your Xbox 360 Hard Drive is connected.
Solution 3: Disconnect memory units or USB flash drives
Here's how:
  2. Unplug any memory units or USB flash drives attached to your console.
  3. Turn on the console.
If these steps resolve the problem, reattach the memory unit or USB flash drive to make sure the error occurs only when it's connected. If this is true, order a replacement memory unit or use another USB flash drive.
Solution 4: Request a repair
If the previous steps don't resolve the single flashing red light issue, there are no additional troubleshooting steps. Your original Xbox 360 console must be repaired at our service center. Start the repair process online.
Jan 09, 2015 | Microsoft Xbox 360 Console
I have a 320gb hard drive for my Xbox and when it is inserted it doesn't show on the dashboard for memory devises
In this process your hard drive will be formatted, so back up all files to another hard drive, laptop, or be prepared to lose everything on your hard drive. After you have backed everything up, plug your hard drive into an Xbox 360 then go 'My Xbox/System Settings/Memory.Select 'USB Storage Device/Configure Now' then accept the warning.After the formatting is complete a Performance Warning box will appear, click 'OK.' Now in the 'Storage Devices' screen you should see a new option 'Memory Unit.' This shows that the formatting was successful. Disconnect your hard drive, then connect it to your laptop, load on some media (makes sure the file types are compatible), then reconnect it to your Xbox 360. Your selected media should not appear under 'Portable Device' in the Video/Music/Picture Library.
Dec 27, 2013 | Microsoft Open Box Xbox 360 320gb Hard...
Original xbox it freezes then a box with a circle with a red x and says.A problem has occured.Please restart your Xbox
Check that you have reconnected the IDE cables to the DVD drive and the hard drive and that they both have power. I think this happens when the xbox cannot detect one of the devices.
Jun 25, 2012 | Microsoft XBOX Thompson, Thomason or...
I can not play original xbox games now it said the hard drive must be attached and it is what is the problem?
Just assuming that your hard drive did not come with your Xbox 360? Or if it did then you bought your Xbox 360 used maybe? Below is the reason why some hard drives won't work with BC games. But before you go out and buy a new HDD then go ahead and remove your hard drive from the Xbox 360 and reinsert it to see if that helps. Note: it has to be a HDD not a USB memory for BC gaming.
"Simple. Certain eBay sellers try to make more money by buying 20GB official Microsoft Xbox 360 hard drives for cheap, and then putting larger laptop hard drives into the official 360 hard drive case and then selling them for less than an official drive of the same size would be. Now, technically, these hacked hard drives are the exact same thing as an official one, at least as far as parts go. They will function exactly the same as an official drive. But many of the sellers that sell these drives forget (or might be just plain ignorant about) one important thing - to play backward compatible Xbox games, the hard drives need a special partition for the Xbox 360 to store BC-related data in. If the hard drive doesn't have that partition, you can't play backward compatible games with it."
"So, to answer the question "Why won't original Xbox games work on my Xbox 360" there really is only one answer - Your cheap eBay hard drive might not be as official as you thought and is missing key files that allow for backward compatibility. The solution - Buy official Xbox 360 accessories from established retailers, or if you want to save a few bucks on eBay, make sure you ask the right questions so you know what you're getting."
Aug 04, 2011 | Video Game Consoles & Games
The old can't be played on the new 360?
The Xbox 360 is backwards compatible with certain games that were released for the original Xbox. Currently there are more than 200 BC titles with more being added all the time. Big name titles such as Halo, Halo 2, Splinter Cell: Chaos Theory, Star Wars: Knights of the Old Republic, and Ninja Gaiden Black are just some of the Xbox games you can play on Xbox 360
There is a requirement for backwards compatibility and that is you have to have a hard drive for your Xbox 360. If you bought a Core system you can't play original Xbox games on your system until you buy a hard drive
Jan 14, 2011 | Microsoft Xbox 360 Console
Games on hard drive
Hi, is the xbox modified or is a retail version of your xbox. Retail Xbox's cannot load games from it's hard drive. The games you must be seeing are the game save files in the memory menu. If it is modified and you cannot play and of the games, then it is going to require reinstalling. As for the dvd games, your xbox dvd drive will need replacing. Any xbox modifying outlet will be happy to change that for you. Just be aware that around a 50NZD will be most likely the charge.
Jul 18, 2009 | EA Sports Video Game Consoles & Games
XBOX games on XBOX 360
You must have an Xbox 360 Hard Drive to play original Xbox games on your Xbox 360 console.
You can only play approved original Xbox games on Xbox 360. Visit the following Web site to view a current list of approved original Xbox games that you can play on Xbox 360:
http://www.xbox.com/games
Jan 02, 2009 | Microsoft Xbox 360 Console
Xbox 360 won't play old xbox games?
If your console is hooked up to Xboxlive and has a Hard Drive connected to it you will automatically be prompted to update upon insertion of the original Xbox title. Your console will restart when it's ready and you should be able to play.
*If you do not have a Hard drive you cannot play original Xbox titles.* The original Xbox Memory unit will not work in Xbox360 and the original Xbox games have no access to the Xbox360 memory units.
If you have a Hard Drive but your Xbox360 is not hooked up to the internet you can either order a disc for free from Microsoft by going Here
or burn the needed information onto a disc by going Here
Dec 26, 2008 | Microsoft Xbox 360 Console
Xbox360
i suspect you bought the xbox 360 core version. this does not come with a hard drive and therefore you cannot play original games. since you have the 30 day warranty i'd recommend you buy either the premium (comes with 20 gb hard drive) or the elite (120 gb hard drive). or you can buy a hard drive seperately and install it, however it's very overpriced like all 360 accessories
hopefully that helps
Dec 30, 2007 | Microsoft Xbox 360 Console
Tranport old hard drive data to new drive
Just click it loose from the old one and attach it to the new one. Shouldn't be a problem as long as ito's original.
Nov 26, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
78 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
